[Nek5000-users] Infinite Prandtlnumber with Nek5000
Mon Aug 17 03:55:36 CDT 2015
Hello Lailai,
I see oscillations in the velocity field with a period dependent on the
time step (shorter timesteps result in faster oscillations), which only
decay very slowly. I haven't tested increasing the resolution here, this
might  be the reason. However, the method outlined by Paul seems to work
fine at the same resolutions and converges very fast. The big caveat
here is that I haven't tested the results against other codes or
theoretical predictions yet. I am not working on the subject of inf.
Prandtlnumber flows myself, but other members of my group were
interested in Nek5000, so I gave it a try.
Cheers,
Jan
On 08/15/2015 12:43 AM, nek5000-users at lists.mcs.anl.gov wrote:
> hello, Jan,
> great that you have tested them. I always want to try, but am too lasy...
> Could you say a little bit about the aphysical
> oscillations? Do you see oscillations for one iteration, or they
> appear because of the
> time stepping approach I suggested? Sometimes I indeed see this in the
> velocity field
>  for a low-quality mesh with low GLL numbers, normally the spatial
> velocity oscillations
> are gone by either using a mesh with better quality (same GLL) or
> increasing the number GLL points for
> the same mesh.
> I think the way suggested by Paul will significantly speedup the
> simulation compared to the way
> I suggested, although trivial inertia is introduced.  have you
> observed the speedup?
> thanks,
> lailai
> On 2015/8/14 9:00, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> thanks for the advice. I tested some simple 2D cases and the method
>> seems to work quite good. The idea in the other posts had a tendency
>> to produce unphysical oscillations. We might look into testing Nek
>> against other mantle convection codes, where varying viscosity and
>> parallelisation is still a problem.
>> Thanks again,
>> Jan
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Jan Vormann
Institut für Geophysik
Corrensstr. 24
D-48149 Münster
