[Nek5000-users] Error Compiling
Wed Nov 16 11:16:22 CST 2016
Try ‘visnek eddy_uv’ without the ‘./'
On Nov 16, 2016, at 11:41 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Thanks for the answer.
I tried to use visnek. After type ./visnek eddy_uv I got these error:
bash: ./visnek: /bin/tcsh: bad interpreter: No such file or directory
Any ideia?
Mateus.
2016-11-16 14:34 GMT-02:00 <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>:
I think you can ignore the error message you are getting.
As for visualization of the solution, you can also use visit or paraview. You have to use visnek.
Marco
On Nov 16, 2016, at 11:12 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
I realize my mistake. My PATH was wrong, now I can compile without problems.
But now I have other problem. After compile with makenek and after run with nekb I can't vizualize the results with postx.
My path is /bin, I type ./postx and I got a black window without a sidebar.
Whats wrong?
Thanks.
2016-11-16 1:11 GMT-02:00 <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>:
What does echo $PATH return for you?
On Nov 15, 2016, at 4:31 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi all,
I'm ver new at nek5000. I'm trying to compiling a first example case (eddy) and I get a error.
After ./makenek eddy_uv
I get:
./makenek: line 92: /home/mateus/nek5000/core/makenek.inc: No such file or directory
make: makefile: No such file or directory
make: *** No rule to make target 'makefile'.  Stop.
Can someone help me?
Mateus Peixoto Avanci
Engenheiro Mecânico
Aluno do Programa de Pós-Graduação em Engenharia Mecânica
Universidade Federal Fluminense
http://lattes.cnpq.br/1773896725783894
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Engenheiro Mecânico
Engenheiro Mecânico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161116/284e1d65/attachment-0001.html>
