[Nek5000-users] Rotational velocity
Thu Nov 26 07:19:23 CST 2015
if you would like to add Coriolis (and centrifugal) acceleration terms
then these can easily be put into userf as body forces. If you use a
param-value from the rea file, then the amount of rotation can be set at
runtime.
If on the other hand you would like to specify a rotating body, then I
guess you could use the boundary conditions (userbc) on the body to
impose this rotation.
Best regards,
Philipp
On 2015-11-26 03:53, nek5000-users at lists.mcs.anl.gov wrote:
> Hi neks,
> Is there a way to specify rotation on a body without mesh deformation? A
> follow up question to that is..suppose I specify an Omega a value. Omega
> is rotational velocity. How does nek know that this is rotational and
> not translational?
> Rif
> Nek5000-users mailing list
