[Nek5000-users] fix_geom
Tue Oct 18 08:15:30 CDT 2016
Hi Neks,
Does anyone have any experience using the fix_geom routine?
As I understand it, it is supposed to adjust the interior GLL points
based on the perturbation to the element verticies/edges/faces using
gordon hall.
I am trying to use it for one of my cases but it doesn't seem to have
any effect.
What I do is adjust the locations of some boundary elements in usrdat2
and then call fix geom. Something like the following:
subroutine usrdat2
     call fix_naca
     call fix_geom
end subroutine
Where fix naca adjusts the GLL points on the wall surface to the closest
point given by a naca profile. The internal points do not seem to change
after I call fix_geom.
I looked at the routine in navier5.f and it appears to me that the
perturbation applied is always being set to zero (unless I understand it
wrong). First xm1 is copied to xb, and then xm1 is subtracted from xb to
find local displacements. And the same for y and z coordinates. Which
should always result in zero local displacements...?
So I guess the question is if things are working correctly and I am
doing something wrong or if there is a bug in the routine?
Prabal
