[Nek5000-users] Projection technique's parameters
Mon Jun 27 08:01:08 CDT 2016
Paul,
is there a paper/report we can have access to that goes in the details of the implementation, please? Also, are the typical values based on your personal experience?
Marco
On Jun 27, 2016, at 8:55 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Andrew,
The projection routines are currently being overhauled, but the general strategy is:
   Number of projections controlled by p93 and mxprev in SIZE.
   p94 > 0:   start projecting velocity/temp after step p94
   p95 > 0:   start projecting pressure after step 95
I typically set p94 and p95 to 5
I set mxprev and p93 to 20, but sometimes to a higher value.
I used to occasionally to to much higher than 20 (say, 80), but in a recent
rewrite and effort to make projection more robust I slowed the projection
step down with too much work, so another rewrite is due soon.
Paul
PS - note that certain combinations of run parameters don't support
projection or potentially blow up.  Set p94=0 in this case and retry.
There was a bug that was fixed about 6 weeks back---it may have cured
some of the cases that users were running into.
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> [nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> [nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>]
Sent: Monday, June 27, 2016 3:17 AM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] Projection technique's parameters
Hi Neks,
My question is about the parameters which manage the projection method in the NEK5000: p93, p94 and p95. How can the correct values be selected for these parameters to obtain the better performance depending on the nature of simulation: laminar / turbulent, convection / diffusion, time step?
Thank you for any suggestion,
Andrew
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160627/cdd16221/attachment-0001.html>
