[Nek5000-users] Compilation of nek5000 in ubuntu
Wed Jan 14 05:49:19 CST 2015
    Hi Simon,
    Could you try this ' export LD_LIBRARY_PATH=/usr/local/opempi/lib '
and then launching "./makenek eddy_uv".
    If that does not help, There are a couple of things to do :
   1) sudo apt-get update
   2) sudo apt-get upgrade
   3) Sudo apt-get install build essential
   do the above commands to install some Linux libraries and try
recompiling openmpi with ' ./configure --prefix=/usr/local/openmpi
FC=/usr/local/gfortran (path of your gfortran).
    just take look at the output when you do ' sudo make ' and see If
everything is going perfectly.
    Best,
    Kamal
    PS: Check If your gfortran works properly
On 14/01/2015 12:31, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> I am really thankful that you give so detailed information on
> compilation of Open-mpi. Everything went well when following your
> first 4 steps except for Step 5 in which creation of dir
> /sur/local/openmpi/share was denied. So I re-do Step 5 with command
> "sudo make check install", and then it compiled well without errors.
> Then I followed Step 6 but it was found that no mpif77 nor mpicc files
> were under dir /use/local/openmpi/. After checking files under dir
> /use/local/openmpi/bin, there exist mpiff77 and mpicc files. So
> finally I changed makenek to "F77 = /usr/local/openmpi/bin/mpif77" and
> " CC = /usr/local/openmpi/bin/mpicc" and then type "./makenek eddy_uv".
> Unluckily, the error came again as following:
> Unfortunately, this installation of Open MPI was not compiled with
> Fortran 77 support.  As such, the mpif77 compiler is non-functional.
> FATAL ERROR: Basic compiler test for /usr/local/openmpi/bin/mpif77 failed!
> It seems fortran 77 not ready yet. Do you have any comments about it?
> Thanks,
> Simon
> *From:* nek5000-users-bounces at lists.mcs.anl.gov
> <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
> nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> *Sent:* Wednesday, 14 January, 2015 5:58 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Compilation of nek5000 in ubuntu
>   Hi Simon,
>    1) Download the Open-Mpi file from here :
> www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.4.tar.gz,
> unpack it
>    2) Create a folder ' sudo mkdir  /usr/local/openmpi '
>    3) Go to the unpacked openmpi-1.8.4 folder and do ./configure
> --prefix = /usr/local/openmpi
>    4) Then just type ' make '
>    5) Then ' make check install '
>    This will install open-mpi in the folder /usr/local/openmpi, now
> your mpi files will be in this folder.
>    6) Open makenek and change ' F77 = /use/local/openmpi/mpif77 ' and
> ' CC = /usr/local/openmpi/mpicc '  or you can the path to ./bashrc
> file if you don't want to do this step.
>    I hope this should work for you.
>  Best Regards,
>   Kamal
> On 14/01/2015 10:24, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Kamal,
>> Thank you very much for the suggestion. As I am a Linux user at very
>> basic level, could you please tell a little bit more details on
>> reinstalling open-mpi? Are u suggesting me reinstall the same version
>> as installed in ubundu, or any other version? If it should be a
>> certain version, I will download and install in.
>> To tell the truth, I installed a package f2c that can translate
>> fortran77 to c language, but it does not help here. Do you think do u
>> have to install fortran77 in Ubuntu? It is said installing f77 will
>> cause more errors in the latest version of Ubuntu.
>> Thanks for your reply again.
>> Sincerely,
>> Simon
>> On 14 Jan, 2015, at 5:08 pm, "nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>"
>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>>   Hi Simon,
>>>   I would suggest you to reinstall OPEN-MPI in ubuntu and use mpif77
>>> compiler.
>>>   Best,
>>>   Kamal
>>>  PS: Install Open Mpi in a separate folder and the add the path in
>>> ./bashsrc or to the makenek directly
>>> On 14/01/2015 09:30, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi there,
>>>> I am compiling the eddy example in my ubuntu OS, but the system
>>>> returns error with "*Error: Can't open included file 'mpif.h'*".
>>>> The fortran compiler in makenek file was changed to gfortran since
>>>> mpif77 gives error:
>>>> **Unfortunately, this installation of Open MPI was not compiled with**
>>>> **Fortran 77 support.  As such, the mpif77 compiler is
>>>> non-functional.**
>>>> **FATAL ERROR: Basic compiler test for mpif77 failed!*
>>>> Is there anyone experience the same problem when compiling in
>>>> ubuntu? You assistance will be greatly appreciated.
>>>> Sincerely,
>>>> Simon
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150114/6fcce9e0/attachment-0001.html>
