[Nek5000-users] Genbox periodic simple case
Wed Dec 7 01:36:05 CST 2016
Thank you both Paul and Steffen for your quick response and help.
I will try them out and let you know if I run into problems.
Thanks again,
JP
> Message: 2
> Date: Tue, 6 Dec 2016 08:50:09 +0100
> From: nek5000-users at lists.mcs.anl.gov
> To: <nek5000-users at lists.mcs.anl.gov>
> Subject: [Nek5000-users] Genbox periodic simple case
> Message-ID:
>         <mailman.7237.1481028077.3602.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"; format=flowed
> Hi JP,
> I had a similar issue with genbox when I wanted to create a simple mesh
> where periodic BCs are shared between different boxes. I haven't tested
> Paul's suggestion yet but I wrote a genbox inspired python script that
> did the job in my case.
> You can find it here: https://github.com/Steffen1989/code-snippets
> (genbox.py)
> The Input is very similar to genbox but you can specify a periodic BC
> shared between two boxes with P01, a second one with P02, ... and the
> same with internal BCs, i.e. E01, E02, ...
> This can create a 2d mesh, which is afterwards extruded with n2to3 in
> the third direction.
> Note that it has not been tested thoroughly but you are welcome to give
> it a try and contact me if you run into troubles.
> \Steffen
> Nek5000-users mailing list
> End of Nek5000-users Digest, Vol 94, Issue 5
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161207/2f0d531c/attachment.html>
