[Nek5000-users] Infinite Prandtlnumber with Nek5000
Fri Aug 14 17:43:43 CDT 2015
hello, Jan,
great that you have tested them. I always want to try, but am too lasy...
Could you say a little bit about the aphysical
oscillations? Do you see oscillations for one iteration, or they appear
because of the
time stepping approach I suggested? Sometimes I indeed see this in the
velocity field
  for a low-quality mesh with low GLL numbers, normally the spatial
velocity oscillations
are gone by either using a mesh with better quality (same GLL) or
increasing the number GLL points for
the same mesh.
I think the way suggested by Paul will significantly speedup the
simulation compared to the way
I suggested, although trivial inertia is introduced.  have you observed
the speedup?
thanks,
lailai
On 2015/8/14 9:00, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> thanks for the advice. I tested some simple 2D cases and the method
> seems to work quite good. The idea in the other posts had a tendency
> to produce unphysical oscillations. We might look into testing Nek
> against other mantle convection codes, where varying viscosity and
> parallelisation is still a problem.
> Thanks again,
> Jan
> Nek5000-users mailing list
Lailai Zhu
Laboratory of Fluid Mechanics and Instabilities LFMI
EPFL STI IGM LFMI ME A2 408 (Bâtiment ME) Station 9
CH-1015 Lausanne Switzerland
