[Nek5000-users] NEK-MOAB coupling
Thu Nov 19 15:33:37 CST 2015
Dear Neks,
I think recent version of Nek has some problems to couple Nek with MOAB, I
coupled Nek and MOAB before. But with current version of Nek (1090) , it
can't compile with MOAB. I attached the makenek output.
( P.S.  MOAB version 4.6.3 and compiled with mpi and parallel hdf5 and
passed all the tests)
Fatih
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151119/75aa2ec4/attachment-0001.html>
makenek - automatic build tool for Nek5000
CMT root /scratch/user/fatihsinan/NEK/trunk/nek/cmt
/usr/bin/ld: warning: libquadmath.so.0, needed by /scratch/user/fatihsinan/MOAB/mpi2/mpich-3.2/gcc/lib/libmpi.so, not found (try using -rpath or -rpath-link)
./a.out: error while loading shared libraries: libquadmath.so.0: cannot open shared object file: No such file or directory
generating makefile ...
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/drive.f -o obj/drive.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/drive1.f -o obj/drive1.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/drive2.f -o obj/drive2.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/plan4.f -o obj/plan4.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/bdry.f -o obj/bdry.o
/scratch/user/fatihsinan/NEK/trunk/nek/plan4.f:409.25:
      call add3s2(vext(1,2),vy,vylag,ab0,ab1,ntot)
                         1
Warning: Array reference at (1) is out of bounds (2 > 1) in dimension 2
/scratch/user/fatihsinan/NEK/trunk/nek/plan4.f:410.34:
      if(if3d) call add3s2(vext(1,3),vz,vzlag,ab0,ab1,ntot)
                                  1
Warning: Array reference at (1) is out of bounds (3 > 1) in dimension 2
/scratch/user/fatihsinan/NEK/trunk/nek/plan4.f:414.27:
        call add2s2(vext(1,2),vylag(1,1,1,1,2),ab2,ntot)
                           1
/scratch/user/fatihsinan/NEK/trunk/nek/plan4.f:415.36:
        if(if3d) call add2s2(vext(1,3),vzlag(1,1,1,1,2),ab2,ntot)
                                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/coef.f -o obj/coef.o
/scratch/user/fatihsinan/NEK/trunk/nek/bdry.f:1231.37:
            cv   = vtrans(ix,iy,iz,e,icv)/rho
                                     1
Warning: Array reference at (1) is out of bounds (3 > 2) in dimension 5
/scratch/user/fatihsinan/NEK/trunk/nek/bdry.f:1239.38:
            lambda = vdiff(ix,iy,iz,e,ilam)
                                      1
/scratch/user/fatihsinan/NEK/trunk/nek/bdry.f:1465.20:
      COMMON /CTMP1/ A1X(LX1),A1Y(LX1),A2X(LX1),A2Y(LX1)
                    1
Warning: Named COMMON block 'ctmp1' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/bdry.f:1646.20:
      COMMON /CTMP1/  DRM1(LX1,LX1),DRTM1(LX1,LY1)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/conduct.f -o obj/conduct.o
/scratch/user/fatihsinan/NEK/trunk/nek/bdry.f:1897.20:
      COMMON /SCRMG/ V1(LX1,LY1,LZ1,LELV)
                    1
Warning: Named COMMON block 'scrmg' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/drive2.f:1836.20:
      COMMON /SCRNS/ rw1   (LX1,LY1,LZ1,LELV)
                    1
Warning: Named COMMON block 'scrns' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/conduct.f:267.20:
      common /scrns/ ta(lt),tb(lt),h2(lt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/conduct.f:454.20:
      common /scruz/ ta(lx1,ly1,lz1,lelt)
                    1
Warning: Named COMMON block 'scruz' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/connect1.f -o obj/connect1.o
/scratch/user/fatihsinan/NEK/trunk/nek/connect1.f:719.20:
      COMMON /CTMP0/ XCB(2,2,2),YCB(2,2,2),ZCB(2,2,2),H(3,3,2),INDX(8)
                    1
Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/connect2.f -o obj/connect2.o
/scratch/user/fatihsinan/NEK/trunk/nek/connect2.f:1653.20:
      common /scrns/ tc(lx1,ly1,lz1,lelt),td(lx1,ly1,lz1,lelt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/connect2.f:1883.20:
      COMMON /CTMP0/ VO(LELT),XYZI(3,LELT),CG(3,LELT)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/dssum.f -o obj/dssum.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/edgec.f -o obj/edgec.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/eigsolv.f -o obj/eigsolv.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/gauss.f -o obj/gauss.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/genxyz.f -o obj/genxyz.o
/scratch/user/fatihsinan/NEK/trunk/nek/genxyz.f:329.21:
      COMMON /SRFCEL/ SUCCES
                     1
Warning: Named COMMON block 'srfcel' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier1.f -o obj/navier1.o
/scratch/user/fatihsinan/NEK/trunk/nek/genxyz.f:1298.20:
      common /ctmp0/ xcb(2,2,2),ycb(2,2,2),zcb(2,2,2),w(ldw)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/genxyz.f:1349.20:
      common /ctmp0/ w(ldw,2),zg(3)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/genxyz.f:1359.20:
      common /cxyzl/ zgml(lx1,3),jx (lx1*3),jy (lx1*3),jz (lx1*3)
                    1
Warning: Named COMMON block 'cxyzl' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/navier1.f:168.20:
      COMMON /SCRUZ/ TB1   (LX1,LY1,LZ1,LELV)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/makeq.f -o obj/makeq.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier0.f -o obj/navier0.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier1.f:1316.20:
      COMMON /CTMP1/  MFI    (LX1,LY1,LZ1,LELV)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier2.f -o obj/navier2.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier1.f:2237.20:
      COMMON /SCRMG/ Y1 (LX1,LY1,LZ1,LELT)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier3.f -o obj/navier3.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier1.f:3513.20:
      COMMON /CTMP0/ TA1  (LX1,LY1,LZ1,LELV)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier4.f -o obj/navier4.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/prepost.f -o obj/prepost.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier4.f:209.21:
      COMMON /ORTHOX/ Pbar(LTOT2),Pnew(LTOT2),Pbrr(ltot2)
                     1
Warning: Named COMMON block 'orthox' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/navier1.f:4206.20:
      COMMON /CTMP1/ RKX1  (LX1,LY1,LZ1,LELV)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/speclib.f -o obj/speclib.o
/scratch/user/fatihsinan/NEK/trunk/nek/prepost.f:814.20:
      common /scruz/ ta1(lx1,ly1,lz1,lelv)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/navier4.f:1127.11:
      ivar(2) = m ! Update number of saved vectors
           1
Warning: Array reference at (1) is out of bounds (2 > 1) in dimension 1
/scratch/user/fatihsinan/NEK/trunk/nek/prepost.f:2264.20:
      common /SCRNS/ u4(2+lxo*lxo*lxo*6*lelt)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/map2.f -o obj/map2.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/turb.f -o obj/turb.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/mvmesh.f -o obj/mvmesh.o
/scratch/user/fatihsinan/NEK/trunk/nek/turb.f:578.20:
      COMMON /SCRUZ/ V1(LX1,LY1,LZ1,LELV)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/ic.f -o obj/ic.o
/scratch/user/fatihsinan/NEK/trunk/nek/ic.f:966.38:
     $            call copy(t(1,1,1,1,2),sdmp2(1,1),ntott)
                                      1
Warning: Array reference at (1) is out of bounds (2 > 1) in dimension 5
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/ssolv.f -o obj/ssolv.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/planx.f -o obj/planx.o
mpif77 -c  -O3 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I./ /scratch/user/fatihsinan/NEK/trunk/nek/math.f -o obj/math.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/mxm_wrapper.f -o obj/mxm_wrapper.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/hmholtz.f -o obj/hmholtz.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/gfdm_par.f -o obj/gfdm_par.o
/scratch/user/fatihsinan/NEK/trunk/nek/hmholtz.f:638.22:
      COMMON  /CPRINT/ IFPRINT, IFHZPC
                      1
Warning: Named COMMON block 'cprint' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/gfdm_op.f -o obj/gfdm_op.o
/scratch/user/fatihsinan/NEK/trunk/nek/hmholtz.f:2141.20:
      common /ctmp0/ ugunh(2*lx1*lz1*2*ldim*lelt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/hmholtz.f:2143.20:
      common /ctmp1/ ur(lt),us(lt),ut(lt)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/gfdm_solve.f -o obj/gfdm_solve.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/subs1.f -o obj/subs1.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/subs2.f -o obj/subs2.o
/scratch/user/fatihsinan/NEK/trunk/nek/subs1.f:1578.20:
      common /ctmp1/ exx(lx1*ly1*lz1*lelt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/subs2.f:736.20:
      common /screv/ hfmask(lx1,lz1,6,lelt)
                    1
Warning: Named COMMON block 'screv' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/genbox.f -o obj/genbox.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/gmres.f -o obj/gmres.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/hsmg.f -o obj/hsmg.o
/scratch/user/fatihsinan/NEK/trunk/nek/hsmg.f:296.20:
      common /hsmgw/ work(0:lwk-1),work2(0:lwk-1)
                    1
Warning: Named COMMON block 'hsmgw' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/hsmg.f:2046.20:
      common /ctmp0/ ur(lxyz),us(lxyz),ut(lxyz)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/hsmg.f:2535.20:
      common /scrvh/ h1    (lx1,ly1,lz1,lelv)
                    1
Warning: Named COMMON block 'scrvh' at (1) shall be of the same size
/scratch/user/fatihsinan/NEK/trunk/nek/hsmg.f:2924.20:
      common /ctmp0/ w(100000)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/convect.f -o obj/convect.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/induct.f -o obj/induct.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/perturb.f -o obj/perturb.o
/scratch/user/fatihsinan/NEK/trunk/nek/induct.f:189.20:
      COMMON /SCRNS/ TA1(LX1,LY1,LZ1,LELV)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/convect.f:946.20:
      common /ctmp1/ work(lxyz1,lelt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/perturb.f:454.20:
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/convect.f:1538.20:
      common /scrdg/ uf(lf),uxf(lf),uyf(lf),uzf(lf),upwind_wgt(lf)
                    1
Warning: Named COMMON block 'scrdg' at (1) shall be of the same size
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier5.f -o obj/navier5.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier6.f -o obj/navier6.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier7.f -o obj/navier7.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/navier8.f -o obj/navier8.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/fast3d.f -o obj/fast3d.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier8.f:1449.20:
      common /ctmp0/ w(2,2,lx1),v(2,ly1,lz1,lelt)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/navier8.f:2022.21:
      common  /scrns/ ind,etuple
                     1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/fasts.f -o obj/fasts.o
/scratch/user/fatihsinan/NEK/trunk/nek/navier5.f:4085.20:
      common /ctmp1/ w(lt,lelt),ur(lt),us(lt),ut(lt),w1(2*lt)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/calcz.f -o obj/calcz.o
mpicc -c  -O2 -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG  -DPREFIX=jl_ /scratch/user/fatihsinan/NEK/trunk/nek/byte.c -o obj/byte.o
mpicc -c  -O2 -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG  -DPREFIX=jl_ /scratch/user/fatihsinan/NEK/trunk/nek/chelpers.c -o obj/chelpers.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/byte_mpi.f -o obj/byte_mpi.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/postpro.f -o obj/postpro.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cvode_driver.f -o obj/cvode_driver.o
mpicc -c  -O2 -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG  -DPREFIX=jl_ /scratch/user/fatihsinan/NEK/trunk/nek/nek_comm.c -o obj/nek_comm.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/init_plugin.f -o obj/init_plugin.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/setprop.f -o obj/setprop.o
/scratch/user/fatihsinan/NEK/trunk/nek/postpro.f:1056.20:
      common /scrns/ vcurve(5,12,lblock),wk(5*12*lblock)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/postpro.f:1057.20:
      common /scruz/ icurve(12,lblock)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/qthermal.f -o obj/qthermal.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cvode_aux.f -o obj/cvode_aux.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/makeq_aux.f -o obj/makeq_aux.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/papi.f -o obj/papi.o
/scratch/user/fatihsinan/NEK/trunk/nek/postpro.f:2111.20:
      common /scrns/ xyz(ldim,lt2)
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/postpro.f:2112.20:
      common /scruz/ mid(lt2)  ! Target proc id
                    1
mpif77 -c   -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/nek_in_situ.f -o obj/nek_in_situ.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f -o obj/drive1_cmt.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive2_cmt.f -o obj/drive2_cmt.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:240.30:
            call copy(U(1,1,1,2,e),vx(1,1,1,e),nxyz1)
                              1
Warning: Array reference at (1) is out of bounds (2 > 1) in dimension 4
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:241.30:
            call copy(U(1,1,1,3,e),vy(1,1,1,e),nxyz1)
                              1
Warning: Array reference at (1) is out of bounds (3 > 1) in dimension 4
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:242.30:
            call copy(U(1,1,1,4,e),vz(1,1,1,e),nxyz1)
                              1
Warning: Array reference at (1) is out of bounds (4 > 1) in dimension 4
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:243.30:
            call copy(U(1,1,1,5,e),t(1,1,1,e,3),nxyz1)
                              1
Warning: Array reference at (1) is out of bounds (5 > 1) in dimension 4
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:243.45:
                                             1
Warning: Array reference at (1) is out of bounds (3 > 1) in dimension 5
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/drive1_cmt.f:244.45:
            call copy(U(1,1,1,1,e),t(1,1,1,e,2),nxyz1)
                                             1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f -o obj/driver3_cmt.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:16.42:
         call invcol3(vx(1,1,1,e),u(1,1,1,irpu,e),u(1,1,1,irg,e),nxyz)
                                          1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:17.42:
         call invcol3(vy(1,1,1,e),u(1,1,1,irpv,e),u(1,1,1,irg,e),nxyz)
                                          1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:19.42:
         call invcol3(vz(1,1,1,e),u(1,1,1,irpw,e),u(1,1,1,irg,e),nxyz)
                                          1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:23.27:
     >             u(1,1,1,irpu,e),u(1,1,1,irpv,e),u(1,1,1,irpw,e),
                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:23.43:
                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:23.59:
                                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:24.27:
     >             u(1,1,1,irpu,e),u(1,1,1,irpv,e),u(1,1,1,irpw,e),nxyz)
                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:24.43:
                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:24.59:
                                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:26.35:
            call vdot2(scr,u(1,1,1,irpu,e),u(1,1,1,irpv,e),
                                   1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:26.51:
                                                   1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:27.35:
     >                     u(1,1,1,irpu,e),u(1,1,1,irpv,e),nxyz)
                                   1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:27.51:
                                                   1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/driver3_cmt.f:64.24:
         vtrans(i,j,k,e,icv)= cv*rho
                        1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/face.f -o obj/face.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/ausm.f -o obj/ausm.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/MixtPerf.f -o obj/MixtPerf.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/intpdiff.f -o obj/intpdiff.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/diffusive_cmt.f -o obj/diffusive_cmt.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diffusive_cmt.f:305.26:
            vdiff(i,1,1,e,ilam) = lambda
                          1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f -o obj/eqnsolver_cmt.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:149.37:
     >                 vdiff(1,1,1,e,ilam),
                                     1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:151.38:
     >                 vtrans(1,1,1,e,icv))
                                      1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:209.20:
      common /ctmp1/ ur(ldd),us(ldd),ut(ldd),ju(ldd),ud(ldd),tu(ldd)
                    1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/surface_fluxes.f -o obj/surface_fluxes.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:261.20:
                    1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:331.40:
     &                       +  U(i,j,k,4,e)*FFZ)/ U(i,j,k,1,e)
                                        1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:330.59:
               usrf(i,j,k,5) = (U(i,j,k,2,e)*FFX + U(i,j,k,3,e)*FFY
                                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/eqnsolver_cmt.f:330.40:
                                        1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/surface_fluxes.f:41.37:
      call fillq(icvf,vtrans(1,1,1,1,icv),fatface(iqm),fatface(iqp))
                                     1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/surface_fluxes.f:46.40:
         call fillq(ilamf,vdiff(1,1,1,1,ilam),fatface(iqm),fatface(iqp))
                                        1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/bc.f -o obj/bc.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/inflow_bc.f -o obj/inflow_bc.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/outflow_bc.f -o obj/outflow_bc.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/wall_bc.f -o obj/wall_bc.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/step.f -o obj/step.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/filters_cmt.f -o obj/filters_cmt.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ /scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f -o obj/diagnostics.o
mpif77 -c  -O3 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I./ /scratch/user/fatihsinan/NEK/trunk/nek/mxm_std.f -o obj/mxm_std.o
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:80.44:
         call copy(otvar(1,1,1,e,2),u(1,1,1,2,e),n)
                                            1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:81.44:
         call copy(otvar(1,1,1,e,3),u(1,1,1,3,e),n)
                                            1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:82.44:
         call copy(otvar(1,1,1,e,4),u(1,1,1,4,e),n)
                                            1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:83.44:
         call copy(otvar(1,1,1,e,5),u(1,1,1,5,e),n)
                                            1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:192.33:
     $         ,rhseqs(1),rhseqs(2),rhseqs(3),rhseqs(4)
                                 1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:192.43:
                                           1
Warning: Array reference at (1) is out of bounds (3 > 1) in dimension 1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:192.53:
                                                     1
Warning: Array reference at (1) is out of bounds (4 > 1) in dimension 1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:193.23:
     $         ,rhseqs(5)
                       1
Warning: Array reference at (1) is out of bounds (5 > 1) in dimension 1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:205.33:
                                 1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:205.43:
                                           1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:205.53:
                                                     1
/scratch/user/fatihsinan/NEK/trunk/nek/cmt/diagnostics.f:206.23:
     $         ,rhseqs(5)
                       1
mpif77 -c  -O0      -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I./ /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f -o obj/blas.o
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set       -I/scratch/user/fatihsinan/MOAB/hdf5/hdf5-1.8.16/gcc/include -isystem /scratch/user/fatihsinan/MOAB/hdf5/hdf5-1.8.16/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DHAVE_ZOLTAN -I/scratch/user/fatihsinan/MOAB/moab_nek/trunk-test/gcc/include  /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f -o obj/moab.o
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/MOABCORE:21:
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/NEKMOAB:53:
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:79:
      parameter(lelcmt = 1  ) ! # of cmt elements
                      1
Error: Symbol 'lelcmt' at (1) has no IMPLICIT type
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:121:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:131.23:
      pointer (tagv_ptr, tag_vals(1))
                       1
Warning: Cray pointer at (1) has 4 bytes of precision; memory addresses require 8 bytes
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:132.22:
      pointer (adj_ptr, adjs(1))
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:133.24:
      pointer (verts_ptr, verts(1))
                        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:134.24:
      pointer (elems_ptr, elems(1))
                        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:135.25:
      pointer (offset_ptr, offset(1))
                         1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:218:
                      1
GEOM:62.26:
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:219:
     $             ,etalph(lx1*lz1,2*ldim,lelt)
                          1
Error: Symbol 'etalph' at (1) has no IMPLICIT type
PARALLEL:35.45:
      common /xcdg_ints/   dg_hndlx,ndg_facex
                                             1
Error: Symbol 'ndg_facex' at (1) has no IMPLICIT type
GEOM:49.23:
      COMMON /GSURF/unr   (lx1*lz1,6,lelt)
                       1
Error: Symbol 'unr' at (1) has no IMPLICIT type
GEOM:50.23:
     $             ,uns   (lx1*lz1,6,lelt)
                       1
Error: Symbol 'uns' at (1) has no IMPLICIT type
GEOM:51.23:
     $             ,unt   (lx1*lz1,6,lelt)
                       1
Error: Symbol 'unt' at (1) has no IMPLICIT type
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:265:
                      1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:281:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:9764.15:
      GO TO IGO,(120,150,180,210)
               1
Warning: Deleted feature: Assigned GOTO statement at (1)
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:9770.72:
               ASSIGN 120 TO IGO
        1
Warning: Deleted feature: ASSIGN statement at (1)
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:9782.72:
               ASSIGN 150 TO IGO
        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:9795.72:
               ASSIGN 180 TO IGO
        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:9806.72:
               ASSIGN 210 TO IGO
        1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:414:
                      1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:456:
                      1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:497:
                      1
PARALLEL:35.45:
                                             1
mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input -fcray-pointer -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG -I/scratch/user/fatihsinan/NEK/examples/moab -I/scratch/user/fatihsinan/NEK/trunk/nek -I/scratch/user/fatihsinan/NEK/trunk/nek/cmt -I./ -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set       -I/scratch/user/fatihsinan/MOAB/hdf5/hdf5-1.8.16/gcc/include -isystem /scratch/user/fatihsinan/MOAB/hdf5/hdf5-1.8.16/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DHAVE_ZOLTAN -I/scratch/user/fatihsinan/MOAB/moab_nek/trunk-test/gcc/include  /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/imeshutil.f -o obj/imeshutil.o
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:557:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:564.21:
      pointer(tag_ptr, nekid(1))
                     1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:732:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:820.21:
      pointer(tag_ptr, gid(1))
                     1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:823:
                      1
PARALLEL:35.45:
                                             1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:864:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:874.26:
      pointer (connect_ptr, connect(0:1))
                          1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:924:
                      1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:927.25:
      pointer(connect_ptr, connect(0:1))
                         1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:971:
                      1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:1033:
                      1
mpicc -c  -O2 -DMOAB -DMPI -DUNDERSCORE -DGLOBAL_LONG_LONG  /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/imeshcutil.c -o obj/imeshcutil.o
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:1158:
                      1
PARALLEL:35.45:
                                             1
    Included at /scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/moab.f:1174:
                      1
Fatal Error: Error count reached limit of 25.
make: *** [obj/moab.o] Error 1
make: *** Waiting for unfinished jobs....
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:17277.15:
               1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:17283.72:
               ASSIGN 120 TO IGO
        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:17295.72:
               ASSIGN 150 TO IGO
        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:17308.72:
               ASSIGN 180 TO IGO
        1
/scratch/user/fatihsinan/NEK/trunk/nek/3rd_party/blas.f:17319.72:
               ASSIGN 210 TO IGO
        1
