[Nek5000-users] General functionality of the .usr file
Mon Aug 22 08:46:15 CDT 2016
Hi!
I am a new user of Nek5000. I have read through the User Documentation, and ran some simulations. Now it is time for me to start editing a file that a colleague wrote fo me. I therefore need to know how the .usr file is used.
For example: In the User Documentation it is written that uservp() is called "once per processor, and once per discrete point therein". Does this mean that this is called once before the simulation is executed or is it called once per time step or in some other fashion?
I would guess that uservp() is called once before the simulation is run, is that correct? Does thi apply to all routines in the .usr file, or are some of them called repeatedly during the simulation? userbc() for instance?
I have been looking for a definition of the variables that are accessible in the separate routines. For instance, the input arguments to useric are (ix,iy,iz,ieg). I have gotten to understand that ix, iy and iz relate to a spatial coordinate in some way, and that ieg is some kind of index for the fluid element. Is there a precise definition of these names available?
In addition to the input arguments it seems as you have access to more variables than the input arguments in each routine. In useric() you may for instance change ux, uy and uz. Is there a full list of all parameters that are available available?
/Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160822/c887c1fb/attachment.html>
