[Nek5000-users] Moving Wall Advice
Tue Oct 7 09:53:48 CDT 2014
Hi Mike,
No idea of whether it will work or not...I would suggest to try it and
verify (which is what I would do in that case).   In principle, it should
work ok, but I don't know that anyone has tried it for a very long time.
Note that the SIZE file for moving mesh is different from the usual one.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, October 07, 2014 9:31 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Moving Wall Advice
Paul, Oana -- thanks for the tips.
The ocyl example seems very close to what I need.
One question: Will the ALE formulation as currently implemented work if I'm solving a 2D axisymmetric-flow problem (where the temperature is used to represent the azimuthal flow component)?
Thanks again,
Mike
On Oct 7, 2014, at 8:08 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mike,
> There is also the ocyl example, which has an oscillating cylinder.
> Paul
> Sent: Friday, October 03, 2014 2:36 PM
> Subject: [Nek5000-users] Moving Wall Advice
> Hello Neks,
> I'm trying to simulate a flow where one of the boundaries is moving in a manner that requires the mesh to deform as a function of time.   In short, the conditions of the flow will determine how the boundary moves (it's a fluid-structure interaction problem, but the structure is a rigid body suspended in the fluid).
> Are there any available examples that would provide guidance?
> If not, does anyone out there want to share some wisdom?  For example, I understand that I will need IFMVBD = True, and I will need "mv" boundary conditions specified in the .rea file, but in which routine should I modify the mesh node locations and velocities?
> I found a similar question in the archive under the subject "what parameters for a moving wall induced velocity problem?" but there didn't seem to be any follow-up responses.
> Thanks in advance.
> Cheers,
> Mike
> Nek5000-users mailing list
