[Nek5000-users] nek installation and running errors
Wed Jul 23 06:21:20 CDT 2014
Apparently I did not place the /bin in the executable path. now it works fine!
PATH=$PATH:~/.bin
export PATH
Thanks.
Thangam.
To: nek5000-users at lists.mcs.anl.gov
Subject: nek installation and running errors
Date: Wed, 23 Jul 2014 09:17:07 +0530
Thanks Paul. The issue is my system doesnt recognize the commands 'nek' and 'nekb' etc. Do I have to set the environment variables by sourcing the bash file?
Thanks.
Thangam.
Subject: Nek5000-users Digest, Vol 65, Issue 13
Date: Tue, 22 Jul 2014 12:00:08 -0500
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
	nek5000-users-request at lists.mcs.anl.gov
You can reach the person managing the list at
	nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
--Forwarded Message Attachment--
Date: Mon, 21 Jul 2014 19:08:13 +0200
Subject: [Nek5000-users] Extruding 2D .fld file to 3D
Hi Neks,
I followed what Fisher posted in the below link and tried to extrude a 2D flow into 3D.
	http://lists.mcs.anl.gov/pipermail/nek5000-users/2013-October/002333.html
85 c-----------------------------------------------------------------------
86       subroutine usrdat2
87       include 'SIZE'
88       include 'TOTAL'
89
90
91       nelx=lelx,nely=lely,nelz=lelz
92       parameter (l2d=lx1*ly1*lelx)
93       common /mystuff/ u2d(l2d),v2d(l2d)
94
95        if (nid.eq.0) then
96           open(33,file='2D.dat')
97           do i=1,l2d
98              read(33,*) u2d(i),v2d(i)
99           enddo
100           close(33)
101        endif
102        nbytes = 8*l2d
103        call bcast(u2d,nbytes)
104        call bcast(v2d,nbytes)
105
106        call z_average_transpose(vx,u2d)
107        call z_average_transpose(vy,v2d)
108
109        call outpost(vx,vy,vz,pr,t,'3d.dat')
110        call exitti('Quit in usrdat2.$',nelgt)
111
112       return
113       end
114 c-----------------------------------------------------------------------
115       subroutine usrdat3
when I compiling the simulation ( with a 2D.rea and new SIZE) it displays errors,
	nek5000/test/test3dimposed/3d/box.f:91.8:
       	1
	Error: Unclassifiable statement at (1)
	make: *** [nek5000] Error 1
Is there something I misunderstand ?
Thanks!
Wei
Date: Mon, 21 Jul 2014 18:53:10 -0400
Subject: [Nek5000-users] About governing equations
I read in website that NEK5000 can't solve fully compressible flows.
How it changes density in low mach number flows (in which we have thermal
dilatation effects)?
Thanks
Date: Tue, 22 Jul 2014 15:32:01 +0530
Subject: [Nek5000-users] nek installation and running errors
Hi all,
I am trying to download and install NEK5000 and trying to get a hang of it. I have downloaded and tried to the first example from the 'quick start' page.  The compilation is successful after the makenek command. However, it does not realize further nek commands such as nek, nekb etc. (command not found error)I went on to issue the command ./nek5000 eddy_uv and following was the output.
 Number of processors:           1
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
 No file SESSION.NAME; using defaults of
 PATH=. and SESSION=NEK.
  Beginning session:
  ./NEK.rea
 timer accuracy:   0.0000000E+00 sec
 read .rea file
At line 32 of file /home/thangam/nek5_svn/trunk/nek/connect2.f (unit = 9, file = '')
Fortran runtime error: File './NEK.rea' does not exist
I have put a copy of the scripts under the /bin directory as well.
I dont understand what I am missing and where im going wrong!
Thanks.
Thangam.
Date: Tue, 22 Jul 2014 10:10:12 -0500
Subject: Re: [Nek5000-users] nek installation and running errors
You should use one of the scripts in
    trunk/tools/scripts
The usual command would be
nek blah
where blah is the name of your .rea file.
To run in background (strongly recommended),
nekb blah
For mpi there are nekmpi and nekbmpi
nekmpi blah 4
would run on 4 ranks, etc.
There is some description of this in the manual.
Paul
On Tue, 22 Jul 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi all,
> REAL    wdsize      :           8
> INTEGER wdsize      :           4
>  Beginning session:
>  ./NEK.rea
> read .rea file
> Thanks.
> Thangam.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140723/f55913d0/attachment-0001.html>
