[Nek5000-users] Failed in Helmholtz
Wed Dec 2 13:55:00 CST 2015
Dear Neks,
I'm solving a jet problem with a very simple geometry but the simulation keeps crashing. The error in the logfile is "Failed in Helmholtz" and when I post process the results, it appears that the simulation crashes when the jet hits the outflow boundary. I'm using the turb_outflow routine and have verified it by running the turbJet example in the repository. However, when I use my own mesh, created in prex, the same case (or even a simpler case with a lower Reynolds number) always seems to fail. Laminar cases, however, work fine. I have included my usr, rea, SIZE and logfiles. Any help is appreciated.
Thank you,
Goran Marjanovic
Graduate Research Assistant
Center for Compressible Multiphase Turbulence
Mechanical and Aerospace Engineering
University of Florida
<mailto:gmarjanovic at ufl.edu>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/5b986c50/attachment-0001.html>
Desc: jet.log1
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/5b986c50/attachment-0004.obj>
Desc: jet.rea
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/5b986c50/attachment-0005.obj>
Desc: jet.usr
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/5b986c50/attachment-0006.obj>
Desc: SIZE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/5b986c50/attachment-0007.obj>
