[Nek5000-users] output through .rea and through usrchk
Tue Oct 27 07:23:13 CDT 2015
There is an issue that you don't know for certain the sign of param(12)... so I would check
to be sure to clean up your integer il_hptsout.
To me, however, it's not clear that that issue alone would be causing the problem.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, October 27, 2015 6:33 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] output through .rea and through usrchk
Dear neks,
Strange thing happend to a simulation where
I made "standart" output through .rea file,
i.e.
 -0.010000E-01 p012 DT
   0.00000     p013 IOCOMM
   0.50000     p014 IOTIME
and at the same time I need scalar gradients, so I've put to usrchk:
      il_hptsout=-0.5/param(12)
      if ((istep.gt.0).and.(mod(istep,il_hptsout).eq.0)) then
      call gradm1(dtdx,dtdy,dtdz,t)
      call outpost(dtdx,dtdy,dtdz,pr,t,'gdt')
      endif
The strange thing that gdt*  (from usrchk) files are saved as should should be,
but "standart" CASE0.f*  were saved onli partially, below is 'ls -rt' of the case directory.
Why whould that happen? may it be cluster issue? (file sizes are not small ~530mb)
-rw-rw-r-- 1  35K Oct 15 02:52 compiler.out
-rw-rw-r-- 1   99 Oct 15 02:55 SESSION.NAME<http://SESSION.NAME>
-rw-rw-r-- 1   52 Oct 15 02:55 lognekbmpi.txt
-rw-rw-r-- 1 353M Oct 15 03:54 gdtI0.f00001
-rw-rw-r-- 1 353M Oct 15 04:51 gdtI0.f00002
-rw-rw-r-- 1 353M Oct 15 05:29 gdtI0.f00003
-rw-rw-r-- 1 529M Oct 15 05:29 I0.f00001
-rw-rw-r-- 1 353M Oct 15 06:07 gdtI0.f00004
-rw-rw-r-- 1 529M Oct 15 06:07 I0.f00002
-rw-rw-r-- 1 353M Oct 15 06:39 gdtI0.f00005
-rw-rw-r-- 1 529M Oct 15 06:39 I0.f00003
-rw-rw-r-- 1 353M Oct 15 08:23 gdtI0.f00006
-rw-rw-r-- 1 529M Oct 15 08:23 I0.f00004
-rw-rw-r-- 1 353M Oct 15 09:29 gdtI0.f00007
-rw-rw-r-- 1 529M Oct 15 09:29 I0.f00005
-rw-rw-r-- 1 353M Oct 15 10:11 gdtI0.f00008
-rw-rw-r-- 1 529M Oct 15 10:12 I0.f00006
-rw-rw-r-- 1 353M Oct 15 10:57 gdtI0.f00009
-rw-rw-r-- 1 529M Oct 15 10:58 I0.f00007
-rw-rw-r-- 1 353M Oct 15 11:49 gdtI0.f00010
-rw-rw-r-- 1 353M Oct 15 12:41 gdtI0.f00011
-rw-rw-r-- 1 353M Oct 15 13:12 gdtI0.f00012
-rw-rw-r-- 1 353M Oct 15 13:48 gdtI0.f00013
-rw-rw-r-- 1 353M Oct 15 14:28 gdtI0.f00014
-rw-rw-r-- 1 353M Oct 15 15:01 gdtI0.f00015
-rw-rw-r-- 1 353M Oct 15 16:34 gdtI0.f00016
-rw-rw-r-- 1 353M Oct 15 18:18 gdtI0.f00017
-rw-rw-r-- 1 353M Oct 15 21:07 gdtI0.f00018
-rw-rw-r-- 1 353M Oct 15 21:13 gdtI0.f00019
-rw-rw-r-- 1 353M Oct 15 21:19 gdtI0.f00020
-rw-rw-r-- 1 529M Oct 15 21:19 I0.f00008
-rw-rw-r-- 1 353M Oct 15 21:25 gdtI0.f00021
-rw-rw-r-- 1 529M Oct 15 21:25 I0.f00009
-rw-rw-r-- 1 353M Oct 15 21:31 gdtI0.f00022
-rw-rw-r-- 1 529M Oct 15 21:31 I0.f00010
-rw-rw-r-- 1 353M Oct 15 21:37 gdtI0.f00023
-rw-rw-r-- 1 529M Oct 15 21:37 I0.f00011
-rw-rw-r-- 1 353M Oct 15 21:43 gdtI0.f00024
-rw-rw-r-- 1 529M Oct 15 21:43 I0.f00012
-rw-rw-r-- 1 353M Oct 15 21:49 gdtI0.f00025
-rw-rw-r-- 1 529M Oct 15 21:50 I0.f00013
-rw-rw-r-- 1 353M Oct 15 21:56 gdtI0.f00026
-rw-rw-r-- 1 529M Oct 15 21:56 I0.f00014
-rw-rw-r-- 1 353M Oct 15 22:02 gdtI0.f00027
-rw-rw-r-- 1 529M Oct 15 22:02 I0.f00015
-rw-rw-r-- 1 353M Oct 15 22:08 gdtI0.f00028
-rw-rw-r-- 1 529M Oct 15 22:08 I0.f00016
-rw-rw-r-- 1 353M Oct 15 22:14 gdtI0.f00029
-rw-rw-r-- 1 529M Oct 15 22:14 I0.f00017
-rw-rw-r-- 1 353M Oct 15 22:20 gdtI0.f00030
-rw-rw-r-- 1 529M Oct 15 22:20 I0.f00018
-rw-rw-r-- 1 353M Oct 15 22:26 gdtI0.f00031
-rw-rw-r-- 1 529M Oct 15 22:26 I0.f00019
-rw-rw-r-- 1 353M Oct 15 22:32 gdtI0.f00032
-rw-rw-r-- 1 529M Oct 15 22:32 I0.f00020
-rw-rw-r-- 1 353M Oct 15 22:38 gdtI0.f00033
-rw-rw-r-- 1 529M Oct 15 22:38 I0.f00021
-rw-rw-r-- 1 353M Oct 15 22:44 gdtI0.f00034
-rw-rw-r-- 1 529M Oct 15 22:44 I0.f00022
-rw-rw-r-- 1 353M Oct 15 22:50 gdtI0.f00035
-rw-rw-r-- 1 529M Oct 15 22:50 I0.f00023
-rw-rw-r-- 1 353M Oct 15 22:56 gdtI0.f00036
-rw-rw-r-- 1 529M Oct 15 22:56 I0.f00024
-rw-rw-r-- 1 353M Oct 15 23:02 gdtI0.f00037
-rw-rw-r-- 1 529M Oct 15 23:02 I0.f00025
-rw-rw-r-- 1 353M Oct 15 23:08 gdtI0.f00038
-rw-rw-r-- 1 353M Oct 15 23:14 gdtI0.f00039
-rw-rw-r-- 1 353M Oct 15 23:20 gdtI0.f00040
-rw-rw-r-- 1 353M Oct 15 23:26 gdtI0.f00041
-rw-rw-r-- 1 353M Oct 15 23:32 gdtI0.f00042
-rw-rw-r-- 1 353M Oct 15 23:38 gdtI0.f00043
-rw-rw-r-- 1 353M Oct 15 23:44 gdtI0.f00044
-rw-rw-r-- 1 353M Oct 15 23:50 gdtI0.f00045
-rw-rw-r-- 1 353M Oct 15 23:56 gdtI0.f00046
-rw-rw-r-- 1 353M Oct 16 00:01 gdtI0.f00047
-rw-rw-r-- 1 353M Oct 16 00:07 gdtI0.f00048
-rw-rw-r-- 1 353M Oct 16 00:13 gdtI0.f00049
-rw-rw-r-- 1 353M Oct 16 00:19 gdtI0.f00050
-rw-rw-r-- 1 353M Oct 16 00:25 gdtI0.f00051
-rw-rw-r-- 1 353M Oct 16 00:31 gdtI0.f00052
-rw-rw-r-- 1 353M Oct 16 00:37 gdtI0.f00053
-rw-rw-r-- 1 353M Oct 16 00:43 gdtI0.f00054
-rw-rw-r-- 1 353M Oct 16 00:49 gdtI0.f00055
-rw-rw-r-- 1 353M Oct 16 00:55 gdtI0.f00056
-rw-rw-r-- 1 353M Oct 16 01:01 gdtI0.f00057
-rw-rw-r-- 1 353M Oct 16 01:07 gdtI0.f00058
-rw-rw-r-- 1 353M Oct 16 01:13 gdtI0.f00059
-rw-rw-r-- 1 353M Oct 16 01:19 gdtI0.f00060
-rw-rw-r-- 1 353M Oct 16 01:25 gdtI0.f00061
-rw-rw-r-- 1 353M Oct 16 01:31 gdtI0.f00062
-rw-rw-r-- 1 353M Oct 16 01:36 gdtI0.f00063
-rw-rw-r-- 1 353M Oct 16 01:42 gdtI0.f00064
-rw-rw-r-- 1 353M Oct 16 01:48 gdtI0.f00065
-rw-rw-r-- 1 353M Oct 16 01:54 gdtI0.f00066
-rw-rw-r-- 1 353M Oct 16 02:00 gdtI0.f00067
-rw-rw-r-- 1 353M Oct 16 02:06 gdtI0.f00068
-rw-rw-r-- 1 353M Oct 16 02:12 gdtI0.f00069
-rw-rw-r-- 1 353M Oct 16 02:18 gdtI0.f00070
-rw-rw-r-- 1 353M Oct 16 02:24 gdtI0.f00071
-rw-rw-r-- 1 353M Oct 16 02:30 gdtI0.f00072
-rw-rw-r-- 1 353M Oct 16 02:36 gdtI0.f00073
-rw-rw-r-- 1 353M Oct 16 02:42 gdtI0.f00074
-rw-rw-r-- 1 353M Oct 16 02:48 gdtI0.f00075
-rw-rw-r-- 1 353M Oct 16 02:54 gdtI0.f00076
-rw-rw-r-- 1 353M Oct 16 03:00 gdtI0.f00077
-rw-rw-r-- 1 353M Oct 16 03:06 gdtI0.f00078
-rw-rw-r-- 1 529M Oct 16 03:06 I0.f00026
-rw-rw-r-- 1 353M Oct 16 03:12 gdtI0.f00079
-rw-rw-r-- 1 529M Oct 16 03:12 I0.f00027
-rw-rw-r-- 1 353M Oct 16 03:18 gdtI0.f00080
-rw-rw-r-- 1 529M Oct 16 03:18 I0.f00028
-rw-rw-r-- 1 353M Oct 16 03:24 gdtI0.f00081
-rw-rw-r-- 1 529M Oct 16 03:25 I0.f00029
-rw-rw-r-- 1 353M Oct 16 03:31 gdtI0.f00082
-rw-rw-r-- 1 529M Oct 16 03:31 I0.f00030
-rw-rw-r-- 1 353M Oct 16 03:37 gdtI0.f00083
-rw-rw-r-- 1 529M Oct 16 03:37 I0.f00031
-rw-rw-r-- 1 353M Oct 16 03:43 gdtI0.f00084
-rw-rw-r-- 1 529M Oct 16 03:44 I0.f00032
-rw-rw-r-- 1 353M Oct 16 03:50 gdtI0.f00085
-rw-rw-r-- 1 529M Oct 16 03:50 I0.f00033
-rw-rw-r-- 1 353M Oct 16 03:56 gdtI0.f00086
-rw-rw-r-- 1 529M Oct 16 03:56 I0.f00034
-rw-rw-r-- 1 353M Oct 16 04:02 gdtI0.f00087
-rw-rw-r-- 1 529M Oct 16 04:02 I0.f00035
-rw-rw-r-- 1 353M Oct 16 04:08 gdtI0.f00088
-rw-rw-r-- 1 529M Oct 16 04:08 I0.f00036
-rw-rw-r-- 1 353M Oct 16 04:14 gdtI0.f00089
-rw-rw-r-- 1 529M Oct 16 04:14 I0.f00037
-rw-rw-r-- 1 353M Oct 16 04:20 gdtI0.f00090
-rw-rw-r-- 1 529M Oct 16 04:21 I0.f00038
-rw-rw-r-- 1 353M Oct 16 04:27 gdtI0.f00091
-rw-rw-r-- 1 529M Oct 16 04:27 I0.f00039
-rw-rw-r-- 1 353M Oct 16 04:33 gdtI0.f00092
-rw-rw-r-- 1 529M Oct 16 04:33 I0.f00040
-rw-rw-r-- 1 353M Oct 16 04:39 gdtI0.f00093
-rw-rw-r-- 1 529M Oct 16 04:39 I0.f00041
-rw-rw-r-- 1 353M Oct 16 04:45 gdtI0.f00094
-rw-rw-r-- 1 529M Oct 16 04:45 I0.f00042
-rw-rw-r-- 1 353M Oct 16 04:51 gdtI0.f00095
-rw-rw-r-- 1 529M Oct 16 04:52 I0.f00043
-rw-rw-r-- 1 353M Oct 16 04:58 gdtI0.f00096
-rw-rw-r-- 1 529M Oct 16 04:58 I0.f00044
-rw-rw-r-- 1 353M Oct 16 05:04 gdtI0.f00097
-rw-rw-r-- 1 529M Oct 16 05:04 I0.f00045
-rw-rw-r-- 1 353M Oct 16 05:10 gdtI0.f00098
-rw-rw-r-- 1 529M Oct 16 05:11 I0.f00046
-rw-rw-r-- 1 353M Oct 16 05:17 gdtI0.f00099
-rw-rw-r-- 1 529M Oct 16 05:17 I0.f00047
-rw-rw-r-- 1 353M Oct 16 05:23 gdtI0.f00100
-rw-rw-r-- 1 529M Oct 16 05:23 I0.f00048
-rw-rw-r-- 1 353M Oct 16 05:29 gdtI0.f00101
-rw-rw-r-- 1 529M Oct 16 05:29 I0.f00049
-rw-rw-r-- 1 353M Oct 16 05:35 gdtI0.f00102
-rw-rw-r-- 1 529M Oct 16 05:35 I0.f00050
-rw-rw-r-- 1 353M Oct 16 05:41 gdtI0.f00103
-rw-rw-r-- 1 529M Oct 16 05:41 I0.f00051
-rw-rw-r-- 1 353M Oct 16 05:47 gdtI0.f00104
-rw-rw-r-- 1 529M Oct 16 05:48 I0.f00052
-rw-rw-r-- 1 353M Oct 16 05:54 gdtI0.f00105
-rw-rw-r-- 1 529M Oct 16 05:54 I0.f00053
-rw-rw-r-- 1 353M Oct 16 06:00 gdtI0.f00106
-rw-rw-r-- 1 529M Oct 16 06:00 I0.f00054
-rw-rw-r-- 1 353M Oct 16 06:06 gdtI0.f00107
-rw-rw-r-- 1 529M Oct 16 06:06 I0.f00055
-rw-rw-r-- 1 353M Oct 16 06:12 gdtI0.f00108
-rw-rw-r-- 1 529M Oct 16 06:13 I0.f00056
-rw-rw-r-- 1 353M Oct 16 06:18 gdtI0.f00109
-rw-rw-r-- 1 529M Oct 16 06:19 I0.f00057
-rw-rw-r-- 1 353M Oct 16 06:24 gdtI0.f00110
-rw-rw-r-- 1 529M Oct 16 06:25 I0.f00058
-rw-rw-r-- 1 353M Oct 16 06:31 gdtI0.f00111
-rw-rw-r-- 1 529M Oct 16 06:31 I0.f00059
-rw-rw-r-- 1 353M Oct 16 06:37 gdtI0.f00112
-rw-rw-r-- 1 529M Oct 16 06:37 I0.f00060
-rw-rw-r-- 1 353M Oct 16 06:43 gdtI0.f00113
-rw-rw-r-- 1 529M Oct 16 06:44 I0.f00061
-rw-rw-r-- 1 353M Oct 16 06:50 gdtI0.f00114
-rw-rw-r-- 1 529M Oct 16 06:50 I0.f00062
-rw-rw-r-- 1 353M Oct 16 06:56 gdtI0.f00115
-rw-rw-r-- 1 529M Oct 16 06:56 I0.f00063
-rw-rw-r-- 1 353M Oct 16 07:02 gdtI0.f00116
-rw-rw-r-- 1 529M Oct 16 07:02 I0.f00064
-rw-rw-r-- 1 353M Oct 16 07:08 gdtI0.f00117
-rw-rw-r-- 1 529M Oct 16 07:08 I0.f00065
-rw-rw-r-- 1 353M Oct 16 07:14 gdtI0.f00118
-rw-rw-r-- 1 529M Oct 16 07:14 I0.f00066
-rw-rw-r-- 1 353M Oct 16 07:20 gdtI0.f00119
-rw-rw-r-- 1 529M Oct 16 07:20 I0.f00067
-rw-rw-r-- 1 353M Oct 16 07:26 gdtI0.f00120
-rw-rw-r-- 1 529M Oct 16 07:26 I0.f00068
-rw-rw-r-- 1 353M Oct 16 07:32 gdtI0.f00121
-rw-rw-r-- 1 529M Oct 16 07:32 I0.f00069
-rw-rw-r-- 1 353M Oct 16 07:38 gdtI0.f00122
-rw-rw-r-- 1 529M Oct 16 07:38 I0.f00070
-rw-rw-r-- 1 353M Oct 16 07:44 gdtI0.f00123
-rw-rw-r-- 1 529M Oct 16 07:44 I0.f00071
-rw-rw-r-- 1 353M Oct 16 07:50 gdtI0.f00124
-rw-rw-r-- 1 529M Oct 16 07:50 I0.f00072
-rw-rw-r-- 1 353M Oct 16 07:56 gdtI0.f00125
-rw-rw-r-- 1 529M Oct 16 07:56 I0.f00073
-rw-rw-r-- 1 353M Oct 16 08:02 gdtI0.f00126
-rw-rw-r-- 1 529M Oct 16 08:02 I0.f00074
-rw-rw-r-- 1 353M Oct 16 08:08 gdtI0.f00127
-rw-rw-r-- 1 529M Oct 16 08:08 I0.f00075
-rw-rw-r-- 1 353M Oct 16 08:14 gdtI0.f00128
-rw-rw-r-- 1 529M Oct 16 08:14 I0.f00076
-rw-rw-r-- 1 353M Oct 16 08:20 gdtI0.f00129
-rw-rw-r-- 1 529M Oct 16 08:21 I0.f00077
-rw-rw-r-- 1 353M Oct 16 08:26 gdtI0.f00130
-rw-rw-r-- 1 529M Oct 16 08:27 I0.f00078
-rw-rw-r-- 1 353M Oct 16 08:32 gdtI0.f00131
-rw-rw-r-- 1 529M Oct 16 08:33 I0.f00079
-rw-rw-r-- 1 353M Oct 16 08:39 gdtI0.f00132
-rw-rw-r-- 1 529M Oct 16 08:39 I0.f00080
-rw-rw-r-- 1 353M Oct 16 08:45 gdtI0.f00133
-rw-rw-r-- 1 529M Oct 16 08:45 I0.f00081
-rw-rw-r-- 1 353M Oct 16 08:51 gdtI0.f00134
-rw-rw-r-- 1 529M Oct 16 08:51 I0.f00082
-rw-rw-r-- 1 353M Oct 16 08:57 gdtI0.f00135
-rw-rw-r-- 1 529M Oct 16 08:57 I0.f00083
-rw-rw-r-- 1 353M Oct 16 09:03 gdtI0.f00136
-rw-rw-r-- 1 529M Oct 16 09:03 I0.f00084
-rw-rw-r-- 1 353M Oct 16 09:09 gdtI0.f00137
-rw-rw-r-- 1 529M Oct 16 09:09 I0.f00085
-rw-rw-r-- 1 353M Oct 16 09:15 gdtI0.f00138
-rw-rw-r-- 1 529M Oct 16 09:15 I0.f00086
-rw-rw-r-- 1 353M Oct 16 09:21 gdtI0.f00139
-rw-rw-r-- 1 529M Oct 16 09:22 I0.f00087
-rw-rw-r-- 1 353M Oct 16 09:27 gdtI0.f00140
-rw-rw-r-- 1 529M Oct 16 09:28 I0.f00088
-rw-rw-r-- 1 353M Oct 16 09:33 gdtI0.f00141
-rw-rw-r-- 1 529M Oct 16 09:34 I0.f00089
-rw-rw-r-- 1 353M Oct 16 09:40 gdtI0.f00142
-rw-rw-r-- 1 529M Oct 16 09:40 I0.f00090
-rw-rw-r-- 1 353M Oct 16 09:46 gdtI0.f00143
-rw-rw-r-- 1 529M Oct 16 09:46 I0.f00091
-rw-rw-r-- 1 353M Oct 16 09:52 gdtI0.f00144
-rw-rw-r-- 1 529M Oct 16 09:52 I0.f00092
-rw-rw-r-- 1 353M Oct 16 09:57 gdtI0.f00145
-rw-rw-r-- 1 529M Oct 16 09:58 I0.f00093
-rw-rw-r-- 1 353M Oct 16 10:03 gdtI0.f00146
-rw-rw-r-- 1 529M Oct 16 10:04 I0.f00094
-rw-rw-r-- 1 353M Oct 16 10:09 gdtI0.f00147
-rw-rw-r-- 1 529M Oct 16 10:10 I0.f00095
-rw-rw-r-- 1 353M Oct 16 10:15 gdtI0.f00148
-rw-rw-r-- 1 529M Oct 16 10:16 I0.f00096
-rw-rw-r-- 1 353M Oct 16 10:21 gdtI0.f00149
-rw-rw-r-- 1 529M Oct 16 10:22 I0.f00097
-rw-rw-r-- 1 353M Oct 16 10:27 gdtI0.f00150
-rw-rw-r-- 1 529M Oct 16 10:28 I0.f00098
-rw-rw-r-- 1 353M Oct 16 10:33 gdtI0.f00151
-rw-rw-r-- 1 529M Oct 16 10:34 I0.f00099
-rw-rw-r-- 1 353M Oct 16 10:39 gdtI0.f00152
-rw-rw-r-- 1 529M Oct 16 10:40 I0.f00100
-rw-rw-r-- 1 353M Oct 16 10:46 gdtI0.f00153
-rw-rw-r-- 1 353M Oct 16 10:52 gdtI0.f00154
-rw-rw-r-- 1 353M Oct 16 10:57 gdtI0.f00155
-rw-rw-r-- 1 353M Oct 16 11:03 gdtI0.f00156
-rw-rw-r-- 1 353M Oct 16 11:09 gdtI0.f00157
-rw-rw-r-- 1 353M Oct 16 11:15 gdtI0.f00158
-rw-rw-r-- 1 353M Oct 16 11:21 gdtI0.f00159
-rw-rw-r-- 1 353M Oct 16 11:27 gdtI0.f00160
-rw-rw-r-- 1 353M Oct 16 11:33 gdtI0.f00161
-rw-rw-r-- 1 353M Oct 16 11:39 gdtI0.f00162
-rw-rw-r-- 1 353M Oct 16 11:45 gdtI0.f00163
-rw-rw-r-- 1 353M Oct 16 11:51 gdtI0.f00164
-rw-rw-r-- 1 353M Oct 16 11:57 gdtI0.f00165
-rw-rw-r-- 1 353M Oct 16 12:03 gdtI0.f00166
-rw-rw-r-- 1 353M Oct 16 12:09 gdtI0.f00167
-rw-rw-r-- 1 353M Oct 16 12:15 gdtI0.f00168
-rw-rw-r-- 1 353M Oct 16 12:21 gdtI0.f00169
-rw-rw-r-- 1 353M Oct 16 12:27 gdtI0.f00170
-rw-rw-r-- 1 353M Oct 16 12:33 gdtI0.f00171
-rw-rw-r-- 1 353M Oct 16 12:39 gdtI0.f00172
-rw-rw-r-- 1 353M Oct 16 12:45 gdtI0.f00173
-rw-rw-r-- 1 353M Oct 16 12:51 gdtI0.f00174
-rw-rw-r-- 1 353M Oct 16 12:57 gdtI0.f00175
-rw-rw-r-- 1 353M Oct 16 13:03 gdtI0.f00176
-rw-rw-r-- 1 353M Oct 16 13:09 gdtI0.f00177
-rw-rw-r-- 1 353M Oct 16 13:15 gdtI0.f00178
-rw-rw-r-- 1 353M Oct 16 13:21 gdtI0.f00179
-rw-rw-r-- 1 353M Oct 16 13:27 gdtI0.f00180
-rw-rw-r-- 1 353M Oct 16 13:33 gdtI0.f00181
-rw-rw-r-- 1 353M Oct 16 13:39 gdtI0.f00182
-rw-rw-r-- 1 353M Oct 16 13:45 gdtI0.f00183
-rw-rw-r-- 1 353M Oct 16 13:51 gdtI0.f00184
-rw-rw-r-- 1 353M Oct 16 13:57 gdtI0.f00185
-rw-rw-r-- 1 353M Oct 16 14:03 gdtI0.f00186
-rw-rw-r-- 1 353M Oct 16 14:09 gdtI0.f00187
-rw-rw-r-- 1 353M Oct 16 14:15 gdtI0.f00188
-rw-rw-r-- 1 353M Oct 16 14:21 gdtI0.f00189
-rw-rw-r-- 1 353M Oct 16 14:27 gdtI0.f00190
-rw-rw-r-- 1 353M Oct 16 14:33 gdtI0.f00191
-rw-rw-r-- 1 353M Oct 16 14:39 gdtI0.f00192
-rw-rw-r-- 1 353M Oct 16 15:42 gdtI0.f00193
-rw-rw-r-- 1 353M Oct 16 16:34 gdtI0.f00194
-rw-rw-r-- 1 353M Oct 16 17:34 gdtI0.f00195
-rw-rw-r-- 1 353M Oct 16 18:32 gdtI0.f00196
-rw-rw-r-- 1 353M Oct 16 18:52 gdtI0.f00197
-rw-rw-r-- 1 353M Oct 16 18:58 gdtI0.f00198
-rw-rw-r-- 1 353M Oct 16 19:04 gdtI0.f00199
-rw-rw-r-- 1 353M Oct 16 19:10 gdtI0.f00200
-rw-rw-r-- 1 353M Oct 16 19:16 gdtI0.f00201
-rw-rw-r-- 1 353M Oct 16 19:22 gdtI0.f00202
-rw-rw-r-- 1 353M Oct 16 19:28 gdtI0.f00203
-rw-rw-r-- 1 353M Oct 16 19:34 gdtI0.f00204
-rw-rw-r-- 1 353M Oct 16 19:40 gdtI0.f00205
-rw-rw-r-- 1 353M Oct 16 19:46 gdtI0.f00206
-rw-rw-r-- 1 353M Oct 16 19:52 gdtI0.f00207
-rw-rw-r-- 1 353M Oct 16 19:58 gdtI0.f00208
-rw-rw-r-- 1 353M Oct 16 20:04 gdtI0.f00209
-rw-rw-r-- 1 353M Oct 16 20:10 gdtI0.f00210
-rw-rw-r-- 1 353M Oct 16 20:16 gdtI0.f00211
-rw-rw-r-- 1 353M Oct 16 20:22 gdtI0.f00212
-rw-rw-r-- 1 353M Oct 16 20:28 gdtI0.f00213
-rw-rw-r-- 1 353M Oct 16 20:34 gdtI0.f00214
-rw-rw-r-- 1 353M Oct 16 20:40 gdtI0.f00215
-rw-rw-r-- 1 353M Oct 16 20:46 gdtI0.f00216
-rw-rw-r-- 1 353M Oct 16 20:52 gdtI0.f00217
-rw-rw-r-- 1 353M Oct 16 20:58 gdtI0.f00218
-rw-rw-r-- 1 353M Oct 16 21:04 gdtI0.f00219
-rw-rw-r-- 1 353M Oct 16 21:10 gdtI0.f00220
-rw-rw-r-- 1 353M Oct 16 21:16 gdtI0.f00221
-rw-rw-r-- 1 353M Oct 16 21:22 gdtI0.f00222
-rw-rw-r-- 1 353M Oct 16 21:28 gdtI0.f00223
-rw-rw-r-- 1 353M Oct 16 21:34 gdtI0.f00224
-rw-rw-r-- 1 353M Oct 16 21:40 gdtI0.f00225
-rw-rw-r-- 1 353M Oct 16 21:46 gdtI0.f00226
-rw-rw-r-- 1 353M Oct 16 21:52 gdtI0.f00227
-rw-rw-r-- 1 353M Oct 16 21:58 gdtI0.f00228
-rw-rw-r-- 1 353M Oct 16 22:04 gdtI0.f00229
-rw-rw-r-- 1 353M Oct 16 22:10 gdtI0.f00230
-rw-rw-r-- 1 353M Oct 16 22:16 gdtI0.f00231
-rw-rw-r-- 1 353M Oct 16 22:22 gdtI0.f00232
-rw-rw-r-- 1 353M Oct 16 22:28 gdtI0.f00233
-rw-rw-r-- 1 353M Oct 16 22:34 gdtI0.f00234
-rw-rw-r-- 1 353M Oct 16 22:40 gdtI0.f00235
-rw-rw-r-- 1 353M Oct 16 22:46 gdtI0.f00236
-rw-rw-r-- 1 353M Oct 16 22:52 gdtI0.f00237
-rw-rw-r-- 1 353M Oct 16 22:58 gdtI0.f00238
-rw-rw-r-- 1 353M Oct 16 23:04 gdtI0.f00239
-rw-rw-r-- 1 353M Oct 16 23:10 gdtI0.f00240
-rw-rw-r-- 1 353M Oct 16 23:16 gdtI0.f00241
-rw-rw-r-- 1 353M Oct 16 23:22 gdtI0.f00242
-rw-rw-r-- 1 353M Oct 16 23:28 gdtI0.f00243
-rw-rw-r-- 1 353M Oct 16 23:34 gdtI0.f00244
-rw-rw-r-- 1 353M Oct 16 23:40 gdtI0.f00245
-rw-rw-r-- 1 353M Oct 16 23:46 gdtI0.f00246
-rw-rw-r-- 1 353M Oct 16 23:52 gdtI0.f00247
-rw-rw-r-- 1 353M Oct 16 23:58 gdtI0.f00248
-rw-rw-r-- 1 353M Oct 17 00:04 gdtI0.f00249
-rw-rw-r-- 1 353M Oct 17 00:10 gdtI0.f00250
-rw-rw-r-- 1 353M Oct 17 00:16 gdtI0.f00251
-rw-rw-r-- 1 353M Oct 17 00:22 gdtI0.f00252
-rw-rw-r-- 1 353M Oct 17 00:28 gdtI0.f00253
-rw-rw-r-- 1 353M Oct 17 00:34 gdtI0.f00254
-rw-rw-r-- 1 353M Oct 17 00:40 gdtI0.f00255
-rw-rw-r-- 1 353M Oct 17 00:46 gdtI0.f00256
-rw-rw-r-- 1 353M Oct 17 00:52 gdtI0.f00257
-rw-rw-r-- 1 353M Oct 17 00:58 gdtI0.f00258
-rw-rw-r-- 1 353M Oct 17 01:04 gdtI0.f00259
-rw-rw-r-- 1 353M Oct 17 01:10 gdtI0.f00260
-rw-rw-r-- 1 353M Oct 17 01:16 gdtI0.f00261
-rw-rw-r-- 1 353M Oct 17 01:22 gdtI0.f00262
-rw-rw-r-- 1 353M Oct 17 01:28 gdtI0.f00263
-rw-rw-r-- 1 353M Oct 17 01:34 gdtI0.f00264
-rw-rw-r-- 1 353M Oct 17 01:40 gdtI0.f00265
-rw-rw-r-- 1 353M Oct 17 01:46 gdtI0.f00266
-rw-rw-r-- 1 353M Oct 17 01:52 gdtI0.f00267
-rw-rw-r-- 1 353M Oct 17 01:58 gdtI0.f00268
-rw-rw-r-- 1 353M Oct 17 02:04 gdtI0.f00269
-rw-rw-r-- 1 353M Oct 17 02:10 gdtI0.f00270
-rw-rw-r-- 1 353M Oct 17 02:16 gdtI0.f00271
-rw-rw-r-- 1 353M Oct 17 02:22 gdtI0.f00272
-rw-rw-r-- 1 353M Oct 17 02:28 gdtI0.f00273
-rw-rw-r-- 1 353M Oct 17 02:34 gdtI0.f00274
-rw-rw-r-- 1 353M Oct 17 02:40 gdtI0.f00275
-rw-rw-r-- 1 353M Oct 17 02:46 gdtI0.f00276
-rw-rw-r-- 1 353M Oct 17 02:52 gdtI0.f00277
-rw-rw-r-- 1 353M Oct 17 02:58 gdtI0.f00278
-rw-rw-r-- 1 353M Oct 17 03:04 gdtI0.f00279
-rw-rw-r-- 1 353M Oct 17 03:10 gdtI0.f00280
-rw-rw-r-- 1 353M Oct 17 03:16 gdtI0.f00281
-rw-rw-r-- 1 353M Oct 17 03:22 gdtI0.f00282
-rw-rw-r-- 1 353M Oct 17 03:28 gdtI0.f00283
-rw-rw-r-- 1 353M Oct 17 03:34 gdtI0.f00284
-rw-rw-r-- 1 353M Oct 17 03:40 gdtI0.f00285
-rw-rw-r-- 1 353M Oct 17 03:46 gdtI0.f00286
-rw-rw-r-- 1 353M Oct 17 03:52 gdtI0.f00287
-rw-rw-r-- 1 353M Oct 17 03:58 gdtI0.f00288
-rw-rw-r-- 1 353M Oct 17 04:04 gdtI0.f00289
-rw-rw-r-- 1 353M Oct 17 04:10 gdtI0.f00290
-rw-rw-r-- 1 353M Oct 17 04:16 gdtI0.f00291
-rw-rw-r-- 1 353M Oct 17 04:22 gdtI0.f00292
-rw-rw-r-- 1 353M Oct 17 04:28 gdtI0.f00293
-rw-rw-r-- 1 353M Oct 17 04:34 gdtI0.f00294
-rw-rw-r-- 1 353M Oct 17 04:40 gdtI0.f00295
-rw-rw-r-- 1 353M Oct 17 04:46 gdtI0.f00296
-rw-rw-r-- 1 353M Oct 17 04:52 gdtI0.f00297
-rw-rw-r-- 1 353M Oct 17 04:58 gdtI0.f00298
-rw-rw-r-- 1 353M Oct 17 05:04 gdtI0.f00299
-rw-rw-r-- 1 353M Oct 17 05:10 gdtI0.f00300
-rw-rw-r-- 1 353M Oct 17 05:16 gdtI0.f00301
-rw-rw-r-- 1 353M Oct 17 05:22 gdtI0.f00302
-rw-rw-r-- 1 353M Oct 17 05:28 gdtI0.f00303
-rw-rw-r-- 1 353M Oct 17 05:34 gdtI0.f00304
-rw-rw-r-- 1 353M Oct 17 05:40 gdtI0.f00305
-rw-rw-r-- 1 353M Oct 17 05:46 gdtI0.f00306
-rw-rw-r-- 1 353M Oct 17 05:52 gdtI0.f00307
-rw-rw-r-- 1 353M Oct 17 05:58 gdtI0.f00308
-rw-rw-r-- 1 353M Oct 17 06:04 gdtI0.f00309
-rw-rw-r-- 1 353M Oct 17 06:10 gdtI0.f00310
-rw-rw-r-- 1 353M Oct 17 06:16 gdtI0.f00311
-rw-rw-r-- 1 353M Oct 17 06:22 gdtI0.f00312
-rw-rw-r-- 1 353M Oct 17 06:28 gdtI0.f00313
-rw-rw-r-- 1 353M Oct 17 06:34 gdtI0.f00314
-rw-rw-r-- 1 353M Oct 17 06:40 gdtI0.f00315
-rw-rw-r-- 1 353M Oct 17 06:46 gdtI0.f00316
-rw-rw-r-- 1 377M Oct 17 06:52 hpts.out
-rw-rw-r-- 1 353M Oct 17 06:52 gdtI0.f00317
-rw-rw-r-- 1 190M Oct 17 06:56 slurm-1134244.out
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151027/8e14b3e7/attachment-0001.html>
