[Nek5000-users] Metadata files
Sat Mar 14 21:20:57 CDT 2015
Thanks for your help, but I'm not sure I understand. What do you mean by
out posting the files?
On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi David,
>  Which files are you referring to? Your own output files or nek outpost
> generated ones? The easiest would be to just make a call to outpost and
> overwrite the velocity fields and pressure, and use a different name than
> your current SESSION, instead of writing out your own data file.
>  In this way you can still use the script 'visnek' to create a Visit
> readable file (the format visit has for nek is .nek5000 which looks very
> simple to tweak if needed).
>  Hope I understood your problem correctly,
> Oana
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Sunday, March 01, 2015 9:32 AM
> *To:* Nek Mailing List
> *Subject:* [Nek5000-users] Metadata files
>   Hi all,
> Would someone be able to help me create a Metadata file, so I can upload
> my results into VisIt? I'm under the impression that you have to create a
> new file, is that correct? Thanks.
> David H.
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150314/e688f0b1/attachment.html>
