[Nek5000-users] help : compiling error
Wed Feb 10 14:06:13 CST 2016
I have been compiling nek for now 2 weeks and still it is not done. in the user's manual I have done till maketools all.
after that I was I did
cd
mkdir eddy
cd eddy
cp ~/nek5_svn/examples/eddy/* .
cp ~/nek5_svn/trunk/nek/makenek .
than for applying  changes
vi makenek
I changed
F77 to gfortran , CC to gcc and uncommented the ifmpi = false
than for compiling I did ./makenek eddy_uv
it does not get compile and gives me following please help what should I do?
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/mvmesh.f -o obj/mvmesh.o
 In file /home/users/mansi/nek5_svn/trunk/nek/turb.f:578
      COMMON /SCRUZ/ V1(LX1,LY1,LZ1,LELV)
                   1
Warning: Named COMMON block 'scruz' at (1) shall be of the same size
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/ic.f -o obj/ic.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/ssolv.f -o obj/ssolv.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/planx.f -o obj/planx.o
gfortran -c  -O3 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I./ /home/users/mansi/nek5_svn/trunk/nek/math.f -o obj/math.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/mxm_wrapper.f -o obj/mxm_wrapper.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/hmholtz.f -o obj/hmholtz.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/gfdm_par.f -o obj/gfdm_par.o
 In file /home/users/mansi/nek5_svn/trunk/nek/hmholtz.f:638
      COMMON  /CPRINT/ IFPRINT, IFHZPC
                     1
Warning: Named COMMON block 'cprint' at (1) shall be of the same size
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/gfdm_op.f -o obj/gfdm_op.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/gfdm_solve.f -o obj/gfdm_solve.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/subs1.f -o obj/subs1.o
 In file /home/users/mansi/nek5_svn/trunk/nek/hmholtz.f:2143
      common /ctmp1/ ur(lt),us(lt),ut(lt)
                   1
Warning: Named COMMON block 'ctmp1' at (1) shall be of the same size
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/subs2.f -o obj/subs2.o
 In file /home/users/mansi/nek5_svn/trunk/nek/subs1.f:1578
      common /ctmp1/ exx(lx1*ly1*lz1*lelt)
                   1
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/genbox.f -o obj/genbox.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/gmres.f -o obj/gmres.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/hsmg.f -o obj/hsmg.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/convect.f -o obj/convect.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/induct.f -o obj/induct.o
 In file /home/users/mansi/nek5_svn/trunk/nek/hsmg.f:296
      common /hsmgw/ work(0:lwk-1),work2(0:lwk-1)
                   1
Warning: Named COMMON block 'hsmgw' at (1) shall be of the same size
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:189
      COMMON /SCRNS/ TA1(LX1,LY1,LZ1,LELV)
                   1
Warning: Named COMMON block 'scrns' at (1) shall be of the same size
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:722
               tr(i,2)=rx(i,4,e)*fx(i)+rx(i,5,e)*fy(i)+rx(i,6,e)*fz(i)
                                                           1
Warning: Array reference at (1) is out of bounds
                                           1
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:723
               tr(i,3)=rx(i,7,e)*fx(i)+rx(i,8,e)*fy(i)+rx(i,9,e)*fz(i)
                                                           1
                                           1
                           1
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:919
              cs(i,e)=rx(i,4,e)*fx(i)+rx(i,5,e)*fy(i)+rx(i,6,e)*fz(i)
                                                          1
                                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:920
              ct(i,e)=rx(i,7,e)*fx(i)+rx(i,8,e)*fy(i)+rx(i,9,e)*fz(i)
                                                          1
                                          1
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:946
      common /ctmp1/ work(lxyz1,lelt)
                   1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:472
         c1 = lf(i,2)*b3(i) - lf(i,3)*b2(i)
                                  1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:473
         c2 = lf(i,3)*b1(i) - lf(i,1)*b3(i)
                  1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:477
         lf(i,3) = c3
             1
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/perturb.f -o obj/perturb.o
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1079
     $                         ,vproj(1,5),ivproj(1,5),binvm1)
                                       1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1083
     $                         ,vproj(1,6),ivproj(1,6),binvm1)
                                       1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1379
     $            rx(i,4,e)*zm(i,1)+rx(i,5,e)*zm(i,2)+rx(i,6,e)*zm(i,3)
                                                          1
                                        1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1381
     $            rx(i,7,e)*zm(i,1)+rx(i,8,e)*zm(i,2)+rx(i,9,e)*zm(i,3)
                                                          1
                                        1
                      1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1408
     $            rx(i,4,e)*zp(i,1)+rx(i,5,e)*zp(i,2)+rx(i,6,e)*zp(i,3)
                                                          1
                                        1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1410
     $            rx(i,7,e)*zp(i,1)+rx(i,8,e)*zp(i,2)+rx(i,9,e)*zp(i,3)
                                                          1
                                        1
                      1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:343
     $              +rx(i,7,e)*utz(i))
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:341
     $              +rx(i,7,e)*uty(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:339
     $              +rx(i,7,e)*utx(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:349
     $              +rx(i,8,e)*utz(i))
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:348
     $              fz(i)*(rx(i,2,e)*urz(i)+rx(i,5,e)*usz(i)
                                                1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:347
     $              +rx(i,8,e)*uty(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:346
     $              fy(i)*(rx(i,2,e)*ury(i)+rx(i,5,e)*usy(i)
                                                1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:345
     $              +rx(i,8,e)*utx(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:344
               uf5(i)=fx(i)*(rx(i,2,e)*urx(i)+rx(i,5,e)*usx(i)
                                                  1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:355
     $              +rx(i,9,e)*utz(i))
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:354
     $              fz(i)*(rx(i,3,e)*urz(i)+rx(i,6,e)*usz(i)
                                                1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:353
     $              +rx(i,9,e)*uty(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:352
     $              fy(i)*(rx(i,3,e)*ury(i)+rx(i,6,e)*usy(i)
                                                1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:351
     $              +rx(i,9,e)*utx(i))+
                         1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:350
               uf6(i)=fx(i)*(rx(i,3,e)*urx(i)+rx(i,6,e)*usx(i)
                                                  1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1552
            call intp_rstd(rx(1,5,e),sym1(1,1,1,e),nx1,nxd,if3d,0) ! 0 -
                               1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1553
            call intp_rstd(rx(1,6,e),szm1(1,1,1,e),nx1,nxd,if3d,0) ! 0 -
                               1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1554
            call intp_rstd(rx(1,7,e),txm1(1,1,1,e),nx1,nxd,if3d,0) ! 0 -
                               1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1555
            call intp_rstd(rx(1,8,e),tym1(1,1,1,e),nx1,nxd,if3d,0) ! 0 -
                               1
 In file /home/users/mansi/nek5_svn/trunk/nek/induct.f:1556
            call intp_rstd(rx(1,9,e),tzm1(1,1,1,e),nx1,nxd,if3d,0) ! 0 -
                               1
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:454
                   1
 In file /home/users/mansi/nek5_svn/trunk/nek/convect.f:1538
      common /scrdg/ uf(lf),uxf(lf),uyf(lf),uzf(lf),upwind_wgt(lf)
                   1
Warning: Named COMMON block 'scrdg' at (1) shall be of the same size
 In file /home/users/mansi/nek5_svn/trunk/nek/hsmg.f:2535
      common /scrvh/ h1    (lx1,ly1,lz1,lelv)
                   1
Warning: Named COMMON block 'scrvh' at (1) shall be of the same size
 In file /home/users/mansi/nek5_svn/trunk/nek/perturb.f:700
      common /scruz/ ta (lx1,ly1,lz1,lelt)
                   1
 In file /home/users/mansi/nek5_svn/trunk/nek/hsmg.f:2924
      common /ctmp0/ w(100000)
                   1
Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/navier5.f -o obj/navier5.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/navier6.f -o obj/navier6.o
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/navier7.f -o obj/navier7.o
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1822
         s21 = sij(j1,j2,1,4,e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1823
         s31 = sij(j1,j2,1,6,e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1825
         s12 = sij(j1,j2,1,4,e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1827
         s32 = sij(j1,j2,1,5,e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1829
         s13 = sij(j1,j2,1,6,e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:1830
         s23 = sij(j1,j2,1,5,e)
                          1
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/navier8.f -o obj/navier8.o
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:2706
      common /scravg/ u (lyavg)
                    1
Warning: Named COMMON block 'scravg' at (1) shall be of the same size
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/fast3d.f -o obj/fast3d.o
 In file /home/users/mansi/nek5_svn/trunk/nek/navier8.f:2022
      common  /scrns/ ind,etuple
                    1
 In file /home/users/mansi/nek5_svn/trunk/nek/fast3d.f:1585
            llr(e) = l(1,2,2,e)-lmr(e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/fast3d.f:1586
            lrr(e) = l(n,2,2,e)-lmr(e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/fast3d.f:1587
            lls(e) = l(2,1,2,e)-lms(e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/fast3d.f:1588
            lrs(e) = l(2,n,2,e)-lms(e)
                          1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3056
         xt(l,3) = z(i,j,k)
             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3217
                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3218
                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3220
                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3222
                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3224
                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:3225
                             1
gfortran -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/users/mansi/eddy -I/home/users/mansi/nek5_svn/trunk/nek -I/home/users/mansi/nek5_svn/trunk/nek/cmt -I./ /home/users/mansi/nek5_svn/trunk/nek/fasts.f -o obj/fasts.o
/home/users/mansi/nek5_svn/trunk/nek/navier8.f: In function 'setvert3d':
/home/users/mansi/nek5_svn/trunk/nek/navier8.f:2354: internal compiler error: in expand_expr_real_1, at expr.c:6846
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
make: *** [obj/navier8.o] Error 1
make: *** Waiting for unfinished jobs....
 In file /home/users/mansi/nek5_svn/trunk/nek/fasts.f:343
                  l(i,j,2,e)=1
                       1
 In file /home/users/mansi/nek5_svn/trunk/nek/fasts.f:384
                  w(i,j,1,3,eb)=1.0/l(i+1,j+1,2,e)
                                             1
 In file /home/users/mansi/nek5_svn/trunk/nek/navier5.f:4085
      common /ctmp1/ w(lt,lelt),ur(lt),us(lt),ut(lt),w1(2*lt)
                   1
[mansi at maea203-01 eddy]$
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160210/12dc36b9/attachment-0001.html>
