[Nek5000-users] Full restart with a different time step
Tue Nov 17 17:24:07 CST 2015
Hi Adam,
Thank you very much for your comments.
I actually thought about loading the 4 restart files in nek and do interpolation between two time steps. But I agree with you that I would introduce some error to the flow fields for restarting. In my case, I want to keep the data of the old simulation and continue from the current checkpoints, so I don't want to ruin the accuracy of the flow fields.
Like you said, changing \dt after restarting from the current flow fields maight be the simplest solution. However, I have one concern about this. When we use 3rd order accuracy in time, the solver would use the history information from the last few time steps and that's why we need to restart the simulation with 4 continuous flow fields. If I change the time step size in the middle of the simulation, how much would it affect the solving process? What do you think?
Best regards,
Tony
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users-request at lists.mcs.anl.gov <nek5000-users-request at lists.mcs.anl.gov>
Sent: 17 November 2015 18:00
To: nek5000-users at lists.mcs.anl.gov
Subject: Nek5000-users Digest, Vol 81, Issue 15
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Full restart with a different time step
      (nek5000-users at lists.mcs.anl.gov)
   2. Re: Full restart with a different time step
Message: 1
Date: Mon, 16 Nov 2015 19:19:23 +0000
To: "nek5000-users at lists.mcs.anl.gov"
        <nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] Full restart with a different time step
Message-ID:
        <mailman.10777.1447701586.24727.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Dear Neks,
I use full_restart option for my current simulations. One simulation crashed after restarting for some time with the Courant number going crazy. I suppose I will need to reduce the time step size.
Basically, I want to continue my simulation using full_restart option but with a smaller time step size. Somehow I remember I saw one post saying one shouldn't change the time step size when using the full_restart option. I'm just thinking of a way to work around the problem.
So does anyone have ideas on how I can interpolate the flow fields between two time steps or any other ways to fully restart a simulation with a different time step size?
Thank you very much in advance for any suggestions or comments.
Best regards,
Tony
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151116/ff31eb4f/attachment-0001.html>
Message: 2
Date: Tue, 17 Nov 2015 09:27:47 +0100
Subject: Re: [Nek5000-users] Full restart with a different time step
Message-ID:
        <mailman.10819.1447748894.24727.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Hi
For full_restart you should have four velocity fields and you could use
nek5000 as a preprocessing tool. You can simply load all 4 fields in
userchk, perform some kind of interpolation in time and finally write
down new restart files. The question is how to deal with pressure. One
solution would be simply interpolate pressure saved in the files. The
other would be to run modified version of pressure solver with uzawa
turned on to get pressure corresponding to interpolated velocity field.
We've played with uzawa for pn-pn-2 and we use our version of
full_restart, but we haven't done this kind of modified restart, so I
don't know what is better. On the other hand you could restart nek with
your current checkpoints and dt corresponding to the old simulation, and
later (after 4th step) gradually decrease time step. I guess this would
be the simplest and probably best solution. If time resolution in old
simulation was insufficient, your restart files do not give correct
evolution of the field and interpolation in time would not remove it.
Anyhow you introduce some initial error to simulation. In this case I
probably would simply play with dt keeping it constant during first 4
steps and gradually decreasing later.
Regards
Adam
On 2015-11-16 20:19, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> problem.
> Best regards,
> Tony
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151117/7d8c9274/attachment-0001.html>
End of Nek5000-users Digest, Vol 81, Issue 15
