[Nek5000-users] Parallel speedup on supercomputer Tianhe-2
Mon Dec 5 04:23:39 CST 2016
What's your problem size (number of elements and polynomial order)?
Let's assume t_MPI << t (this holds if your problem size is reasonably large). Even in this limit you don't get a linear intra-node speedup simply because Nek5000 is not purely compute bound and the cumulative memory bandwidth is saturated with N cores (N < total number of cores).
Cheers,
Stefan
From: <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of <nek5000-users at lists.mcs.anl.gov>
Reply-To: <nek5000-users at lists.mcs.anl.gov>
Date: Monday, December 5, 2016 at 6:12 AM
Subject: [Nek5000-users] Parallel speedup on supercomputer Tianhe-2
Dear Neks,
I'm using Nek5000 to simulate turbulent Rayleigh-Benard convection, which is governed by the coupled Navier-Stokes equations and convective heat equation. I'm running the code on a supercomputer, Tianhe-2, located in Guangzhou, China. Each computer node in Tianhe-2 has 24 cores (2 Xeon E5 12-core CPUs) and 64GB memory. I find the speedup curve is not linear on a single node. For example, a 24-task job is only 8 times faster than the serial one. However, the performance with an increasing number of nodes is quite good. I don't know whether there is any parameter in nek500 that I can change in order to improve the speedup performance of the individual nodes.
Thanks in advance!
Best regards,
Wei XU
Wei XU
Ph.D. Candidate
Nano Science and Technology Program
The Hong Kong University of Science and Technology
_______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161205/d65d89ce/attachment.html>
