[Nek5000-users] Error Compiling
Wed Nov 16 10:41:34 CST 2016
Thanks for the answer.
I tried to use visnek. After type ./visnek eddy_uv I got these error:
bash: ./visnek: /bin/tcsh: bad interpreter: No such file or directory
Any ideia?
Mateus.
2016-11-16 14:34 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
> I think you can ignore the error message you are getting.
> As for visualization of the solution, you can also use visit or paraview.
> You have to use visnek.
> Marco
> On Nov 16, 2016, at 11:12 AM, nek5000-users at lists.mcs.anl.gov wrote:
> I realize my mistake. My PATH was wrong, now I can compile without
> problems.
> But now I have other problem. After compile with makenek and after run
> with nekb I can't vizualize the results with postx.
> My path is /bin, I type ./postx and I got a black window without a
> sidebar.
> Whats wrong?
> Thanks.
> 2016-11-16 1:11 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>> What does echo $PATH return for you?
>> On Nov 15, 2016, at 4:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi all,
>> I'm ver new at nek5000. I'm trying to compiling a first example case
>> (eddy) and I get a error.
>> After ./makenek eddy_uv
>> I get:
>> ./makenek: line 92: /home/mateus/nek5000/core/makenek.inc: No such file
>> or directory
>> make: makefile: No such file or directory
>> make: *** No rule to make target 'makefile'.  Stop.
>> Can someone help me?
>> Mateus Peixoto Avanci
>> Engenheiro Mecânico
>> Aluno do Programa de Pós-Graduação em Engenharia Mecânica
>> Universidade Federal Fluminense
>> *http://lattes.cnpq.br/1773896725783894
>> <http://lattes.cnpq.br/1773896725783894>*
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Engenheiro Mecânico
Engenheiro Mecânico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161116/c9dce5f1/attachment.html>
