[Nek5000-users] Output data format and VisIt issue
Sun Mar 15 14:50:53 CDT 2015
indeed, VisIt even in the latest version does not read the 8-byte format
properly. The problem, in fact, is mainly related to the computations of
the limits (at least in 2D), and by just setting these manually (in
Controls/View) it can be corrected. The data appears to be read in
without problem.
Jing has analysed the source code of the Nek reader, and fixed the
corresponding parts; he has already sent it further to the VisIt
developers, and hopefully the next version will read 8-byte files as well.
Regarding the restart with 4-byte files, I guess the answer is that it
depends on the case and the requirements on accuracy you have. In my
opinion, for stability calculations you will not only need 8-byte files,
but also the restart from 4 files (aka proper restart). Similar
observations we have made for high-Reynolds-number turbulence. On the
other hand, for low-Re cases I guess there is not much of a problem.
Best regards,
Philipp
On 2015-03-15 20:16, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> Recently I've been playing with VisIt and it seems there is still
> problem reading nek5000 output data in 8-byte format. VisIt reads 4-byte
> output data successfully but not 8-byte. Is it essential to output data
> in 4-byte format if I want to use VisIt (ParaView actually can handle
> both data format well)?
> Also, in terms of continuing simulations, would 4-byte precision affect
> the restarting condition?
> Hope anyone can help. Thank you very much in advance.
> Kind regards,
> Tony
> Nek5000-users mailing list
