[Nek5000-users] Full restart with a different time step
Tue Nov 17 02:27:47 CST 2015
Hi
For full_restart you should have four velocity fields and you could use
nek5000 as a preprocessing tool. You can simply load all 4 fields in
userchk, perform some kind of interpolation in time and finally write
down new restart files. The question is how to deal with pressure. One
solution would be simply interpolate pressure saved in the files. The
other would be to run modified version of pressure solver with uzawa
turned on to get pressure corresponding to interpolated velocity field.
We've played with uzawa for pn-pn-2 and we use our version of
full_restart, but we haven't done this kind of modified restart, so I
don't know what is better. On the other hand you could restart nek with
your current checkpoints and dt corresponding to the old simulation, and
later (after 4th step) gradually decrease time step. I guess this would
be the simplest and probably best solution. If time resolution in old
simulation was insufficient, your restart files do not give correct
evolution of the field and interpolation in time would not remove it.
Anyhow you introduce some initial error to simulation. In this case I
probably would simply play with dt keeping it constant during first 4
steps and gradually decreasing later.
Regards
Adam
On 2015-11-16 20:19, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I use full_restart option for my current simulations. One simulation
> crashed after restarting for some time with the Courant number going
> crazy. I suppose I will need to reduce the time step size.
> Basically, I want to continue my simulation using full_restart option
> but with a smaller time step size. Somehow I remember I saw one post
> saying one shouldn't change the time step size when using the
> full_restart option. I'm just thinking of a way to work around the
> problem.
> So does anyone have ideas on how I can interpolate the flow fields
> between two time steps or any other ways to fully restart a simulation
> with a different time step size?
> Thank you very much in advance for any suggestions or comments.
> Best regards,
> Tony
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151117/7d8c9274/attachment.html>
