[Nek5000-users] Genbox periodic simple case
Sun Dec 4 22:37:52 CST 2016
Hi JP,
Periodicity can only be induced on a single "sub box" ... So you'll
need to rethink your approach a bit.  (I tried to look at your example,
but am guessing that is simpler than your true target.)
I can see that there are some configurations that definitely wouldn't
work in genbox.
Here is one idea:
Set the "P  " bcs to "   "   (3 blanks).
Then, just run the output through pretex (text-based prenek ) and
when you get to the BC menu just
SET ENTIRE LEVEL
AUTO-PERIODIC.
This should just work... (beware, there are some tricky issues with
periodicity when using millions of elements -- it's a workflow issue
that we're trying to clean up).
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Sunday, December 04, 2016 5:15 PM
To: nek5000-users
Subject: [Nek5000-users] Genbox periodic simple case
Dear Users,
I have used genbox for ages but now I need to split a channel
in the x direction and cannot make genmap recognize the periodic boundary
conditions. Can a periodic boundary condition be separated by a box? I need
periodic boundary conditions in x and z. This is my .box:
parameters.rea
-3
1
# Left box
Box1
-10  -10  -10
0.000 2.000 1.00
0.000 2.000 1.00
0.000 2.000 1.00
P  ,E  ,W  ,W  ,P  ,P    bc's
# Right box
Box2
-10  -10  -10
2.000 4.000 1.00
0.000 2.000 1.00
0.000 2.000 1.00
E  ,P  ,W  ,W  ,P  ,P    bc's
I thought it should be really simple but I cannot get it to work... any help/insight?
JP
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161205/a958504c/attachment.html>
