[Nek5000-users] problems in compiling the code for parallel run
Thu Jul 14 07:20:10 CDT 2016
Hi Mansi,
I suspect that you can safely ignore the error.  The error probably comes
from line 7 of the "nekbmpi" script:
mv $1.sch $1.sch1
This command is intended to move the .sch file from a previous run, in case
there's one in your directory. If this is your first run, there will be no
.sch file in your directory, and the "mv" command will give the error you
saw. So it probably doesn't indicate a problem.
Best,
Ron Rahaman
Argonne National Laboratory, Math and Computer Science Division
University of Chicago, Department of Computer Science
On Wed, Jul 13, 2016 at 3:27 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello Users,
> I have Redhat linux workstation, I have already compiled code with nekb by
> making changes in makenek file, but now I want to run it parallel. At first
> when I compiled it by making F77 = mpif77 and cc= mpicc and commenting
> IFMPI ="false" I got errors that mpi not found than I installed openmpi
> Now when I compile using makenek it gets compiled successfully but when I
> try to run it using nekbmpi i get errors like
> mv: cannot stat `eddy_uv.sch': No such file or directory
> and sometimes if i do ./nekbmpi eddy_uv 4 it and put enter i get no errors
> on first time but if i enter again for second time I get same error that is mv:
> I want to understand what mistake I am doing and what should I do to get
> rid of errors and also which file can help me to see whats going on in
> simulation
> Thanks,
> Mansi Patel
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160714/d1c4aeb1/attachment.html>
