[Nek5000-users] mesh merging
Thu Apr 2 00:44:00 CDT 2015
Dear all,
I have decided a cylinder-box-transition mesh (box hole at centre), with
another mesh in box. I tried to use prenek to merge them, but the curved
side values vanish and error comes in -
2773     2     4  Matrix:  SELF!!
       1 SELF!!     1189     1377     1189     1377
       2 SELF!!     1360     1206     1360     1206
 cont: SELF!!        2773   ??
 ABORT: SELF-CHK            1           5        2773           0
 Try to tighten the mesh tolerance!
  3024     8    10  Matrix T:  slfchk     3024        0
Then I tried to check the meshes individually. I set up the BCs on prenek
and output a new .rea. Both works fine.
Again I tried another way out - nekmerge. It gives me error only when I
input the cylinder mesh -
At line 100 of file reader.f (unit = 10, file = 'box1.rea')
Fortran runtime error: Bad value during floating point read
Which was not encountered in box mesh.
Anyone knows the solution? Thank you very much.
Simon
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150402/70dca9f3/attachment.html>
