[Nek5000-users] Interfacing with Arpack
Mon Oct 27 11:17:47 CDT 2014
Hi Adam,
thanks for sharing the code, I will study it, and if I can produce
something useful I will contact you.
Best regards,
Giuseppe
On 27/10/2014 16:47, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Guiseppe
> I've just noticed you work on eigenvalue problem with arpack for
> nek5000 p_n-p_n. We've done similar work for p_n-p_n-2 and we are very
> interested in your work and we would like to share the code if it is
> possible. Our implementation of ext_cyl example you can find at
> ftp://ftp.mech.kth.se/pub/adam/Nek5000/toolbox/
> Best regards
> Adam
> On 22/10/14 13:31, nek5000-users at lists.mcs.anl.gov wrote:
>> Giuseppe,
>> There are several masks:  tmask()
>> v1mask for vx
>> v2mask for vy
>> v3mask for vz
>> pmask for pressure
>> tmask has several fields in the situation where
>> you have different boundary conditions on different
>> passive scalars.
>> Note that repeated application of one of the SEM operators
>> requires injection into H^1, which is effected through dssum
>> + mass matrix, as discussed earlier.   Subroutine ALPHAM1
>> in eigsolv illustrates this.  (It's an older routine, so it
>> uses the multiplicity array when computing this inner products.
>> That would not be necessary, however, if the inner products
>> had been computed prior to dssum.)
>> Paul
>> On Wed, 22 Oct 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Paul, thanks again for your reply. I think I am close to a
>>> solution now. One more thing: I think I need to mask out Dirichlet
>>> bc nodes when applying the matrix-vector products, right? How can I
>>> do this? Is it sufficient to call col2(u,vmask,n) after the
>>> matrix-vector product?
>>> Best,
>>> Giuseppe
>>> On 20/10/2014 16:37, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Giuseppe,
>>>> You're close.
>>>> The key point to understand is that application of Q^T arises from
>>>> continuity
>>>> requirements on the test functions (that we normally call "v" in an
>>>> abstract setting).
>>>> Everything in Nek is cast in the weak form:   Find u \in X^N_0 such
>>>> that, for all v \in X^N_0,
>>>>          a( v, u )_N =   a( v, u* )_N
>>>> where u* is the exact solution and a( . , . )_N is the
>>>> inner-product of interest, with discrete
>>>> quadrature.   For example, if
>>>>       a( v , u ) := \int_Omega  grad v . grad u  dV (1)
>>>> then a( v , u )_N would be the same bilinear form with integration
>>>> replaced by numerical
>>>> quadrature.    Note that an L2 projection would be of the form:
>>>>        ( v , u ) = ( v , u* )
>>>> where I've dropped the _N on the inner product on the working
>>>> assumption that we
>>>> always use quadrature.
>>>> Since u,v are continuous in Nek, the bilinear forms read:
>>>>             v^T  Q^T M_L Q u =   v^T Q^T M_L  u*_L
>>>> and, in nek,
>>>>               u = Binvm1 * QQ^T  BM1  u*
>>>> Note that (1), above, has the mass matrix build in because of the
>>>> volume
>>>> integral.    So, technically, if you are doing dssum, you should
>>>> have a mass
>>>> matrix present, because dssum relates to projection against the
>>>> test functions
>>>> v, which implies a volume-weighted average of the equations.
>>>> Sorry if this isn't very clear...
>>>> Paul
>>>> ________________________________________
>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>> Sent: Monday, October 20, 2014 8:21 AM
>>>> To: nek5000-users at lists.mcs.anl.gov
>>>> Subject: Re: [Nek5000-users] Interfacing with Arpack
>>>> Dear Paul,
>>>> thank you for the answer.
>>>> If my understanding is correct, since each matrix-vector product
>>>> (coded
>>>> as matrix-matrix product) is done on the local variables, I should
>>>> call
>>>> dssum after each matrix-vector operation.
>>>> For instance, if I want to apply the Helmholtz matrix to a vector u
>>>> and
>>>> store the result in v, I should do:
>>>> call axhelm(v,u,h1,h2,imsh,1)
>>>> call dssum(v,nx1,ny1,nz1)
>>>> is it correct?
>>>> If I want to apply the gradient to a vector (always for eigenvalue
>>>> computation purposes) shoud I do something like:
>>>>         call gradm1(dudx,dudy,dudz,u)
>>>>         call dssum(dudx,nx1,ny1,nz1)
>>>>         call dssum(dudy,nx1,ny1,nz1)
>>>>         call dssum(dudz,nx1,ny1,nz1)
>>>>         bufx = glsc2(u0,dudx,n)           !bufx = u0.du/dx
>>>> or am I missing something?
>>>> Giuseppe
>>>> On 20/10/2014 12:58, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Giuseppe,
>>>>> The key thing to understand about Nek is that variables are
>>>>> _always_ stored in their local format,
>>>>> which implies you have redundant values at the interface such that
>>>>> they are ready for parallel operator
>>>>> evaluation.
>>>>> Let u_L denote such a vector with redundant values (L for Local)
>>>>> and let u be the corresponding
>>>>> vector without the redundantly stored data.  Nominally, there is a
>>>>> matrix Q that maps u to u_L:
>>>>> (1)       u_L = Q u
>>>>> and the matrix-vector product involving the mass matrix, of the
>>>>> form w = M u, can be expressed as:
>>>>> (2)       w = M u =  Q^T M_L Q u  = Q^T  M_L u_L
>>>>> where M_L = block_diag(M^e) , e=1,...,Nelv is the block-diagonal
>>>>> matrix consisting of local mass
>>>>> matrices within each element, e.   In Nek, M^e is also block
>>>>> diagonal, so the whole _unassembled_
>>>>> stiffness matrix, M_L, is diagonal.   It is this matrix that is
>>>>> stored in bm1  ("B" on Mesh 1, the velocity/temp
>>>>> mesh).
>>>>> Notice that, as written, the output of (2) violates our "store
>>>>> only local vectors" policy, so we invoke
>>>>> (1) to correct this:
>>>>> (3)    w_L = Q w = Q M u =  Q Q^T  M_L u_L.
>>>>> We refer to QQ^T as direct-stiffness summation  (dssum, in nek).
>>>>> It is the operation that
>>>>> glues things together.
>>>>> So, suppose you wish to find a continuous function that is close
>>>>> to a discontinuous function
>>>>> in nek.   Let f be the continuous thing and g be the discontinuous
>>>>> one. You can do this via:
>>>>> (4)      f_L  = Q  M^-1   Q M_L g_L.
>>>>> In Nek, this would be written as:
>>>>>             n = nx1*ny1*nz1*nelv
>>>>>             call col3(f,g,bm1,n)
>>>>>             call dssum(f,nx1,ny1,nz1)
>>>>>             call col2    (f,binvm1,n)
>>>>> Here, binvm1 is  effectively   binvm1 =  1./ (QQT*bm1)   , if we
>>>>> view bm1 and binvm1 as
>>>>> vectors, rather than diagonal matrices.
>>>>> Paul
>>>>> Sent: Monday, October 20, 2014 2:03 AM
>>>>> Subject: [Nek5000-users] Interfacing with Arpack
>>>>> Dear users and developers,
>>>>> I would like to solve a generalized eigenvalue problem with Arpack,
>>>>> based on Nek subroutines. Using reverse communication interface, I
>>>>> only
>>>>> need to express the action of the matrices on the vectors, but I
>>>>> am not
>>>>> sure on how to apply the mass matrix and the inverse mass matrix
>>>>> in the
>>>>> Pn-Pn formulation.
>>>>> Is it sufficient to write:
>>>>> call col2(p1,bm1,n)      !apply mass matrix to vector p1
>>>>> call invcol2(p1,bm1,n)  ! apply inverse mass matrix to vector p1
>>>>> or should I do:
>>>>> call rzero(h1,n)
>>>>> call rone(h2,n)
>>>>> call hmholtz('vel',p,p1,h1,h2,pmask,vmult,imsh,tolh,maxiter,isd)
>>>>> to apply inverse mass matrix to p1, or should I do something else?
>>>>> Also, from a related question from a couple of years ago, should I
>>>>> call
>>>>> col2(v,vmask,n) after each matrix-vector product?
>>>>> Thank you in advance.
>>>>> Best,
>>>>> Giuseppe
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
