[Nek5000-users] Metadata files
Sun Mar 1 09:48:01 CST 2015
Hi David,
Which files are you referring to? Your own output files or nek outpost generated ones? The easiest would be to just make a call to outpost and overwrite the velocity fields and pressure, and use a different name than your current SESSION, instead of writing out your own data file.
In this way you can still use the script 'visnek' to create a Visit readable file (the format visit has for nek is .nek5000 which looks very simple to tweak if needed).
Hope I understood your problem correctly,
Oana
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Sunday, March 01, 2015 9:32 AM
To: Nek Mailing List
Subject: [Nek5000-users] Metadata files
Hi all,
Would someone be able to help me create a Metadata file, so I can upload my results into VisIt? I'm under the impression that you have to create a new file, is that correct? Thanks.
David H.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150301/a924c33d/attachment.html>
