[Nek5000-users] How to assembly different geometry
Sun Oct 30 23:22:50 CDT 2016
Hi Paul,
Thanks a lot. Your .box file is also running. Mine is not...
I have only modified the dimensions of the mesh according to what I
need. Do you see anything wrong?
rbsissa2d.rea
2                      spatial dimension
1                      number of fields
#    Here is a multibox example
Box                        left lower
-3  -2                     nelx,nely,nelz for Box)
0  1  1.0               x0 x1 ratio
0  0.47   1.0               y0 y1 ratio
v  ,W  ,SYM,   ,          (bc's)
Box                        left center
-3  -3                     nelx,nely,nelz for Box)
0  1   1.0               x0 x1 ratio
.47 .53   1.0               y0 y1 ratio
v  ,   ,   ,   ,          (bc's)
Box                        left upper
0  1   1.0               x0 x1 ratio
.53  1   1.0               y0 y1 ratio
v  ,W  ,   ,SYM,          (bc's)
Box                        center center
1  1.47   1.0               x0 x1 ratio
    ,   ,W  ,W  ,          (bc's)
Box                        right lower
-3  -4                     nelx,nely,nelz for Box)
1.47  9.47   1.0               x0 x1 ratio
    ,O  ,SYM,   ,          (bc's)
Box                         right center
    ,O  ,   ,   ,          (bc's)
Box                         right upper
    ,O  ,   ,SYM,          (bc's)
Il 31/10/16 00:01, nek5000-users at lists.mcs.anl.gov ha scritto:
> Hi Alessondro,
> Just to be clear, I attach the mbox.box file that I used.  It works
> with the current repo
> version of genbox (and earlier ones).
> Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Sunday, October 30, 2016 10:32 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] How to assembly different geometry
> Hi Paul,
> Thank you so much. Are the BC's correct?
> I have slightly modified your script and I get the following error.
> What is wrong in your opinion?
> forrtl: severe (24): end-of-file during read, unit 99, file
> /galileo/home/userexternal/aalla000/channel/box.tmp
> Image              PC                Routine Line        Source
> libifcore.so.5     00007FD15E583947 Unknown               Unknown  Unknown
> libifcore.so.5     00007FD15E5C209F Unknown               Unknown  Unknown
> libifcore.so.5     00007FD15E5C0538 Unknown               Unknown  Unknown
> genbox             0000000000416D0D Unknown               Unknown  Unknown
> genbox             000000000040270C Unknown               Unknown  Unknown
> genbox             000000000040134E Unknown               Unknown  Unknown
> libc.so.6          00007FD15C6A0B15 Unknown               Unknown  Unknown
> genbox             0000000000401259 Unknown               Unknown  Unknown
> Thanks a lot,
> Alessandro
> Il 30/10/16 22:25, nek5000-users at lists.mcs.anl.gov ha scritto:
>> Hi Alessandro,
>>  Here is a multi-box file example that will generate something
>> similar to what you're
>> after.  You can edit to suit your needs.
>> Paul
>> one2d.rea
>> 2                      spatial dimension
>> 1                      number of fields
>> Box  left lower
>> -2  -1   0.8               x0 x1 ratio
>> -2 -.1   1.0               y0 y1 ratio
>> v  ,W  ,SYM,   ,          (bc's)
>> Box  left center
>> -.1 .1   1.0               y0 y1 ratio
>> v  ,   ,   ,   ,          (bc's)
>> Box  left upper
>> .1   2   1.0               y0 y1 ratio
>> v  ,W  ,   ,SYM,          (bc's)
>> Box  center center
>> -4  -3                     nelx,nely,nelz for Box)
>> -1   0   1.0               x0 x1 ratio
>>    ,   ,W  ,W  ,          (bc's)
>> Box  right lower
>> 0   2.   1.2               x0 x1 ratio
>>    ,O  ,SYM,   ,          (bc's)
>> Box  right center
>>    ,O  ,   ,   ,          (bc's)
>> Box  right upper
>>    ,O  ,   ,SYM,          (bc's)
>> .... PS ---- Be sure that you have 3 characters (counting spaces)
>> for each BC.
>> The "right upper"  "right center" etc. are just comments.
>> "Box" is a keyword, however... (so to distinguish from cylinder, etc.)
>> *Sent:* Sunday, October 30, 2016 3:09 PM
>> I can think of two options:
>> - Create the three different boxes with genbox and merge them with
>> nekmerge
>> - Create the whole mesh with your favorite meshing tool, export it as
>> EXODUSII and use exo2nek
>> Von: <nek5000-users-bounces at lists.mcs.anl.gov
>> <mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of
>> <nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>>
>> Antworten an: <nek5000-users at lists.mcs.anl.gov
>> Datum: Sunday, October 30, 2016 at 10:26 PM
>> An: <nek5000-users at lists.mcs.anl.gov
>> Betreff: [Nek5000-users] How to assembly different geometry
>> Hi All,
>> I would like to generate a mesh as Figure 2 in
>> http://www.mathematics.uh.edu/docs/math/NASC-preprint-series/2015_2016/Preprint_No16-54.pdf
>> If I build three different boxes, how can I then assemble them? Could anyone please help me?
>> Thanks,
>> Alessandro
>> Dr Alessandro Alla
>> Florida State University
>> Department of Scienfitic Computing
>> 400 Dirac Science Library
>> Tallahassee FL 32306-4120
>> Room:   462
>> Phone:  +1 8506441010
>> E-Mail:aalla at fsu.edu
>> Skype: alessandro.alla
>> www.alessandroalla.com
>> _______________________________________________ Nek5000-users mailing
>> list Nek5000-users at lists.mcs.anl.gov
>> <mailto:Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Nek5000-users mailing list
> Dr Alessandro Alla
> Room:   462
Dr Alessandro Alla
Room:   462
E-Mail: aalla at fsu.edu
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161031/536c791c/attachment-0001.html>
