[Nek5000-users] MPI_TAG_UB
Thu Aug 18 14:07:01 CDT 2016
I checked the source (nekbone 3.1) and it looks like the fortran part does
not use any tagged messages but the C part does. In fact, there are C
parts using the MPI rank to tag messages.
So I am afraid commenting the check won¹t help.
Cheers,
Stefan
Am 8/18/16, 8:55 AM schrieb "nek5000-users-bounces at lists.mcs.anl.gov on
behalf of nek5000-users at lists.mcs.anl.gov" unter
<nek5000-users-bounces at lists.mcs.anl.gov on behalf of
nek5000-users at lists.mcs.anl.gov>:
>Basically, the MPI library that we are testing sets MPI_TAG_UB=65534,
>which is quite low to be used with higher numbers of lp.
>On 18/08/16 19:33, nek5000-users at lists.mcs.anl.gov wrote:
>> To answer your question I need to know why you want to comment this
>>check?
>> Am 8/18/16, 7:02 AM schrieb "nek5000-users-bounces at lists.mcs.anl.gov on
>>> Hi Neks,
>>> I was wondering if someone could tell me the implications of commenting
>>> this section of code out in Nekbone:
>>> if (nval.lt.(10000+max(lp,lelg))) then
>>>         if(nid.eq.0) then
>>>            write(6,*) 'ABORT: MPI_TAG_UB too small!'
>>> 	endif
>>> 	call exitt
>>> endif
>>> We are testing Nekbone with an experimental MPI library.
>>> Regards,
>>> Ken
>>> The University of Edinburgh is a charitable body, registered in
>>> Scotland, with registration number SC005336.
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
