[Nek5000-users] Error when creating own mesh
Tue Mar 1 21:57:13 CST 2016
thank you!
On the one hand, if I use a high order mesh in Gmsh, then I find an
error using gmsh2nek, however the error is different to the one that I
posted before. On the other hand, the error that I was asking for is
solved: 1) using a low order mesh, 2) using a higher number of nodes to
create my computational domain in Gmsh.
Cheers
SL
El 01-03-2016 19:24, nek5000-users at lists.mcs.anl.gov escribió:
> Try a lower order mesh in Gmsh.
> Wei
> 2016-03-01 4:34 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
>> Hello,
>> finally, did you solve this problem? I am having the same problem.
>> First I generate a 2D mesh using gmsh, and after that I am using
>> gmsh2nek to create the .rea file. This file seems to be ok. However,
>> when I run genmap, I find the following error:
>> genmap
>> Input (.rea) file name:
>> Cylinder
>> Input mesh tolerance (default 0.2):
>> NOTE: smaller is better, but generous is more forgiving for bad
>> meshes.
>> 0.2
>>  reading .rea file data ...
>>   ERROR: error reading    1           1         782
>>   aborting 510 in routine rdbdry.
>>            1  quit
>> What is the problem? Could you help me, please?
>> Thanks
>> SL
>> El 09-07-2014 23:29, nek5000-users at lists.mcs.anl.gov escribió:
>>> Dear Friedrich,
>>> I recommend running "diff" on the example file and your file.
>>> Assuming that the example file works you should then be close
>>> to understanding the source of difficulty.
>>> Paul
>>> FROM: nek5000-users-bounces at lists.mcs.anl.gov
>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>  SENT: Wednesday, July 09, 2014 5:57 AM
>>>  TO: nek5000-users at lists.mcs.anl.gov
>>>  SUBJECT: [Nek5000-users] Error when creating own mesh
>>> Dear Neks,
>>> I am have attempted to use nek5000, firstly by following some of
>>> the
>>> examples etc.
>>> Now I am trying to create my own simulation, which is based upon
>>> the
>>> ocyl examples.
>>> My efforts simply include creating my own grid points in the .rea
>>> file
>>> to create a slightly different dimension... I believe I have
>>> understood how to define the problem however I continually
>>> receive
>>> errors when creating the genmap it reads as follows....
>>>  ocyl
>>> meshes.
>>>  0.2
>>>  ERROR: error reading 1 11 24
>>>  1 quit
>>> All I have done again is change the dimensions of the elements in
>>> the
>>> .rea file so I do not see why it would now not work?
>>> Thank you for any help in advance,
>>> Friedrich.
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users [1]
> Wei HE 何偉
> School of Aeronautics
> Universidad Politécnica de Madridhttp://www.cfm.upm.es/ [2]
> Links:
> [1] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> [2] http://www.cfm.upm.es/
