[Nek5000-users] Flow Rate Oscillation on 16384 cores
Sun Mar 29 12:57:29 CDT 2015
Hi Philipp,
Yes thanks I solved the problem. It was in fact a slight change I had to do
when converting Nek files since changing the number of cores slightly
changes the way the Nek dump is written. All is ok now.
Thank you,
jp
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150329/58361f46/attachment.html>
