[Nek5000-users] Nekton (pre/post-processing)
Tue Nov 11 13:03:19 CST 2014
Hi Dr Fischer,
Thank you for your reply. I would like to add some question, I wonder if
there's any command to abort a command such when you've mistaken clicked
the [modify element] command or perhaps to undo it? This is because I
usually delete an element or restart the prenek whenever I've mistaken
created/modify an element as I not . Plus, I wonder of how can I obtain
nekton 2.8, since at the moment I'm using nekton 2.6 and the feature for
its menu are pretty different from the manual available online. Thank you.
Best regards,
Muhsin
On 7 November 2014 15:42, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Dear Muhsin,
>  The default is that it is always in "ADD ELEMENT" mode at the main build
> menu.
>  So you simply click in 4 locations (preferably counterclockwise) and an
> element will build.
>  Hour-glass or chevron configurations will not be generated so the newly
> entered 4 points
> will be ignored in those cases.
>  Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Friday, November 07, 2014 9:13 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] Nekton (pre/post-processing)
>   Hello,
> I am wondering if there's any manual for the nekton 2.6 out there. I have
> problem to work on with the pre-processing as menu feature provided by the
> existing manual is different with the one use in the version 2.6.
> Especially right at the beginning in the build menu (there's no ADD
> ELEMENT). Or perhaps is there any suggestion on other option of
> pre-processing. Thanks
> Best,
> Muhsin
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20141111/ede44a79/attachment.html>
