[Nek5000-users] Mesh consistency check failed for merged 2D meshes
Tue Oct 25 05:19:04 CDT 2016
Hi Johan,
I found that I could merge these with pretex (the text-based version of prenek), which
is what I normally use.
Here is a little script that also seems to work, given the outputs of genbox on your
two files.
I call the script "merge2d" and invoke it as:
merge2d   casea caseb casec  to merge casea.rea with caseb.rea and yield casec.rea
ln $1.rea tmp_mg1.rea;
ln $2.rea tmp_mg2.rea;
pretex << EOF
tmp_mg3
       1 READ PREVIOUS PARAMETERS
tmp_mg1
       1 BUILD FROM FILE
tmp_mg1
      10 IMPORT MESH
tmp_mg2
n
       1 END    ELEMENTS
       1 ACCEPT MATL,QVOL
       1 ACCEPT B.C.'s
       1 ACCEPT B.C.'s
       1 EXIT
EOF
mv tmp_mg3.rea $3.rea
rm -f *.dra tmp*
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, October 25, 2016 3:18 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Mesh consistency check failed for merged 2D meshes
I have problems with merging two 2D meshes.
I want to merge two meshes generated with genbox:
1. walls.box
This mesh is an "Y"-type mesh. It goes from beeing a square of side 10 into a square of side 0.5 via two circles (of radii 1.1 and 1.0).
2. center.box
This is an "Box"-type mesh. It is a square of size
This is walls.box:
reafile.rea
2
1
Y
4 -8
0. 0.
bbccb
0.5 0.6 1. 1.1 10.
0 1 1
W  ,W  ,E  ,E  ,
And this is center.box:
reafile.rea
2
1
Box
-2 -2
-0.5 0.5 1.
-0.5 0.5 1.
W  ,W  ,W  ,W  ,
I can plot the two meshes on top of each other, and the elements seem to align perfectly.
I use nekmerge2 (from the example case "expansion") to generate a merged .rea file:
nekmerge2 center walls bottom
I now obtain a bottom.rea file. I generate bottom.map using genmap (tolerance 0.2).
I compile (using a bottom.usr file and a SIZE file) using makenek.
I run serially using "nek".
Now I get several warnings of the type:
 WARNING2 Element mesh mismatch at:
 I,J,K,IE:    1    2    1           1
 Near Y = -0.50000000     -0.41269471       0.0000000    , d:   0.0000000     -0.36629354E-01   2.0000000
And then "Mesh consistency check failed.  EXITING in VRDSMSH."
No output is generated. What is the problem here? Have I missed some critical aspect of merging meshes?
Best,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161025/0e2cf449/attachment.html>
