[Nek5000-users] nek installation and running errors
Tue Jul 22 10:10:12 CDT 2014
You should use one of the scripts in
    trunk/tools/scripts
The usual command would be
nek blah
where blah is the name of your .rea file.
To run in background (strongly recommended),
nekb blah
For mpi there are nekmpi and nekbmpi
nekmpi blah 4
would run on 4 ranks, etc.
There is some description of this in the manual.
Paul
On Tue, 22 Jul 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi all,
> I am trying to download and install NEK5000 and trying to get a hang of it. I have downloaded and tried to the first example from the 'quick start' page.  The compilation is successful after the makenek command. However, it does not realize further nek commands such as nek, nekb etc. (command not found error)I went on to issue the command ./nek5000 eddy_uv and following was the output.
> Number of processors:           1
> REAL    wdsize      :           8
> INTEGER wdsize      :           4
> No file SESSION.NAME; using defaults of
> PATH=. and SESSION=NEK.
>  Beginning session:
>  ./NEK.rea
> timer accuracy:   0.0000000E+00 sec
> read .rea file
> At line 32 of file /home/thangam/nek5_svn/trunk/nek/connect2.f (unit = 9, file = '')
> Fortran runtime error: File './NEK.rea' does not exist
> I have put a copy of the scripts under the /bin directory as well.
> I dont understand what I am missing and where im going wrong!
> Thanks.
> Thangam.
