[Nek5000-users] Mesh consistency check failed for merged 2D meshes
Tue Oct 25 03:18:55 CDT 2016
I have problems with merging two 2D meshes.
I want to merge two meshes generated with genbox:
1. walls.box
This mesh is an "Y"-type mesh. It goes from beeing a square of side 10 into a square of side 0.5 via two circles (of radii 1.1 and 1.0).
2. center.box
This is an "Box"-type mesh. It is a square of size
This is walls.box:
reafile.rea
2
1
Y
4 -8
0. 0.
bbccb
0.5 0.6 1. 1.1 10.
0 1 1
W  ,W  ,E  ,E  ,
And this is center.box:
reafile.rea
2
1
Box
-2 -2
-0.5 0.5 1.
-0.5 0.5 1.
W  ,W  ,W  ,W  ,
I can plot the two meshes on top of each other, and the elements seem to align perfectly.
I use nekmerge2 (from the example case "expansion") to generate a merged .rea file:
nekmerge2 center walls bottom
I now obtain a bottom.rea file. I generate bottom.map using genmap (tolerance 0.2).
I compile (using a bottom.usr file and a SIZE file) using makenek.
I run serially using "nek".
Now I get several warnings of the type:
 WARNING2 Element mesh mismatch at:
 I,J,K,IE:    1    2    1           1
 Near Y = -0.50000000     -0.41269471       0.0000000    , d:   0.0000000     -0.36629354E-01   2.0000000
And then "Mesh consistency check failed.  EXITING in VRDSMSH."
No output is generated. What is the problem here? Have I missed some critical aspect of merging meshes?
Best,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161025/d3609384/attachment.html>
