[Nek5000-users] Moving Wall Advice
Tue Oct 7 09:08:24 CDT 2014
Hi Mike,
There is also the ocyl example, which has an oscillating cylinder.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, October 03, 2014 2:36 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Moving Wall Advice
Hello Neks,
I'm trying to simulate a flow where one of the boundaries is moving in a manner that requires the mesh to deform as a function of time.   In short, the conditions of the flow will determine how the boundary moves (it's a fluid-structure interaction problem, but the structure is a rigid body suspended in the fluid).
Are there any available examples that would provide guidance?
If not, does anyone out there want to share some wisdom?  For example, I understand that I will need IFMVBD = True, and I will need "mv" boundary conditions specified in the .rea file, but in which routine should I modify the mesh node locations and velocities?
I found a similar question in the archive under the subject "what parameters for a moving wall induced velocity problem?" but there didn't seem to be any follow-up responses.
Thanks in advance.
Cheers,
Mike
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
