[Nek5000-users] Compiling the First 2D Example in a Cray machine using the Cray compiler
Fri May 9 03:36:08 CDT 2014
Hi Neks,
I am trying to build Nek5000 for the first time and I am doing it in a
Cray machine using the Cray compiler. So, after changing
*ftn*)        P="-r8 -Mpreprocess -fast" by  *ftn*)        P="-ra  -s
real64 -eZ -em -rm " in makenek.inc I have tried to build this first
example:
makenek eddy_uv
Unfortunately I am getting an error :
ftn-1295 crayftn: ERROR MFI_PREPARE, File =
../../../work/z01/z01/lcebaman/nek5000/nek5_svn/trunk/nek/ic.f, Line =
2676, Column = 13
  "MFI_PARSE_HDR" is defined or referenced at line 2281
(/work/z01/z01/lcebaman/nek5000/nek5_svn/trunk/nek/ic.f) and here.  The
number of arguments do not match.  Expected 2, but found 1.
make: *** [obj/ic.o] Error 1
make: *** Waiting for unfinished jobs...
and I was wondering if someone has experience something similar in the
past so I could get some hints of how to proceed here.
I would appreciate any ideas.
Best regards,
Luis
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
