[Nek5000-users] Nek5000-users Digest, Vol 88, Issue 5
Wed Jun 8 11:15:42 CDT 2016
Hello Jing,
Recently I am also working on converting fluent mesh to nek5000. I have
generated the *msh from gambit, then using the mshconvert.py tool to
convert a simple mesh with a circular cylinder inside a square.
simply, I can get the *rea file with circle of the "W", "v" and "O". but I
have met two problems;
1. to impose the periodic boundary conditons: in the script, it strongly
recommend to impose "P" through the script, then how to setup it in
mshconvert.py? the way
convert('mesh.msh', bcs={1:'W',2:'v',3:'O',4:'P', 5:'P'})
can generate the rea field but failed in the step of genmap. so how to
treat boundary 4 and 5 as periodic BCs?
2. about the curved wall. there is no problem to  define a circle by
"Circle" command, but if I want to using "m" to define a spline curve, how
to seed middle points? I know in Gambit I can mesh the line using 3 node, I
defined 3 node mode to mesh a circle, and using "m" instead of "circle",
however,  it failed to generate the rea file. the circle merged into a
point, then what should I do to active the spline curve?
Thanks!
Wei
2016-06-08 15:46 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
> Hi Mansi,
> You can find the updated "mshconvert.py" in the attachment.  You can run
> the script for your case likes
> $ ipython
> In [1]: from mshconvert import *
> Converting from ANSYS Fluent format (.msh) to Nek5000, semtex or FEniCS
> format
> In [2]: convert('mesh_hexa_final.msh', bcs={10:'W',11:'v',12:'v',13:'O'})
> Here I assume that BC "W" is on zone 10, "v" is on zones 11 and 12, and
> 'O' on zone 13.
> The snapshot for the Nek5000 mesh using visit is also attached in the
> email.
> /Jing
> From: nek5000-users-bounces at lists.mcs.anl.gov <
> nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
> nek5000-users-request at lists.mcs.anl.gov <
> nek5000-users-request at lists.mcs.anl.gov>
> Sent: Monday, June 6, 2016 22:09
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Nek5000-users Digest, Vol 88, Issue 5
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Nek5000-users Digest, Vol 88, Issue 4,        Problem creating
>       .rea file (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Mon, 6 Jun 2016 19:58:31 +0000
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users at lists.mcs.anl.gov"
> Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 88, Issue 4,
>         Problem creating .rea file
> Message-ID:
>         <mailman.23344.1465243753.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="iso-8859-1"
> Hello all,
> Thanks jing, that was a lot helpful to me.
> I have generated the .msh file for the hexahedral mesh for my geometry.
> File is attached to this mail.
> I have given boundary condition in this file only let me know if there are
> any changes to be made and file has only one zone( if by one zone you mean
> only 1 type of mesh through out whole geometry).
> Questions:
> 1) Users, what are other ways to convert (Icem cfd) .msh  file to .rea
> file?
> 2) is there any way to smooth hexahedral mesh for unstructured geometry?
> Thanks,
> Mansi Patel
> Sent: Friday, June 3, 2016 1:00 PM
> Subject: Nek5000-users Digest, Vol 88, Issue 4
> Today's Topics:
>    1. Re: Nek5000-users Digest, Vol 88, Issue 3
> Message: 1
> Date: Thu, 2 Jun 2016 21:21:13 +0000
> Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 88, Issue 3
> Message-ID:
>         <mailman.23169.1464902611.24727.nek5000-users at lists.mcs.anl.gov>
> Hi Mansi,
> 1)what should I do to solve error?
> Right now mshconvert can only deal with single zone's case. So you should
> have to manually merge the multi-zone to single-zone in the .msh file.
> Also we found that there are few bugs in the file.  Could you please send
> us your .msh file to test  and then we will get back to you with the
> corrected version?
> 2)what are mesh types that we can use?
> Quadrant  for 2D- and hexahedral for 3D-cases.
> 3) I there any other easy way to convert .msh file to .rea?
> I leave this question to other users.
> Thanks.
> Regards, Jing
> Sent: Thursday, June 2, 2016 19:17
> Subject: Nek5000-users Digest, Vol 88, Issue 3
> Today's Topics:
>    1. problems in generating .rea file (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Thu, 2 Jun 2016 17:12:11 +0000
> Subject: [Nek5000-users] problems in generating .rea file
> Message-ID:
>         <mailman.23153.1464887866.24727.nek5000-users at lists.mcs.anl.gov>
> Hello all,
> I want to ask what type of mesh does Nek5000 accept? tetrahedral,
> hexahedral,etc?
> Because I am using ICEM CFD for generating mesh which has extension .msh
> and for that I used python code given for mshconvert to convert into .rea
> file but I am getting error. the error image is attached.
> Please let me know following questions
> Thanks, any help would be appreciated.
> Thanks,
> Mansi Patel
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160602/aaf91e41/attachment.html
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: error.png
> URL: <
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160602/aaf91e41/attachment.png
> End of Nek5000-users Digest, Vol 88, Issue 3
> End of Nek5000-users Digest, Vol 88, Issue 4
> URL: <
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160606/e07ab762/attachment.html
> Type: application/octet-stream
> Desc: mesh_hexa_final.msh
> URL: <
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160606/e07ab762/attachment.obj
> End of Nek5000-users Digest, Vol 88, Issue 5
Wei HE 何偉
School of Aeronautics
Universidad Politécnica de Madrid
http://www.cfm.upm.es/
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160608/0c29485d/attachment-0001.html>
