[Nek5000-users] output through .rea and through usrchk
Tue Oct 27 13:47:04 CDT 2015
Paul,  thanks for the answer
For param(12) I have in .rea
 -0.00100E-00 p012 DT
So by putting
    il_hptsout=-0.5/param(12)
in usrchk I wanted to ensure the output with timestep 0.5,
and I don't see problem here.
This simulation had been running for 52 hours on 1024 cores and ended with
node falure
slurmd[node1-057-01]: *** JOB 1134244 CANCELLED AT 2015-10-17T06:56:44 DUE
TO NODE FAILURE ***
So may be it was something wrong on cluster, but I don't understand why gdt*
files (through outpost in usrchk)
and hpts.out are OK.
For me it is also annoying since I wanted to continue this simulation, but
I can only do so with unmodified field output.
So I had to restart it from beginning.
Thank you, Ilias
P.S. Below is the beginning of .rea file
 ****** PARAMETERS *****
   2.60999990      NEKTON VERSION
           2  DIMENSIONAL RUN
         120  PARAMETERS FOLLOW
   1.00000     p001 DENSITY
  0.103000E-01 p002 VISCOS
   0.00000     p003
  -1.00000     p004        p04 Froude^2
   0.00000     p005
   0.00000     p006
   1.00000     p007 RHOCP
  0.144000E-04 p008 CONDUCT
   0.00000     p009
   9.00000E+03 p010 FINTIME
  0.100000E+10 p011 NSTEPS
 -0.010000E-01 p012 DT
   0.00000     p013 IOCOMM
   0.50000     p014 IOTIME
   0000000     p015 IOSTEP
   0.00000     p016 PSSOLVER: 0=default
   0.00000     p017
   0.00000     p018 GRID < 0 --> # cells on screen
   0.00000     p019 INTYPE
   0.00000     p020 NORDER
  0.100000E-05 p021 DIVERGENCE
  0.100000E-08 p022 HELMHOLTZ
  0              p23 NPSCAL
  0.100000E-09 p024 TOLREL
  0.100000E-09 p025 TOLABS
   2.00000     p026 COURANT/NTAU
   2.00000     p027 TORDER
   0.00000     p028 TORDER: mesh velocity (0: p28=p27)
   0.00000     p029 = magnetic visc if > 0, = -1/Rm if < 0
   0.00000     p030 > 0 ==> properties set in uservp()
   0.00000     p031 NPERT: #perturbation modes
   0.00000     p032 #BCs in re2 file, if > 0
   0.00000     p033
   0.00000     p034
   0.00000     p035
   0.00000     p036
   0.00000     p037
   0.00000     p038
   0.00000     p039
   0.00000     p040
   0.00000     p041 1-->multiplicative SEMG
   0.00000     p042 0=gmres/1=pcg
   1.00000     p043 0=semg/1=schwarz
   0.00000     p044 0=E-based/1=A-based prec.
   0.00000     p045 Relaxation factor for DTFS
   0.00000     p046 reserved
   0.00000     p047 vnu: mesh matieral prop.
   0.00000     p048
   0.00000     p049
   0.00000     p050
   0.00000     p051
   0.00000     p052 IOHIS
   0.00000     p053
   0.00000     p054 fixed flow rate dir: |p54|=1,2,3=x,y,z
   0.00000     p055 vol.flow rate (p54>0) or Ubar (p54<0)
   0.00000     p056
   0.00000     p057
   0.00000     p058
   0.00000     p059 !=0 --> full Jac. eval. for each el.
   0.00000     p060 !=0 --> init. velocity to small nonzero
   0.00000     p061
   0.00000     p062 >0 --> force byte_swap for output
   0.00000     p063 =8 --> force 8-byte output
   0.00000     p064 =1 --> perturbation restart
   1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
   6.00000     p066 output : <0=ascii, else binary
   6.00000     p067 restart: <0=ascii, else binary
   0.00000     p068 iastep: freq for avg_all (0=iostep)
   0.00000     p069
   0.00000     p070
   0.00000     p071
   0.00000     p072
   0.00000     p073
   0.00000     p074 verbose Helmholtz
   0.00000     p075
   0.00000     p076
   0.00000     p077
   0.00000     p078
   0.00000     p079
   0.00000     p080
   0.00000     p081
   0.00000     p082
   0.00000     p083
   0.00000     p084 !=0 --> sets initial timestep if p12>0
   0.00000     p085 dt ratio if p84 !=0, for timesteps>0
   0.00000     p086 reserved
   0.00000     p087
   0.00000     p088
   0.00000     p089        p89 reserved
   0.00000     p090
   0.00000     p091
   0.00000     p092
   50.0000     p093 Number of previous pressure solns saved
   5.00000     p094 start projecting velocity after p94 step
   5.00000     p095 start projecting pressure after p95 step
   0.00000     p096
   0.00000     p097
   0.00000     p098
   3.00000     p099 dealiasing: <0--> off/3--> old/4--> new
   0.00000     p100
   1.00000     p101 Number of additional modes to filter
   0.00000     p102 Dump out divergence at each time step
   0.05000     p103 weight of stabilizing filter (.01)
   0.00000     p104
   0.00000     p105
   0.00000     p106
   0.00000     p107 !=0 --> add to h2 array in hlmhotz eqn
   0.00000     p108
   0.00000     p109
   0.00000     p110
   0.00000     p111
   0.00000     p112
   0.00000     p113
   0.00000     p114
   0.00000     p115
   0.00000     p116 !=0: x elements for fast tensor product
   0.00000     p117 !=0: y elements for fast tensor product
   0.00000     p118 !=0: z elements for fast tensor product
   0.00000     p119        p119
   0.00000     p120        p120
      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
   1.00000       1.00000       1.00000       1.00000       1.00000
          13   LOGICAL SWITCHES FOLLOW
  T     IFFLOW
  T     IFHEAT
 T      IFTRAN
 T T F F F F F F F F F  IFNAV & IFADVC (convection in P.S. fields)
 F F T T T T T T T T T T  IFTMSH (IF mesh for this field is T mesh)
 F      IFAXIS
 F      IFSTRS
 F      IFSPLIT
 F      IFMGRID
 F      IFMODEL
 F      IFKEPS
 F      IFMVBD
 T      IFCHAR
   100.000       100.000      -20.0000      -30.0000
XFAC,YFAC,XZERO,YZERO
 **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
      360000  2      360000           NEL,NDIM,NELV
           0  PRESOLVE/RESTART OPTIONS  *****
           7          INITIAL CONDITIONS *****
C Default
C Default
C Default
C Default
C Default
C Default
C Default
  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
           4                  Lines of Drive force data follow
C
C
C
C
  ***** Variable Property Data ***** Overrrides Parameter data.
           1  Lines follow.
           0  PACKETS OF DATA FOLLOW
  ***** HISTORY AND INTEGRAL DATA *****
           0    POINTS.  Hcode, I,J,H,IEL
  ***** OUTPUT FIELD SPECIFICATION *****
           6  SPECIFICATIONS FOLLOW
 F       COORDINATES
 T       VELOCITY
 F       PRESSURE
 T       TEMPERATURE
 F       TEMPERATURE GRADIENT
           0       PASSIVE SCALARS
  ***** OBJECT SPECIFICATION *****
       0 Surface Objects
       0 Volume  Objects
       0 Edge    Objects
       0 Point   Objects
     3960173,8     Bot
On Tue, Oct 27, 2015 at 3:23 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> There is an issue that you don't know for certain the sign of param(12)...
> so I would check
> to be sure to clean up your integer il_hptsout.
> To me, however, it's not clear that that issue alone would be causing the
> problem.
> Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Tuesday, October 27, 2015 6:33 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] output through .rea and through usrchk
> Dear neks,
> Strange thing happend to a simulation where
> I made "standart" output through .rea file,
> i.e.
>    0.00000     p013 IOCOMM
>    0.50000     p014 IOTIME
> and at the same time I need scalar gradients, so I've put to usrchk:
>       if ((istep.gt.0).and.(mod(istep,il_hptsout).eq.0)) then
>       call gradm1(dtdx,dtdy,dtdz,t)
>       call outpost(dtdx,dtdy,dtdz,pr,t,'gdt')
>       endif
> The strange thing that gdt*  (from usrchk) files are saved as should
> should be,
> but "standart" CASE0.f*  were saved onli partially, below is 'ls -rt' of
> the case directory.
> Why whould that happen? may it be cluster issue? (file sizes are not small
> ~530mb)
> -rw-rw-r-- 1  35K Oct 15 02:52 compiler.out
> -rw-rw-r-- 1   99 Oct 15 02:55 SESSION.NAME
> -rw-rw-r-- 1   52 Oct 15 02:55 lognekbmpi.txt
> -rw-rw-r-- 1 353M Oct 15 03:54 gdtI0.f00001
> -rw-rw-r-- 1 353M Oct 15 04:51 gdtI0.f00002
> -rw-rw-r-- 1 353M Oct 15 05:29 gdtI0.f00003
> -rw-rw-r-- 1 529M Oct 15 05:29 I0.f00001
> -rw-rw-r-- 1 353M Oct 15 06:07 gdtI0.f00004
> -rw-rw-r-- 1 529M Oct 15 06:07 I0.f00002
> -rw-rw-r-- 1 353M Oct 15 06:39 gdtI0.f00005
> -rw-rw-r-- 1 529M Oct 15 06:39 I0.f00003
> -rw-rw-r-- 1 353M Oct 15 08:23 gdtI0.f00006
> -rw-rw-r-- 1 529M Oct 15 08:23 I0.f00004
> -rw-rw-r-- 1 353M Oct 15 09:29 gdtI0.f00007
> -rw-rw-r-- 1 529M Oct 15 09:29 I0.f00005
> -rw-rw-r-- 1 353M Oct 15 10:11 gdtI0.f00008
> -rw-rw-r-- 1 529M Oct 15 10:12 I0.f00006
> -rw-rw-r-- 1 353M Oct 15 10:57 gdtI0.f00009
> -rw-rw-r-- 1 529M Oct 15 10:58 I0.f00007
> -rw-rw-r-- 1 353M Oct 15 11:49 gdtI0.f00010
> -rw-rw-r-- 1 353M Oct 15 12:41 gdtI0.f00011
> -rw-rw-r-- 1 353M Oct 15 13:12 gdtI0.f00012
> -rw-rw-r-- 1 353M Oct 15 13:48 gdtI0.f00013
> -rw-rw-r-- 1 353M Oct 15 14:28 gdtI0.f00014
> -rw-rw-r-- 1 353M Oct 15 15:01 gdtI0.f00015
> -rw-rw-r-- 1 353M Oct 15 16:34 gdtI0.f00016
> -rw-rw-r-- 1 353M Oct 15 18:18 gdtI0.f00017
> -rw-rw-r-- 1 353M Oct 15 21:07 gdtI0.f00018
> -rw-rw-r-- 1 353M Oct 15 21:13 gdtI0.f00019
> -rw-rw-r-- 1 353M Oct 15 21:19 gdtI0.f00020
> -rw-rw-r-- 1 529M Oct 15 21:19 I0.f00008
> -rw-rw-r-- 1 353M Oct 15 21:25 gdtI0.f00021
> -rw-rw-r-- 1 529M Oct 15 21:25 I0.f00009
> -rw-rw-r-- 1 353M Oct 15 21:31 gdtI0.f00022
> -rw-rw-r-- 1 529M Oct 15 21:31 I0.f00010
> -rw-rw-r-- 1 353M Oct 15 21:37 gdtI0.f00023
> -rw-rw-r-- 1 529M Oct 15 21:37 I0.f00011
> -rw-rw-r-- 1 353M Oct 15 21:43 gdtI0.f00024
> -rw-rw-r-- 1 529M Oct 15 21:43 I0.f00012
> -rw-rw-r-- 1 353M Oct 15 21:49 gdtI0.f00025
> -rw-rw-r-- 1 529M Oct 15 21:50 I0.f00013
> -rw-rw-r-- 1 353M Oct 15 21:56 gdtI0.f00026
> -rw-rw-r-- 1 529M Oct 15 21:56 I0.f00014
> -rw-rw-r-- 1 353M Oct 15 22:02 gdtI0.f00027
> -rw-rw-r-- 1 529M Oct 15 22:02 I0.f00015
> -rw-rw-r-- 1 353M Oct 15 22:08 gdtI0.f00028
> -rw-rw-r-- 1 529M Oct 15 22:08 I0.f00016
> -rw-rw-r-- 1 353M Oct 15 22:14 gdtI0.f00029
> -rw-rw-r-- 1 529M Oct 15 22:14 I0.f00017
> -rw-rw-r-- 1 353M Oct 15 22:20 gdtI0.f00030
> -rw-rw-r-- 1 529M Oct 15 22:20 I0.f00018
> -rw-rw-r-- 1 353M Oct 15 22:26 gdtI0.f00031
> -rw-rw-r-- 1 529M Oct 15 22:26 I0.f00019
> -rw-rw-r-- 1 353M Oct 15 22:32 gdtI0.f00032
> -rw-rw-r-- 1 529M Oct 15 22:32 I0.f00020
> -rw-rw-r-- 1 353M Oct 15 22:38 gdtI0.f00033
> -rw-rw-r-- 1 529M Oct 15 22:38 I0.f00021
> -rw-rw-r-- 1 353M Oct 15 22:44 gdtI0.f00034
> -rw-rw-r-- 1 529M Oct 15 22:44 I0.f00022
> -rw-rw-r-- 1 353M Oct 15 22:50 gdtI0.f00035
> -rw-rw-r-- 1 529M Oct 15 22:50 I0.f00023
> -rw-rw-r-- 1 353M Oct 15 22:56 gdtI0.f00036
> -rw-rw-r-- 1 529M Oct 15 22:56 I0.f00024
> -rw-rw-r-- 1 353M Oct 15 23:02 gdtI0.f00037
> -rw-rw-r-- 1 529M Oct 15 23:02 I0.f00025
> -rw-rw-r-- 1 353M Oct 15 23:08 gdtI0.f00038
> -rw-rw-r-- 1 353M Oct 15 23:14 gdtI0.f00039
> -rw-rw-r-- 1 353M Oct 15 23:20 gdtI0.f00040
> -rw-rw-r-- 1 353M Oct 15 23:26 gdtI0.f00041
> -rw-rw-r-- 1 353M Oct 15 23:32 gdtI0.f00042
> -rw-rw-r-- 1 353M Oct 15 23:38 gdtI0.f00043
> -rw-rw-r-- 1 353M Oct 15 23:44 gdtI0.f00044
> -rw-rw-r-- 1 353M Oct 15 23:50 gdtI0.f00045
> -rw-rw-r-- 1 353M Oct 15 23:56 gdtI0.f00046
> -rw-rw-r-- 1 353M Oct 16 00:01 gdtI0.f00047
> -rw-rw-r-- 1 353M Oct 16 00:07 gdtI0.f00048
> -rw-rw-r-- 1 353M Oct 16 00:13 gdtI0.f00049
> -rw-rw-r-- 1 353M Oct 16 00:19 gdtI0.f00050
> -rw-rw-r-- 1 353M Oct 16 00:25 gdtI0.f00051
> -rw-rw-r-- 1 353M Oct 16 00:31 gdtI0.f00052
> -rw-rw-r-- 1 353M Oct 16 00:37 gdtI0.f00053
> -rw-rw-r-- 1 353M Oct 16 00:43 gdtI0.f00054
> -rw-rw-r-- 1 353M Oct 16 00:49 gdtI0.f00055
> -rw-rw-r-- 1 353M Oct 16 00:55 gdtI0.f00056
> -rw-rw-r-- 1 353M Oct 16 01:01 gdtI0.f00057
> -rw-rw-r-- 1 353M Oct 16 01:07 gdtI0.f00058
> -rw-rw-r-- 1 353M Oct 16 01:13 gdtI0.f00059
> -rw-rw-r-- 1 353M Oct 16 01:19 gdtI0.f00060
> -rw-rw-r-- 1 353M Oct 16 01:25 gdtI0.f00061
> -rw-rw-r-- 1 353M Oct 16 01:31 gdtI0.f00062
> -rw-rw-r-- 1 353M Oct 16 01:36 gdtI0.f00063
> -rw-rw-r-- 1 353M Oct 16 01:42 gdtI0.f00064
> -rw-rw-r-- 1 353M Oct 16 01:48 gdtI0.f00065
> -rw-rw-r-- 1 353M Oct 16 01:54 gdtI0.f00066
> -rw-rw-r-- 1 353M Oct 16 02:00 gdtI0.f00067
> -rw-rw-r-- 1 353M Oct 16 02:06 gdtI0.f00068
> -rw-rw-r-- 1 353M Oct 16 02:12 gdtI0.f00069
> -rw-rw-r-- 1 353M Oct 16 02:18 gdtI0.f00070
> -rw-rw-r-- 1 353M Oct 16 02:24 gdtI0.f00071
> -rw-rw-r-- 1 353M Oct 16 02:30 gdtI0.f00072
> -rw-rw-r-- 1 353M Oct 16 02:36 gdtI0.f00073
> -rw-rw-r-- 1 353M Oct 16 02:42 gdtI0.f00074
> -rw-rw-r-- 1 353M Oct 16 02:48 gdtI0.f00075
> -rw-rw-r-- 1 353M Oct 16 02:54 gdtI0.f00076
> -rw-rw-r-- 1 353M Oct 16 03:00 gdtI0.f00077
> -rw-rw-r-- 1 353M Oct 16 03:06 gdtI0.f00078
> -rw-rw-r-- 1 529M Oct 16 03:06 I0.f00026
> -rw-rw-r-- 1 353M Oct 16 03:12 gdtI0.f00079
> -rw-rw-r-- 1 529M Oct 16 03:12 I0.f00027
> -rw-rw-r-- 1 353M Oct 16 03:18 gdtI0.f00080
> -rw-rw-r-- 1 529M Oct 16 03:18 I0.f00028
> -rw-rw-r-- 1 353M Oct 16 03:24 gdtI0.f00081
> -rw-rw-r-- 1 529M Oct 16 03:25 I0.f00029
> -rw-rw-r-- 1 353M Oct 16 03:31 gdtI0.f00082
> -rw-rw-r-- 1 529M Oct 16 03:31 I0.f00030
> -rw-rw-r-- 1 353M Oct 16 03:37 gdtI0.f00083
> -rw-rw-r-- 1 529M Oct 16 03:37 I0.f00031
> -rw-rw-r-- 1 353M Oct 16 03:43 gdtI0.f00084
> -rw-rw-r-- 1 529M Oct 16 03:44 I0.f00032
> -rw-rw-r-- 1 353M Oct 16 03:50 gdtI0.f00085
> -rw-rw-r-- 1 529M Oct 16 03:50 I0.f00033
> -rw-rw-r-- 1 353M Oct 16 03:56 gdtI0.f00086
> -rw-rw-r-- 1 529M Oct 16 03:56 I0.f00034
> -rw-rw-r-- 1 353M Oct 16 04:02 gdtI0.f00087
> -rw-rw-r-- 1 529M Oct 16 04:02 I0.f00035
> -rw-rw-r-- 1 353M Oct 16 04:08 gdtI0.f00088
> -rw-rw-r-- 1 529M Oct 16 04:08 I0.f00036
> -rw-rw-r-- 1 353M Oct 16 04:14 gdtI0.f00089
> -rw-rw-r-- 1 529M Oct 16 04:14 I0.f00037
> -rw-rw-r-- 1 353M Oct 16 04:20 gdtI0.f00090
> -rw-rw-r-- 1 529M Oct 16 04:21 I0.f00038
> -rw-rw-r-- 1 353M Oct 16 04:27 gdtI0.f00091
> -rw-rw-r-- 1 529M Oct 16 04:27 I0.f00039
> -rw-rw-r-- 1 353M Oct 16 04:33 gdtI0.f00092
> -rw-rw-r-- 1 529M Oct 16 04:33 I0.f00040
> -rw-rw-r-- 1 353M Oct 16 04:39 gdtI0.f00093
> -rw-rw-r-- 1 529M Oct 16 04:39 I0.f00041
> -rw-rw-r-- 1 353M Oct 16 04:45 gdtI0.f00094
> -rw-rw-r-- 1 529M Oct 16 04:45 I0.f00042
> -rw-rw-r-- 1 353M Oct 16 04:51 gdtI0.f00095
> -rw-rw-r-- 1 529M Oct 16 04:52 I0.f00043
> -rw-rw-r-- 1 353M Oct 16 04:58 gdtI0.f00096
> -rw-rw-r-- 1 529M Oct 16 04:58 I0.f00044
> -rw-rw-r-- 1 353M Oct 16 05:04 gdtI0.f00097
> -rw-rw-r-- 1 529M Oct 16 05:04 I0.f00045
> -rw-rw-r-- 1 353M Oct 16 05:10 gdtI0.f00098
> -rw-rw-r-- 1 529M Oct 16 05:11 I0.f00046
> -rw-rw-r-- 1 353M Oct 16 05:17 gdtI0.f00099
> -rw-rw-r-- 1 529M Oct 16 05:17 I0.f00047
> -rw-rw-r-- 1 353M Oct 16 05:23 gdtI0.f00100
> -rw-rw-r-- 1 529M Oct 16 05:23 I0.f00048
> -rw-rw-r-- 1 353M Oct 16 05:29 gdtI0.f00101
> -rw-rw-r-- 1 529M Oct 16 05:29 I0.f00049
> -rw-rw-r-- 1 353M Oct 16 05:35 gdtI0.f00102
> -rw-rw-r-- 1 529M Oct 16 05:35 I0.f00050
> -rw-rw-r-- 1 353M Oct 16 05:41 gdtI0.f00103
> -rw-rw-r-- 1 529M Oct 16 05:41 I0.f00051
> -rw-rw-r-- 1 353M Oct 16 05:47 gdtI0.f00104
> -rw-rw-r-- 1 529M Oct 16 05:48 I0.f00052
> -rw-rw-r-- 1 353M Oct 16 05:54 gdtI0.f00105
> -rw-rw-r-- 1 529M Oct 16 05:54 I0.f00053
> -rw-rw-r-- 1 353M Oct 16 06:00 gdtI0.f00106
> -rw-rw-r-- 1 529M Oct 16 06:00 I0.f00054
> -rw-rw-r-- 1 353M Oct 16 06:06 gdtI0.f00107
> -rw-rw-r-- 1 529M Oct 16 06:06 I0.f00055
> -rw-rw-r-- 1 353M Oct 16 06:12 gdtI0.f00108
> -rw-rw-r-- 1 529M Oct 16 06:13 I0.f00056
> -rw-rw-r-- 1 353M Oct 16 06:18 gdtI0.f00109
> -rw-rw-r-- 1 529M Oct 16 06:19 I0.f00057
> -rw-rw-r-- 1 353M Oct 16 06:24 gdtI0.f00110
> -rw-rw-r-- 1 529M Oct 16 06:25 I0.f00058
> -rw-rw-r-- 1 353M Oct 16 06:31 gdtI0.f00111
> -rw-rw-r-- 1 529M Oct 16 06:31 I0.f00059
> -rw-rw-r-- 1 353M Oct 16 06:37 gdtI0.f00112
> -rw-rw-r-- 1 529M Oct 16 06:37 I0.f00060
> -rw-rw-r-- 1 353M Oct 16 06:43 gdtI0.f00113
> -rw-rw-r-- 1 529M Oct 16 06:44 I0.f00061
> -rw-rw-r-- 1 353M Oct 16 06:50 gdtI0.f00114
> -rw-rw-r-- 1 529M Oct 16 06:50 I0.f00062
> -rw-rw-r-- 1 353M Oct 16 06:56 gdtI0.f00115
> -rw-rw-r-- 1 529M Oct 16 06:56 I0.f00063
> -rw-rw-r-- 1 353M Oct 16 07:02 gdtI0.f00116
> -rw-rw-r-- 1 529M Oct 16 07:02 I0.f00064
> -rw-rw-r-- 1 353M Oct 16 07:08 gdtI0.f00117
> -rw-rw-r-- 1 529M Oct 16 07:08 I0.f00065
> -rw-rw-r-- 1 353M Oct 16 07:14 gdtI0.f00118
> -rw-rw-r-- 1 529M Oct 16 07:14 I0.f00066
> -rw-rw-r-- 1 353M Oct 16 07:20 gdtI0.f00119
> -rw-rw-r-- 1 529M Oct 16 07:20 I0.f00067
> -rw-rw-r-- 1 353M Oct 16 07:26 gdtI0.f00120
> -rw-rw-r-- 1 529M Oct 16 07:26 I0.f00068
> -rw-rw-r-- 1 353M Oct 16 07:32 gdtI0.f00121
> -rw-rw-r-- 1 529M Oct 16 07:32 I0.f00069
> -rw-rw-r-- 1 353M Oct 16 07:38 gdtI0.f00122
> -rw-rw-r-- 1 529M Oct 16 07:38 I0.f00070
> -rw-rw-r-- 1 353M Oct 16 07:44 gdtI0.f00123
> -rw-rw-r-- 1 529M Oct 16 07:44 I0.f00071
> -rw-rw-r-- 1 353M Oct 16 07:50 gdtI0.f00124
> -rw-rw-r-- 1 529M Oct 16 07:50 I0.f00072
> -rw-rw-r-- 1 353M Oct 16 07:56 gdtI0.f00125
> -rw-rw-r-- 1 529M Oct 16 07:56 I0.f00073
> -rw-rw-r-- 1 353M Oct 16 08:02 gdtI0.f00126
> -rw-rw-r-- 1 529M Oct 16 08:02 I0.f00074
> -rw-rw-r-- 1 353M Oct 16 08:08 gdtI0.f00127
> -rw-rw-r-- 1 529M Oct 16 08:08 I0.f00075
> -rw-rw-r-- 1 353M Oct 16 08:14 gdtI0.f00128
> -rw-rw-r-- 1 529M Oct 16 08:14 I0.f00076
> -rw-rw-r-- 1 353M Oct 16 08:20 gdtI0.f00129
> -rw-rw-r-- 1 529M Oct 16 08:21 I0.f00077
> -rw-rw-r-- 1 353M Oct 16 08:26 gdtI0.f00130
> -rw-rw-r-- 1 529M Oct 16 08:27 I0.f00078
> -rw-rw-r-- 1 353M Oct 16 08:32 gdtI0.f00131
> -rw-rw-r-- 1 529M Oct 16 08:33 I0.f00079
> -rw-rw-r-- 1 353M Oct 16 08:39 gdtI0.f00132
> -rw-rw-r-- 1 529M Oct 16 08:39 I0.f00080
> -rw-rw-r-- 1 353M Oct 16 08:45 gdtI0.f00133
> -rw-rw-r-- 1 529M Oct 16 08:45 I0.f00081
> -rw-rw-r-- 1 353M Oct 16 08:51 gdtI0.f00134
> -rw-rw-r-- 1 529M Oct 16 08:51 I0.f00082
> -rw-rw-r-- 1 353M Oct 16 08:57 gdtI0.f00135
> -rw-rw-r-- 1 529M Oct 16 08:57 I0.f00083
> -rw-rw-r-- 1 353M Oct 16 09:03 gdtI0.f00136
> -rw-rw-r-- 1 529M Oct 16 09:03 I0.f00084
> -rw-rw-r-- 1 353M Oct 16 09:09 gdtI0.f00137
> -rw-rw-r-- 1 529M Oct 16 09:09 I0.f00085
> -rw-rw-r-- 1 353M Oct 16 09:15 gdtI0.f00138
> -rw-rw-r-- 1 529M Oct 16 09:15 I0.f00086
> -rw-rw-r-- 1 353M Oct 16 09:21 gdtI0.f00139
> -rw-rw-r-- 1 529M Oct 16 09:22 I0.f00087
> -rw-rw-r-- 1 353M Oct 16 09:27 gdtI0.f00140
> -rw-rw-r-- 1 529M Oct 16 09:28 I0.f00088
> -rw-rw-r-- 1 353M Oct 16 09:33 gdtI0.f00141
> -rw-rw-r-- 1 529M Oct 16 09:34 I0.f00089
> -rw-rw-r-- 1 353M Oct 16 09:40 gdtI0.f00142
> -rw-rw-r-- 1 529M Oct 16 09:40 I0.f00090
> -rw-rw-r-- 1 353M Oct 16 09:46 gdtI0.f00143
> -rw-rw-r-- 1 529M Oct 16 09:46 I0.f00091
> -rw-rw-r-- 1 353M Oct 16 09:52 gdtI0.f00144
> -rw-rw-r-- 1 529M Oct 16 09:52 I0.f00092
> -rw-rw-r-- 1 353M Oct 16 09:57 gdtI0.f00145
> -rw-rw-r-- 1 529M Oct 16 09:58 I0.f00093
> -rw-rw-r-- 1 353M Oct 16 10:03 gdtI0.f00146
> -rw-rw-r-- 1 529M Oct 16 10:04 I0.f00094
> -rw-rw-r-- 1 353M Oct 16 10:09 gdtI0.f00147
> -rw-rw-r-- 1 529M Oct 16 10:10 I0.f00095
> -rw-rw-r-- 1 353M Oct 16 10:15 gdtI0.f00148
> -rw-rw-r-- 1 529M Oct 16 10:16 I0.f00096
> -rw-rw-r-- 1 353M Oct 16 10:21 gdtI0.f00149
> -rw-rw-r-- 1 529M Oct 16 10:22 I0.f00097
> -rw-rw-r-- 1 353M Oct 16 10:27 gdtI0.f00150
> -rw-rw-r-- 1 529M Oct 16 10:28 I0.f00098
> -rw-rw-r-- 1 353M Oct 16 10:33 gdtI0.f00151
> -rw-rw-r-- 1 529M Oct 16 10:34 I0.f00099
> -rw-rw-r-- 1 353M Oct 16 10:39 gdtI0.f00152
> -rw-rw-r-- 1 529M Oct 16 10:40 I0.f00100
> -rw-rw-r-- 1 353M Oct 16 10:46 gdtI0.f00153
> -rw-rw-r-- 1 353M Oct 16 10:52 gdtI0.f00154
> -rw-rw-r-- 1 353M Oct 16 10:57 gdtI0.f00155
> -rw-rw-r-- 1 353M Oct 16 11:03 gdtI0.f00156
> -rw-rw-r-- 1 353M Oct 16 11:09 gdtI0.f00157
> -rw-rw-r-- 1 353M Oct 16 11:15 gdtI0.f00158
> -rw-rw-r-- 1 353M Oct 16 11:21 gdtI0.f00159
> -rw-rw-r-- 1 353M Oct 16 11:27 gdtI0.f00160
> -rw-rw-r-- 1 353M Oct 16 11:33 gdtI0.f00161
> -rw-rw-r-- 1 353M Oct 16 11:39 gdtI0.f00162
> -rw-rw-r-- 1 353M Oct 16 11:45 gdtI0.f00163
> -rw-rw-r-- 1 353M Oct 16 11:51 gdtI0.f00164
> -rw-rw-r-- 1 353M Oct 16 11:57 gdtI0.f00165
> -rw-rw-r-- 1 353M Oct 16 12:03 gdtI0.f00166
> -rw-rw-r-- 1 353M Oct 16 12:09 gdtI0.f00167
> -rw-rw-r-- 1 353M Oct 16 12:15 gdtI0.f00168
> -rw-rw-r-- 1 353M Oct 16 12:21 gdtI0.f00169
> -rw-rw-r-- 1 353M Oct 16 12:27 gdtI0.f00170
> -rw-rw-r-- 1 353M Oct 16 12:33 gdtI0.f00171
> -rw-rw-r-- 1 353M Oct 16 12:39 gdtI0.f00172
> -rw-rw-r-- 1 353M Oct 16 12:45 gdtI0.f00173
> -rw-rw-r-- 1 353M Oct 16 12:51 gdtI0.f00174
> -rw-rw-r-- 1 353M Oct 16 12:57 gdtI0.f00175
> -rw-rw-r-- 1 353M Oct 16 13:03 gdtI0.f00176
> -rw-rw-r-- 1 353M Oct 16 13:09 gdtI0.f00177
> -rw-rw-r-- 1 353M Oct 16 13:15 gdtI0.f00178
> -rw-rw-r-- 1 353M Oct 16 13:21 gdtI0.f00179
> -rw-rw-r-- 1 353M Oct 16 13:27 gdtI0.f00180
> -rw-rw-r-- 1 353M Oct 16 13:33 gdtI0.f00181
> -rw-rw-r-- 1 353M Oct 16 13:39 gdtI0.f00182
> -rw-rw-r-- 1 353M Oct 16 13:45 gdtI0.f00183
> -rw-rw-r-- 1 353M Oct 16 13:51 gdtI0.f00184
> -rw-rw-r-- 1 353M Oct 16 13:57 gdtI0.f00185
> -rw-rw-r-- 1 353M Oct 16 14:03 gdtI0.f00186
> -rw-rw-r-- 1 353M Oct 16 14:09 gdtI0.f00187
> -rw-rw-r-- 1 353M Oct 16 14:15 gdtI0.f00188
> -rw-rw-r-- 1 353M Oct 16 14:21 gdtI0.f00189
> -rw-rw-r-- 1 353M Oct 16 14:27 gdtI0.f00190
> -rw-rw-r-- 1 353M Oct 16 14:33 gdtI0.f00191
> -rw-rw-r-- 1 353M Oct 16 14:39 gdtI0.f00192
> -rw-rw-r-- 1 353M Oct 16 15:42 gdtI0.f00193
> -rw-rw-r-- 1 353M Oct 16 16:34 gdtI0.f00194
> -rw-rw-r-- 1 353M Oct 16 17:34 gdtI0.f00195
> -rw-rw-r-- 1 353M Oct 16 18:32 gdtI0.f00196
> -rw-rw-r-- 1 353M Oct 16 18:52 gdtI0.f00197
> -rw-rw-r-- 1 353M Oct 16 18:58 gdtI0.f00198
> -rw-rw-r-- 1 353M Oct 16 19:04 gdtI0.f00199
> -rw-rw-r-- 1 353M Oct 16 19:10 gdtI0.f00200
> -rw-rw-r-- 1 353M Oct 16 19:16 gdtI0.f00201
> -rw-rw-r-- 1 353M Oct 16 19:22 gdtI0.f00202
> -rw-rw-r-- 1 353M Oct 16 19:28 gdtI0.f00203
> -rw-rw-r-- 1 353M Oct 16 19:34 gdtI0.f00204
> -rw-rw-r-- 1 353M Oct 16 19:40 gdtI0.f00205
> -rw-rw-r-- 1 353M Oct 16 19:46 gdtI0.f00206
> -rw-rw-r-- 1 353M Oct 16 19:52 gdtI0.f00207
> -rw-rw-r-- 1 353M Oct 16 19:58 gdtI0.f00208
> -rw-rw-r-- 1 353M Oct 16 20:04 gdtI0.f00209
> -rw-rw-r-- 1 353M Oct 16 20:10 gdtI0.f00210
> -rw-rw-r-- 1 353M Oct 16 20:16 gdtI0.f00211
> -rw-rw-r-- 1 353M Oct 16 20:22 gdtI0.f00212
> -rw-rw-r-- 1 353M Oct 16 20:28 gdtI0.f00213
> -rw-rw-r-- 1 353M Oct 16 20:34 gdtI0.f00214
> -rw-rw-r-- 1 353M Oct 16 20:40 gdtI0.f00215
> -rw-rw-r-- 1 353M Oct 16 20:46 gdtI0.f00216
> -rw-rw-r-- 1 353M Oct 16 20:52 gdtI0.f00217
> -rw-rw-r-- 1 353M Oct 16 20:58 gdtI0.f00218
> -rw-rw-r-- 1 353M Oct 16 21:04 gdtI0.f00219
> -rw-rw-r-- 1 353M Oct 16 21:10 gdtI0.f00220
> -rw-rw-r-- 1 353M Oct 16 21:16 gdtI0.f00221
> -rw-rw-r-- 1 353M Oct 16 21:22 gdtI0.f00222
> -rw-rw-r-- 1 353M Oct 16 21:28 gdtI0.f00223
> -rw-rw-r-- 1 353M Oct 16 21:34 gdtI0.f00224
> -rw-rw-r-- 1 353M Oct 16 21:40 gdtI0.f00225
> -rw-rw-r-- 1 353M Oct 16 21:46 gdtI0.f00226
> -rw-rw-r-- 1 353M Oct 16 21:52 gdtI0.f00227
> -rw-rw-r-- 1 353M Oct 16 21:58 gdtI0.f00228
> -rw-rw-r-- 1 353M Oct 16 22:04 gdtI0.f00229
> -rw-rw-r-- 1 353M Oct 16 22:10 gdtI0.f00230
> -rw-rw-r-- 1 353M Oct 16 22:16 gdtI0.f00231
> -rw-rw-r-- 1 353M Oct 16 22:22 gdtI0.f00232
> -rw-rw-r-- 1 353M Oct 16 22:28 gdtI0.f00233
> -rw-rw-r-- 1 353M Oct 16 22:34 gdtI0.f00234
> -rw-rw-r-- 1 353M Oct 16 22:40 gdtI0.f00235
> -rw-rw-r-- 1 353M Oct 16 22:46 gdtI0.f00236
> -rw-rw-r-- 1 353M Oct 16 22:52 gdtI0.f00237
> -rw-rw-r-- 1 353M Oct 16 22:58 gdtI0.f00238
> -rw-rw-r-- 1 353M Oct 16 23:04 gdtI0.f00239
> -rw-rw-r-- 1 353M Oct 16 23:10 gdtI0.f00240
> -rw-rw-r-- 1 353M Oct 16 23:16 gdtI0.f00241
> -rw-rw-r-- 1 353M Oct 16 23:22 gdtI0.f00242
> -rw-rw-r-- 1 353M Oct 16 23:28 gdtI0.f00243
> -rw-rw-r-- 1 353M Oct 16 23:34 gdtI0.f00244
> -rw-rw-r-- 1 353M Oct 16 23:40 gdtI0.f00245
> -rw-rw-r-- 1 353M Oct 16 23:46 gdtI0.f00246
> -rw-rw-r-- 1 353M Oct 16 23:52 gdtI0.f00247
> -rw-rw-r-- 1 353M Oct 16 23:58 gdtI0.f00248
> -rw-rw-r-- 1 353M Oct 17 00:04 gdtI0.f00249
> -rw-rw-r-- 1 353M Oct 17 00:10 gdtI0.f00250
> -rw-rw-r-- 1 353M Oct 17 00:16 gdtI0.f00251
> -rw-rw-r-- 1 353M Oct 17 00:22 gdtI0.f00252
> -rw-rw-r-- 1 353M Oct 17 00:28 gdtI0.f00253
> -rw-rw-r-- 1 353M Oct 17 00:34 gdtI0.f00254
> -rw-rw-r-- 1 353M Oct 17 00:40 gdtI0.f00255
> -rw-rw-r-- 1 353M Oct 17 00:46 gdtI0.f00256
> -rw-rw-r-- 1 353M Oct 17 00:52 gdtI0.f00257
> -rw-rw-r-- 1 353M Oct 17 00:58 gdtI0.f00258
> -rw-rw-r-- 1 353M Oct 17 01:04 gdtI0.f00259
> -rw-rw-r-- 1 353M Oct 17 01:10 gdtI0.f00260
> -rw-rw-r-- 1 353M Oct 17 01:16 gdtI0.f00261
> -rw-rw-r-- 1 353M Oct 17 01:22 gdtI0.f00262
> -rw-rw-r-- 1 353M Oct 17 01:28 gdtI0.f00263
> -rw-rw-r-- 1 353M Oct 17 01:34 gdtI0.f00264
> -rw-rw-r-- 1 353M Oct 17 01:40 gdtI0.f00265
> -rw-rw-r-- 1 353M Oct 17 01:46 gdtI0.f00266
> -rw-rw-r-- 1 353M Oct 17 01:52 gdtI0.f00267
> -rw-rw-r-- 1 353M Oct 17 01:58 gdtI0.f00268
> -rw-rw-r-- 1 353M Oct 17 02:04 gdtI0.f00269
> -rw-rw-r-- 1 353M Oct 17 02:10 gdtI0.f00270
> -rw-rw-r-- 1 353M Oct 17 02:16 gdtI0.f00271
> -rw-rw-r-- 1 353M Oct 17 02:22 gdtI0.f00272
> -rw-rw-r-- 1 353M Oct 17 02:28 gdtI0.f00273
> -rw-rw-r-- 1 353M Oct 17 02:34 gdtI0.f00274
> -rw-rw-r-- 1 353M Oct 17 02:40 gdtI0.f00275
> -rw-rw-r-- 1 353M Oct 17 02:46 gdtI0.f00276
> -rw-rw-r-- 1 353M Oct 17 02:52 gdtI0.f00277
> -rw-rw-r-- 1 353M Oct 17 02:58 gdtI0.f00278
> -rw-rw-r-- 1 353M Oct 17 03:04 gdtI0.f00279
> -rw-rw-r-- 1 353M Oct 17 03:10 gdtI0.f00280
> -rw-rw-r-- 1 353M Oct 17 03:16 gdtI0.f00281
> -rw-rw-r-- 1 353M Oct 17 03:22 gdtI0.f00282
> -rw-rw-r-- 1 353M Oct 17 03:28 gdtI0.f00283
> -rw-rw-r-- 1 353M Oct 17 03:34 gdtI0.f00284
> -rw-rw-r-- 1 353M Oct 17 03:40 gdtI0.f00285
> -rw-rw-r-- 1 353M Oct 17 03:46 gdtI0.f00286
> -rw-rw-r-- 1 353M Oct 17 03:52 gdtI0.f00287
> -rw-rw-r-- 1 353M Oct 17 03:58 gdtI0.f00288
> -rw-rw-r-- 1 353M Oct 17 04:04 gdtI0.f00289
> -rw-rw-r-- 1 353M Oct 17 04:10 gdtI0.f00290
> -rw-rw-r-- 1 353M Oct 17 04:16 gdtI0.f00291
> -rw-rw-r-- 1 353M Oct 17 04:22 gdtI0.f00292
> -rw-rw-r-- 1 353M Oct 17 04:28 gdtI0.f00293
> -rw-rw-r-- 1 353M Oct 17 04:34 gdtI0.f00294
> -rw-rw-r-- 1 353M Oct 17 04:40 gdtI0.f00295
> -rw-rw-r-- 1 353M Oct 17 04:46 gdtI0.f00296
> -rw-rw-r-- 1 353M Oct 17 04:52 gdtI0.f00297
> -rw-rw-r-- 1 353M Oct 17 04:58 gdtI0.f00298
> -rw-rw-r-- 1 353M Oct 17 05:04 gdtI0.f00299
> -rw-rw-r-- 1 353M Oct 17 05:10 gdtI0.f00300
> -rw-rw-r-- 1 353M Oct 17 05:16 gdtI0.f00301
> -rw-rw-r-- 1 353M Oct 17 05:22 gdtI0.f00302
> -rw-rw-r-- 1 353M Oct 17 05:28 gdtI0.f00303
> -rw-rw-r-- 1 353M Oct 17 05:34 gdtI0.f00304
> -rw-rw-r-- 1 353M Oct 17 05:40 gdtI0.f00305
> -rw-rw-r-- 1 353M Oct 17 05:46 gdtI0.f00306
> -rw-rw-r-- 1 353M Oct 17 05:52 gdtI0.f00307
> -rw-rw-r-- 1 353M Oct 17 05:58 gdtI0.f00308
> -rw-rw-r-- 1 353M Oct 17 06:04 gdtI0.f00309
> -rw-rw-r-- 1 353M Oct 17 06:10 gdtI0.f00310
> -rw-rw-r-- 1 353M Oct 17 06:16 gdtI0.f00311
> -rw-rw-r-- 1 353M Oct 17 06:22 gdtI0.f00312
> -rw-rw-r-- 1 353M Oct 17 06:28 gdtI0.f00313
> -rw-rw-r-- 1 353M Oct 17 06:34 gdtI0.f00314
> -rw-rw-r-- 1 353M Oct 17 06:40 gdtI0.f00315
> -rw-rw-r-- 1 353M Oct 17 06:46 gdtI0.f00316
> -rw-rw-r-- 1 377M Oct 17 06:52 hpts.out
> -rw-rw-r-- 1 353M Oct 17 06:52 gdtI0.f00317
> -rw-rw-r-- 1 190M Oct 17 06:56 slurm-1134244.out
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151027/5c95700f/attachment-0001.html>
