[Nek5000-users] Nekton (pre/post-processing)
Fri Nov 7 09:42:58 CST 2014
Dear Muhsin,
The default is that it is always in "ADD ELEMENT" mode at the main build menu.
So you simply click in 4 locations (preferably counterclockwise) and an element will build.
Hour-glass or chevron configurations will not be generated so the newly entered 4 points
will be ignored in those cases.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, November 07, 2014 9:13 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Nekton (pre/post-processing)
Hello,
I am wondering if there's any manual for the nekton 2.6 out there. I have problem to work on with the pre-processing as menu feature provided by the existing manual is different with the one use in the version 2.6. Especially right at the beginning in the build menu (there's no ADD ELEMENT). Or perhaps is there any suggestion on other option of pre-processing. Thanks
Best,
Muhsin
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20141107/34d1b32d/attachment.html>
