[Nek5000-users] periodic boundary conditions
Wed Jul 16 10:05:23 CDT 2014
Hi Neks,
related to the latter post. Is it possible to establish the connectivity
between two faces in the usr file? I mean, if I set in the rea file
p 1 3 0 0 0 0 0
p 2 4 0 0 0 0 0
What should I write in the usr file to connect these two faces? Is it
possible to do what I want?
Thanks in advance.
SL
El 16-07-2014 09:40, nek5000-users at lists.mcs.anl.gov escribió:
> Hi Neks,
> I'm trying to simulate the flow past a flat plate. I've generated the
> mesh with Gambit and later I've used the code from Michael Meador to
> convert the Gambit file to Nek5000. Everything works fine, however I
> have a problem with the periodic boundary conditions.
> I've imposed periodic BC in 2 sides of the domain. The output of the
> code to Nek5000 for the periodic BC is (e.g.):
> P      1       3      0.00000       0.00000       0.00000
> 0.00000       0.00000
> So, I cannot link the two sides of the domain.
> Do you know if there is any way to link these sides?
> Thanks
> SL
> Nek5000-users mailing list
