[Nek5000-users] Checking convergence to steady solution
Sat May 31 14:22:21 CDT 2014
Hi praveen,
Yes you can ..
         call opsub2(uo,vo,wo,vx,vy,vz)
         call normvc(H1,SEMI,L2,LINF,uo,vo,wo)
         residu = L2/dt
         call opcopy(uo,vo,wo,vx,vy,vz)
The subroutine
1) opsub2 computes the difference between the previous time-step and the current for velocity
uo = uo - vx ..
2) Normvc computes the L2-norm.
3) opcopy copies the [vx,vy,vz] to [uo,vo,wo] to use it for next time step
you can write the the value of residu to a separate file or to the logfile to see it.
Best regards,
Kamal
On 31 May 2014, at 21:03, nek5000-users at lists.mcs.anl.gov wrote:
> Hello neks
> I am computing flow past 2d cylinder at Re=100. To get steady solution I run the unsteady solver with selective frequency damping. Looking at the forces on the cylinder and visualizing the solution I can see that I am getting a steady solution. But I would like to also quantitatively measure the convergence to the steady state. Is there a way that I can compute some residual to measure convergence to steady state ?
> Thanks
> praveen
> Nek5000-users mailing list
