[Nek5000-users] Compiling the First 2D Example in a Cray machine using the Cray compiler
Fri May 9 06:46:15 CDT 2014
Hi Luis,
Thanks for bringing this to our attention.
In fact, the change in argument list was overlooked in a couple of places
and this was a bug.
I've just updated the repo, so if you rm ic.f and postpro.f, then svn update
these files you should be good to go.
Best,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, May 09, 2014 3:36 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Compiling the First 2D Example in a Cray machine       using the Cray compiler
Hi Neks,
I am trying to build Nek5000 for the first time and I am doing it in a
Cray machine using the Cray compiler. So, after changing
*ftn*)        P="-r8 -Mpreprocess -fast" by  *ftn*)        P="-ra  -s
real64 -eZ -em -rm " in makenek.inc I have tried to build this first
example:
makenek eddy_uv
Unfortunately I am getting an error :
ftn-1295 crayftn: ERROR MFI_PREPARE, File =
../../../work/z01/z01/lcebaman/nek5000/nek5_svn/trunk/nek/ic.f, Line =
2676, Column = 13
  "MFI_PARSE_HDR" is defined or referenced at line 2281
(/work/z01/z01/lcebaman/nek5000/nek5_svn/trunk/nek/ic.f) and here.  The
number of arguments do not match.  Expected 2, but found 1.
make: *** [obj/ic.o] Error 1
make: *** Waiting for unfinished jobs...
and I was wondering if someone has experience something similar in the
past so I could get some hints of how to proceed here.
I would appreciate any ideas.
Best regards,
Luis
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
