[Nek5000-users] outpost parallel error
Sun Oct 26 14:10:15 CDT 2014
Hi Paul,
I have solved the problem, there was indeed an error with mpi, but it
was my fault, not Arpack's.
Sorry for the inconvenience, and thanks for your help.
Best,
Giuseppe
On 26/10/2014 18:40, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Giuseppe,
> That shouldn't be an issue...
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Sunday, October 26, 2014 12:20 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] outpost parallel error
> Hi Paul,
> yes, all the arrays are declared. However, I have declared some arrays
> with the same name of some common declarations. For instance, I declare
> real*8 arrays named u,v,u0,v0. Could this be in conflict with some
> common /scruz/ declarations found in other source files?
> Thank you,
> Giuseppe
> On 26/10/2014 17:30, nek5000-users at lists.mcs.anl.gov wrote:
>> Are all your arrays properly declared in the calling routine?
>> Just trying to identify the potential issues...
>> Best,
>> Paul
>> Sent: Sunday, October 26, 2014 9:39 AM
>> My userchk is structured this way:
>>           call pdnaupd(...)
>> c   here call to nek subroutines
>> c   for matrix-vector products
>> c    if outpost is called here, it works (serial and parallel)
>> c   call to Arpack postprocessing routine:
>>           call pdneupd(...,zz,...)
>> c   zz is a matrix storing the eigenvectors
>> c   call to arpack to nek format conversion, then
>>           call outpost(v1,v2,...)      ! this gets stuck in parallel
>> note that with 1 rank this code is working well. If I comment out the
>> call to pdneupd, then it works in parallel, although it will not give
>> any useful results.
>> Giuseppe
>> On 26/10/2014 14:36, nek5000-users at lists.mcs.anl.gov wrote:
>>> If you comment out the arpack call, does it work?
>>> Sent: Sunday, October 26, 2014 2:36 AM
>>> Hi Paul,
>>> thank for the answer.
>>> I tried both removing the .sch file before each run and using outpost
>>> instead of outpost2.
>>> Unfortunately none of these solved my problem.
>>> I have checked that outpost works in parallel before the Arpack pdneupd
>>> subroutine is called, so my guess is that the Arpack subroutine is
>>> modifying some flags forcing outpost to write the .sch file, only when
>>> called by 2 or more ranks.
>>> If somebody has further comments, please let me know.
>>> Best,
>>> Giuseppe
>>> On 25/10/2014 20:39, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Giuseppe,
>>>> It looks as though you didn't remove the .sch file prior to the start
>>>> of your run?
>>>> Nek is designed to not clobber the .sch file because they can contain
>>>> information that might have resulted from very long runs.  The onus
>>>> is thus on the user to manage those files.   The usual nek scripts move
>>>> those files to blah.sch1  if there is already a blah.sch file.
>>>> It's possible, however, that something is messed up in the logic of outpost2().
>>>> That rarely gets exercised.   Is there a reason to not use outpost()?
>>>> Paul
>>>> From:nek5000-users-bounces at lists.mcs.anl.gov  [nek5000-users-bounces at lists.mcs.anl.gov] on behalf ofnek5000-users at lists.mcs.anl.gov  [nek5000-users at lists.mcs.anl.gov]
>>>> Sent: Saturday, October 25, 2014 8:58 AM
>>>> To:nek5000-users at lists.mcs.anl.gov
>>>> Subject: [Nek5000-users] outpost parallel error
>>>> Dear Neks,
>>>> in the usr file, after doing some manipulations on a known solution
>>>> (loaded from file with load_fld(...)), I save the computed values with a
>>>> call to outpost, like:
>>>>               call outpost2(u1(1,1,1,1),v1(1,1,1,1),
>>>>           &  w1(1,1,1,1),p1(1,1,1,1),
>>>>           &  p1(1,1,1,1),1,'arp')
>>>> While this is working correctly with 1 rank, in parallel it fails,
>>>> returning only the error message:
>>>> schfile:/.../myrun.sch
>>>> then it hangs for a while, with all processes consuming all the cpu time
>>>> until they are killed (so the .sch file is empty).
>>>> Does anybody have an idea on how this could be solved?
>>>> Best,
>>>> Giuseppe
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
