[Nek5000-users] find a point
Tue Dec 1 17:14:00 CST 2015
Thanks for your answers!
I think I found the routine that is right for me:
call findpts(h, code_base,  code_stride,
                  proc_base,  proc_stride,
                    el_base,    el_stride,
                     r_base,     r_stride,
                 dist2_base, dist2_stride,
                     x_base,     x_stride,
                     y_base,     y_stride,
                     z_base,     z_stride, npt)
nevertheless I didn't understand the meaning of some variables. I think
that I can set the *_stride parameters equal to 1 for my case because i
should follow just one point. "code_base" return 0 if is in the element, 1
if it is on the border and 2 if it is out. "proc_base" the processor that
have the element ("el_base") in which the point is located. "x_base",
"y_base" and "z_base" are the coordinates of the input point. But is not
clear for me the means of "r_base", "dist2_base" and "h". Moreover I should
give in input the "h" value and I saw that "h" is the output
of findpts_setup function or intpts_setup if I use the routine defined in
postpro.f that wrap the findpts_setup routine. However in both cases it is
not clear for me what "h" represents.
Other question, are *_base values global variables or local? namely, does
each processor know that the investigated point is contained in the el_base
element?
Alessandro
2015-12-01 18:39 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
> in postpro.f there is a Fortran routine hpts which acts as a driver to the
> various hpts... routines. I guess from reading that subroutine you can
> figure out how to call the various operations. You can also use these
> routines to find out on what processor and in what element a certain point
> is located.
> philipp
> On 2015-12-01 17:35, nek5000-users at lists.mcs.anl.gov wrote:
>> Yes, the routines in findpts.c are your friends. Have a look at hpts()
>> to see how it works.
>> Cheers,
>> Stefan
>> Von: <nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>>
>> Antworten an: <nek5000-users at lists.mcs.anl.gov
>> Datum: Tuesday, December 1, 2015 at 7:02 PM
>> An: <nek5000-users at lists.mcs.anl.gov
>> Betreff: [Nek5000-users] find a point
>> Hi Neks,
>> Given a point P(x,y,z) (even not grid point), is there in Nek a fast way
>> to found in which element it is located and also the corresponding
>> processor?
>> sincerely
>> Alessandro
>> _______________________________________________ Nek5000-users mailing
>> list Nek5000-users at lists.mcs.anl.gov
>> <mailto:Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151202/98d5570b/attachment.html>
