[Nek5000-users] MPI_TAG_UB too small
Fri Apr 3 16:59:21 CDT 2015
Dear Tony,
we aim at committing the necessary changes to the repository by Monday.
Hope that this is fine.
Best regards,
Philipp
On 2015-04-03 20:22, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Philipp,
> I see. Thank you very much for the explanation. It would be great if you could help me make relevant changes or send me the files you mentioned if that is at all possible.
> Best regards,
> Tony
> From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users-request at lists.mcs.anl.gov <nek5000-users-request at lists.mcs.anl.gov>
> Sent: 03 April 2015 18:00
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Nek5000-users Digest, Vol 74, Issue 2
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. MPI_TAG_UB too small (nek5000-users at lists.mcs.anl.gov)
>    2. Re: MPI_TAG_UB too small (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Fri, 3 Apr 2015 12:04:14 +0000
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users at lists.mcs.anl.gov"
>         <nek5000-users at lists.mcs.anl.gov>
> Subject: [Nek5000-users] MPI_TAG_UB too small
> Message-ID:
>         <mailman.1264.1428062661.14701.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="iso-8859-1"
> Dear Neks,
> I'm having a problem running my simulation with thousands of processors. In my case, I have 6090000 elements and I ran the simulation with 8520 procs. However, the simulation aborted with the error message 'MPI_TAG_UB too small'.
> I checked the code and found that if "nval.lt.(10000+max(lp,lelg))", the simulation would abort. But in the subroutine 'mpi_attr_get', ival is set to be 9999999. In this case, nval should be larger than 10000+max(lp,lelg). So, why did the simulation not run?
>  Hope anyone can help me on this. Thank you very much.
> Best regards,
> Tony
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150403/8f2d0483/attachment-0001.html>
> Message: 2
> Date: Fri, 03 Apr 2015 18:04:16 +0200
> Subject: Re: [Nek5000-users] MPI_TAG_UB too small
> Message-ID:
>         <mailman.1287.1428077071.14701.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> Dear all,
> indeed, we have experienced the same problem with the recent Cray MPI
> Library; the maximum tag size was reduced to 2**21 (the MPI standard
> requires 2^16, but most libraries have 2^32). The problem in Nek is that
> in the initial distribution of the mesh and velocities onto the
> processors, the element number is used as a message tag, which obviously
> fails if you have more than 2**21 elements. The check you mention
> (nval.lt.(10000+max(lp,lelg)) is exactly checking that (mpi_dummf.f is
> only used in serial runs, in parallel runs mpi_attr_get is a routine
> provided by the current mpi library and returns the maximum tag number
> of the implementation).
> Anyway, we have recently fixed this problem by changing the way the tag
> is used (local element number vs global one). Maybe the easiest would be
> to merge these changes in the repo? Otherwise, I can also send the
> changed files, but then of course one has to be careful to have matching
> revisions.
> Best regards,
> Philipp
> On 2015-04-03 14:04, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Neks,
>> Best regards,
>> Tony
>> Nek5000-users at lists.mcs.anl.gov
> End of Nek5000-users Digest, Vol 74, Issue 2
