[Nek5000-users] Projection technique's parameters
Mon Jun 27 07:55:27 CDT 2016
Hi Andrew,
The projection routines are currently being overhauled, but the general strategy is:
   Number of projections controlled by p93 and mxprev in SIZE.
   p94 > 0:   start projecting velocity/temp after step p94
   p95 > 0:   start projecting pressure after step 95
I typically set p94 and p95 to 5
I set mxprev and p93 to 20, but sometimes to a higher value.
I used to occasionally to to much higher than 20 (say, 80), but in a recent
rewrite and effort to make projection more robust I slowed the projection
step down with too much work, so another rewrite is due soon.
Paul
PS - note that certain combinations of run parameters don't support
projection or potentially blow up.  Set p94=0 in this case and retry.
There was a bug that was fixed about 6 weeks back---it may have cured
some of the cases that users were running into.
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Monday, June 27, 2016 3:17 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Projection technique's parameters
Hi Neks,
My question is about the parameters which manage the projection method in the NEK5000: p93, p94 and p95. How can the correct values be selected for these parameters to obtain the better performance depending on the nature of simulation: laminar / turbulent, convection / diffusion, time step?
Thank you for any suggestion,
Andrew
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160627/bbfb8f90/attachment.html>
