[Nek5000-users] Parallel issue: Inflow conditions from external files
Tue Sep 30 06:38:23 CDT 2014
Thank you Paul. It works!
About your first proposal, I've saved the file in ascii .fld format, but
I cannot restart my simulation if the file is not .f0000. I've set
param(67)=0, but it seems not to recognize the header. It should work,
shouldn't it? Or is there anything that I'm missing in the restart
options, if I work in parallel...?
Best
SL
El 27-09-2014 16:21, nek5000-users at lists.mcs.anl.gov escribió:
> OK... regarding my suggestion about .f0000 .fld, it's actually not the
> correct approach
> for BCs (which I now see was the original request)... Sorry about that!
> The code snippet still holds, but again, some sophistication is
> required because you
> really need to understand which elements are to receive boundary
> conditions, etc.
> Even in serial, this is a nontrivial issue because the approach would
> vary from one
> mesh to the next.  But hopefully the code I sent will point you in the
> right direction
> concerning the parallel apporach.
> Best, Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Saturday, September 27, 2014 8:31 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Parallel issue: Inflow conditions from
> external files
> Dear All,
> You need to understand something about distributed memory parallel
> computing to
> be able to read files.
> My suggestion would be to write your file into the .fld or f0000
> format and restart from that,
> since Nek provides a parallel read.
> Otherwise, you have to think carefully about the reading process,
> whether you have
> enough memory per node for a since process to read the file, whether
> it will take so
> long that you need parallel I/O, etc.   There is not a one-size-fits
> all solution (save for
> the above suggestion) because for small files it's possible to write
> something in 10 minutes
> whereas for large files much more sophistication is required in order
> to meet the
> time and memory constraints.
> If you want to read a small file, you would do something like:
>       common /scrns/ u(lx1,ly1,lz1,lelg),work(lx1,ly1,lz1,lelg)
>       if (istep.eq.0) then
>          nxyz = nx1*ny1*nz1
>          n = nelgv*nxyz
>          call rzero(u,n)   ! zero-out u on all processors
>          if (nid.eq.0) then
>             read(44,*) (u(k),k=1,n)
>          endif
>          call gop(u,work,'+  ',n)  ! add result across all processors
>          do e=1,nelv
>               eg = lglel(e)
>               call copy(vx(1,1,1,e),u(1,1,1,eg),nxyz)
>          enddo
> ...The danger here is that it is slow (because it is serial) and that
> you run out memory because you are allocating memory that is
> the size of the entire problem (i.e., not size-of-problem divided by P,
> the number of processors).
> For small processor counts it might be ok.... depending on how
> big the simulation etc.
> If you take this approach, however, it will not scale when you start
> running
> serious simulations.
> Paul
> Sent: Friday, September 26, 2014 5:52 AM
> external files
> Hi,
> Did you manage to solve the problem? I also have the same problem... I
> am able to read velocity data and to set them as initial condition in
> serial, but in parallel it is not working... The velocity is mapped to
> nodes that are not the proper ones...
> What is wrong?
> Thanks!
> SL
> El 10-09-2014 13:08, nek5000-users at lists.mcs.anl.gov escribió:
>> Hi all,
>> I have a question on how to read in information from external files as
>> an inflow boundary condition when running in parallel.
>> Similar problem to this:
>> http://lists.mcs.anl.gov/pipermail/nek5000-users/2010-December/001151.html
>> [1]
>> My geometry is a simple 3D rectangle prism with the inlet on the Y-Z
>> plane @ x=0.
>> I have developed some code that reads in a 2D plane of velocity data
>> from another simulation (in this case fluent) as the boundary
>> condition in userbc(). I am happy to share the process and the code
>> (Fortran input/output from NEK, and MATLAB to do interpolation)
>> however here I am primarily focused on getting it working in parallel.
>> The process works fine in serial - it reads in 3 files (01.dat,
>> 02.dat, 03.dat) that hold the x,y,z velocity (respectively) for each
>> node on the inlet.
>> However it does not work correctly when running in parallel - looking
>> at the results after a few iterations shows that the velocities are
>> being mapped to nodes that are not all on the inlet. It does compile
>> and run though.
>> I'd sincerely appreciate any the help in making it work.
>> Warm regards,
>> Tom
>> I have included my .usr file below.
>> C-----------------------------
>> C  nek5000 user-file template
>> C
>> C  user specified routines:
>> C     - userbc : boundary conditions
>> C     - useric : initial conditions
>> C     - uservp : variable properties
>> C     - userf  : local acceleration term for fluid
>> C     - userq  : local source term for scalars
>> C     - userchk: general purpose routine for checking errors etc.
>> C
>> C-----------------------------------------------------------------------
>>       subroutine uservp(ix,iy,iz,eg) ! set variable properties
>>       include 'SIZE'
>>       include 'TOTAL'
>>       include 'NEKUSE'
>>       integer e,f,eg
>> c     e = gllel(eg)
>>       udiff  = 0.0
>>       utrans = 0.0
>>       return
>>       end
>> c-----------------------------------------------------------------------
>>       subroutine userf(ix,iy,iz,eg) ! set acceleration term
>> c
>> c     Note: this is an acceleration term, NOT a force!
>> c     Thus, ffx will subsequently be multiplied by rho(x,t).
>> c
>>       include 'SIZE'
>>       include 'TOTAL'
>>       include 'NEKUSE'
>>       integer e,f,eg
>>       ffx=0
>>       ffy=0
>>       ffz=0
>>       return
>>       end
>>       subroutine userq(ix,iy,iz,eg) ! set source term
>>       include 'SIZE'
>>       include 'TOTAL'
>>       include 'NEKUSE'
>>       integer e,f,eg
>> c     e = gllel(eg)
>>       qvol   = 0.0
>>       source = 0.0
>>       return
>>       end
>>       subroutine userbc(ix,iy,iz,iside,eg) ! set up boundary
>> conditions
>> c     NOTE: This routine may or may not be called by every
>> processor
>>       include 'SIZE'
>>       include 'TOTAL'
>>       include 'NEKUSE'
>>       integer e,eg,ix,iy,iz,NELY,NELZ,egs
>>       common /myinlet/ Arrangedu(ly1,lz1,lelt),
>>      >                 Arrangedv(ly1,lz1,lelt),
>>      >                 Arrangedw(ly1,lz1,lelt)
>>       e  = gllel(eg)
>>       ux   = Arrangedu(iy,iz,eg)
>>       uy   = Arrangedv(iy,iz,eg)
>>       uz   = Arrangedw(iy,iz,eg)
>>       temp = 0.0
>>       return
>>       end
>>       subroutine useric(ix,iy,iz,eg) ! set up initial conditions
>>       include 'SIZE'
>>       include 'TOTAL'
>>       include 'NEKUSE'
>>       integer e,eg
>>       ux   = 7.235
>>       uy   = 0.0
>>       uz   = 0.0
>>       temp = 0.0
>>       return
>>       end
>>       subroutine userchk()
>>       include 'SIZE'
>>       include 'TOTAL'
>>       return
>>       end
>>       subroutine usrdat()   ! This routine to modify element
>> vertices
>>       include 'SIZE'
>>       include 'TOTAL'
>>       return
>>       end
>>       subroutine usrdat2()  ! This routine to modify mesh
>> coordinates
>>       include 'SIZE'
>>       include 'TOTAL'
>>       call read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read in
>> inlet data for BCs
>>       return
>>       end
>>       subroutine usrdat3()
>>       include 'SIZE'
>>       include 'TOTAL'
>>       return
>>       end
>> C-------------------------------------------------------------------------------
>>       subroutine read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read
>> in the inlet data
>>       include 'SIZE'
>>       include 'TOTAL'
>>       Integer    Max_Nodes,          Lun_Dat
>>       Parameter( Max_Nodes = 200000, Lun_Dat = 3)
>>       real Var_1( Max_Nodes,lx1), Var_2( Max_Nodes), Var_3(
>> Max_Nodes)
>>       real Var_4( Max_Nodes), Var_5( Max_Nodes), Var_6(
>> Max_Nodes)
>>       real Arrangedu(ly1,lz1,lelt)
>>       real Arrangedv(ly1,lz1,lelt)
>>       real Arrangedw(ly1,lz1,lelt)
>>       integer i_row( Max_Nodes), i_eg( Max_Nodes), i_y(
>> Max_Nodes)
>>       real junk
>>       integer i, j, k, l, m, n, imin, imax, N_Nodes,ze, iyz,
>> egs,egz
>>       integer fcount
>>       Character Line* 72
>>       Character  Directory* 57
>>       Parameter( Directory=
>> '/home/tom/NEK/meshControl/MultiBox/MultiBox_10/NewInlet4/')
>> c
>> 1234567890123456789012345678901234567890123456789012345678
>>       Character  Filename* 4
>>       Parameter( Filename= '.dat')
>> c                           12345
>>       character(2) fc
>> C     +-----------+
>> C     | Execution |
>> C     +-----------+
>> 1       format( 1x, a)
>>       do fcount=1,3 !for each file 01=u;02=v;03=w.
>> 37    format (I2.2)
>>       write (fc,37) fcount ! converting integer to string
>>       print *,'Readining file #: ',fc
>>       open( unit = Lun_Dat, status = 'old', form='formatted', err
>> = 2,
>>      >      file = Directory//trim(fc)//Filename)
>>       go to 3
>> 2     write( 6, 1) 'Error Opening file - EXIT'
>> 3     read( Lun_Dat, 1)  Line
>>       N_Nodes = 0
>>       do i = 1, Max_Nodes
>>          read( Lun_Dat, 11, end=5) i_row(i),  i_eg(i),
>> i_y(i),
>>      >                      Var_1(i,1),
>> Var_1(i,2), Var_1(i,3),
>>      >                      Var_1(i,4),
>> Var_1(i,5), Var_1(i,6),
>>      >                      Var_1(i,7),
>> Var_1(i,8), Var_1(i,9)
>> 11       format( i6, 1x, i5, 1x, i4, 9( 1x, 1P E16.9))
>>          N_Nodes = N_Nodes + 1
>>        if( fcount .EQ. 1) THEN
>>          iyz=i_y(i)
>>          egz=i_eg(i)
>>          do ze=1,lx1
>>          Arrangedu(iyz,ze,egz)= Var_1(i,ze)
>>          end do
>>        else if( fcount .EQ. 2) THEN
>>          iyz=i_y(i)
>>          egz=i_eg(i)
>>          do ze=1,lx1
>>          Arrangedv(iyz,ze,egz)= Var_1(i,ze)
>>          end do
>>       else if( fcount .EQ. 3) THEN
>>          iyz=i_y(i)
>>          egz=i_eg(i)
>>          do ze=1,lx1
>>          Arrangedw(iyz,ze,egz)= Var_1(i,ze)
>>          end do
>>       end if
>>       end do
>>       write( 6, 1) ' '
>>       write( 6, 1) ' WARNING - Max nodes exceeeded'
>>       write( 6, 1) ' '
>> 5     write( 6, 6) N_Nodes
>> 6     format( ' Number of nodes read = ', I8)
>>       end do
>>       end
>> Links:
>> [1]
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
