[Nek5000-users] Pipe with expansion
Tue Jan 21 10:41:07 CST 2014
Kamal,
Usually what I would do in your case is to make a copy
of the torque_calc routine, rename it, and modify to your
specific needs.   It essentially provides a template for
what needs to happen.
Paul
On Tue, 21 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi paul,
> can I make this to be drag or shear quantities to be return to the a separate
> file so that it will easy for me to plot.
> By the way it gives the integral quantity. Think for example I need to find
> the shear stress on the wall  from the inlet to outlet at a particular time =
> 2 . How can I do that ?
> Is there way to find the number of elements in x,y and z direction ?
> On 21/01/2014 17:32, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Kamal,
>> Your integrated drag quantities should be written to the logfile (stdout),
>> assuming you've set the arguments in the call to be .true.
>> Paul
>>> Hi Paul,
>>> I checked the set_obj subroutine and implemented one in my .USR file. The
>>> code seem to run without any errors but I don't find where these variables
>>> are getting stored.
>>> I use VisIT to visualize my output, even there was no change in it.
>>> do I have to define my own output file and write the variables out ?
>>> Thanks,
>>> Kamal.
>>> On 20/01/2014 21:52, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Kamal,
>>>> You'll need to compute your own tke by manipulating the
>>>> velocity fields.
>>>> You can get running averages of the requisite quantities
>>>> via calls to "avg_all" which is found in navier5.f
>>>> You can compute shear stress on the wall simply by computing
>>>> the drag on the wall, which can be done via a call to torque_calc(),
>>>> also found in navier5.f
>>>> If you cd to /examples and type:
>>>>       grep torq */*.usr
>>>> you'll find many examples of calls to torque_calc.  You simply
>>>> need to prescribe the surfaces on which shear is to be integrated.
>>>> I typically write a routine "set_obj" to identify such surfaces
>>>> on the first call to usrchk.
>>>>       grep set_obj */*.usr
>>>> will show similar examples.
>>>> I would recommend trying this for laminar Poiseiulle flow in
>>>> a very simple channel just to check that your calls are properly
>>>> set.
>>>> Best,
>>>> Paul
>>>> On Mon, 20 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Paul,
>>>>> Thanks and that helped.
>>>>> Where can I find the variables like Turbulent KE , shear stress on the
>>>>> wall. ?
>>>>> Do i have to activate some parameters for calculating them ?
>>>>> If I had to plot them.
>>>>> Thanks,
>>>>> Kamal
>>>>> On Jan 20, 2014, at 5:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Kamal,
>>>>>> Looks good.
>>>>>> I'm guessing that one further refinement would be:
>>>>>> if (z.gt.z0) scale = 1 + (smax-1)*(z-z0)/(z1-z0)
>>>>>> if (z.gt.z1) scale = smax
>>>>>> which would yield
>>>>>>   scale = 1 when z=z0
>>>>>>   scale = smax when z >= z1
>>>>>> Paul
>>>>>> On Sun, 19 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi paul,
>>>>>>> The code works fine, but there should be a small change thats has to
>>>>>>> be done
>>>>>>> if (z.gt.z0) scale = 1 + (z /(z1-z0 )))
>>>>>>> This creates a perfect diverging pipe.
>>>>>>> Thanks for the help paul.
>>>>>>> Kamal
>>>>>>> On Jan 20, 2014, at 12:09 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>> Hi paul,
>>>>>>>> If I am not wrong,
>>>>>>>> I make a mesh with three straight pipes( inlet, divergent, outlet )
>>>>>>>> connected together via n2to3 so that I know the element connectivity
>>>>>>>> places of the divergent section (z0,z1) and use the section what you
>>>>>>>> gave
>>>>>>>> Thank you for the code
>>>>>>>> Kamal
>>>>>>>> On Jan 19, 2014, at 8:45 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>> Kamal,
>>>>>>>>> I would do the following in usrdat2():
>>>>>>>>>    n=nx1*ny1*nz1*nelt
>>>>>>>>>    do i=1,n
>>>>>>>>>       x=xm1(i,1,1,1)
>>>>>>>>>       y=ym1(i,1,1,1)
>>>>>>>>>       z=ym1(i,1,1,1)
>>>>>>>>>       scale = 1.
>>>>>>>>>       if (z.gt.z0) scale = smax*(z-z0/(z1-z0)
>>>>>>>>>       xm1(i,1,1,1) = scale*x
>>>>>>>>>       ym1(i,1,1,1) = scale*y
>>>>>>>>>    enddo
>>>>>>>>> Paul
>>>>>>>>> Make certain that z1 and z0 correspond to z values
>>>>>>>>> that precisely coincide with element interfaces.
>>>>>>>>>> Hi Paul,
>>>>>>>>>> I looked into the Peris example but It is so what same like the
>>>>>>>>>> stenosis example with a Cosine deformation.
>>>>>>>>>> In my case it is a pipe with conical divergent. I tried to play
>>>>>>>>>> around the variables Xm1, Ym1 and Zm1 but the mapping doesn't go
>>>>>>>>>> well.
>>>>>>>>>> Could you please help me with this.
>>>>>>>>>> Thank you,
>>>>>>>>>> Kamal
>>>>>>>>>> On Jan 18, 2014, at 7:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>> Hi Paul,
>>>>>>>>>>> I looked at the Helix and stenosis example but they are using
>>>>>>>>>>> cosine functions to deform
>>>>>>>>>>> I tried to use a tangent function but it bends the whole pipe.
>>>>>>>>>>> I dint look at peris example .
>>>>>>>>>>> I will take a look at it and let you know.
>>>>>>>>>>> Thank you
>>>>>>>>>>> Kamal
>>>>>>>>>>> On Jan 18, 2014, at 7:22 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Kamal,
>>>>>>>>>>>> Have you looked at the peris example?  The usr file there shows
>>>>>>>>>>>> how to deform
>>>>>>>>>>>> a pipe geometry.
>>>>>>>>>>>> Paul
>>>>>>>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>>>>>>>>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>>>>>>>>>>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>>>>>>>>>> Sent: Saturday, January 18, 2014 12:17 PM
>>>>>>>>>>>> To: nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>> Subject: Re: [Nek5000-users] Pipe with expansion
>>>>>>>>>>>> Dear Paul,
>>>>>>>>>>>> I tried many ways to map my straight pipe geometry but it does
>>>>>>>>>>>> not seem to work properly
>>>>>>>>>>>> I used something like
>>>>>>>>>>>> X = X + Z * tan ( alpha )
>>>>>>>>>>>> Y = Y + Z* tan (alpha )
>>>>>>>>>>>> even that dint work. could please help me with this
>>>>>>>>>>>> Thank you
>>>>>>>>>>>> Kamal.
>>>>>>>>>>>> On Jan 17, 2014, at 2:24 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>> Thanks paul. I tried working with the diverging mesh
>>>>>>>>>>>>> modification.
>>>>>>>>>>>>> I tried to use this form of equation to modify the mesh
>>>>>>>>>>>>> z = mx + b
>>>>>>>>>>>>> z = ny  + c
>>>>>>>>>>>>> x = ( z - b ) / m
>>>>>>>>>>>>> y = (z - c)  / n
>>>>>>>>>>>>> Do you think would work ? or is there any other way to input
>>>>>>>>>>>>> that ?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>> On 17/01/2014 14:14, nek5000-users at lists.mcs.anl.govwrote:
>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>> 1) To check for convergence, run your simulation for increasing
>>>>>>>>>>>>>> polynomial orders ( lx1 in the SIZE file) and measure some
>>>>>>>>>>>>>> consistent quantity (drag, TKE, etc).  You can plot this
>>>>>>>>>>>>>> quantity against lx1 and this should give you a good picture of
>>>>>>>>>>>>>> how you are converging (without needing to change the physical
>>>>>>>>>>>>>> mesh).
>>>>>>>>>>>>>> 2) If you weren't using temperature in your simulation, you
>>>>>>>>>>>>>> could do put the following code snippet in your userchk
>>>>>>>>>>>>>> c-------------------------------------------
>>>>>>>>>>>>>> integer i, ntot
>>>>>>>>>>>>>> ntot = nx1*ny1*nz1*nelv  ! total number of points in simulation
>>>>>>>>>>>>>> (on THIS processor)
>>>>>>>>>>>>>> do i = 1,ntot
>>>>>>>>>>>>>> t(i,1,1,1,1) = 0.5*(vx(i,1,1,1)**2 + vy(i,1,1,1)**2 +
>>>>>>>>>>>>>> vz(i,1,1,1)**2)
>>>>>>>>>>>>>> enddo
>>>>>>>>>>>>>> ifto = .true.
>>>>>>>>>>>>>> I've assumed here that your density is unity. This computed
>>>>>>>>>>>>>> kinetic energy point-wise and stores it in the temperature
>>>>>>>>>>>>>> field. The part "ifto = .true." tells Nek to output the
>>>>>>>>>>>>>> temperature field whenever it outputs a field file.  You could
>>>>>>>>>>>>>> then view this in visit just like you would the velocity field.
>>>>>>>>>>>>>> Hope this helps!
>>>>>>>>>>>>>> Josh
>>>>>>>>>>>>>> On Wed, Jan 15, 2014 at 9:52 AM,
>>>>>>>>>>>>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>> I will try that mapping, I created a straight pipe to do some
>>>>>>>>>>>>>> simulations.
>>>>>>>>>>>>>> 1) Is there a way to check my spectral convergence, so that I
>>>>>>>>>>>>>> can do some mesh convergence study?
>>>>>>>>>>>>>> 2) Is there a way to plot the kinetic energy in the flow ?
>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>> On 15/01/2014 12:14, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>>> Hi Kamal,
>>>>>>>>>>>>>> For the geometry you describe, I would apply mesh morphing
>>>>>>>>>>>>>> to a standard straight pipe.  You can create such a pipe
>>>>>>>>>>>>>> using a subset of the mkmesh script provided in the expansion
>>>>>>>>>>>>>> example.
>>>>>>>>>>>>>> If your transition region is conical, then I woud make
>>>>>>>>>>>>>> certain that the change in slope occurs at element boundaries,
>>>>>>>>>>>>>> i.e., as in the half cross-section depicted below:
>>>>>>>>>>>>>>                            _______________
>>>>>>>>>>>>>>     ________________/  |   |      |      |
>>>>>>>>>>>>>> +-----+-----+---+--+---+------+------+----> z
>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>> On Wed, 15 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>> I looked at the example and it looks very helpful, but for a
>>>>>>>>>>>>>> sudden expansion we have only two parts (i.e) the inlet pipe
>>>>>>>>>>>>>> and the outlet pipe. Whereas in a diverging pipe we have three
>>>>>>>>>>>>>> section (i.e,) The inlet pipe, Diverging section and the outlet
>>>>>>>>>>>>>> pipe.
>>>>>>>>>>>>>> Is it possible for me to create a 2D diverging section using
>>>>>>>>>>>>>> mesh modification and revolve it around the centre axis to get
>>>>>>>>>>>>>> a 3d diverging pipe ?
>>>>>>>>>>>>>> or should I apply the mesh modification directly to the 3d
>>>>>>>>>>>>>> sudden expansion pipe using usrdat2() ?
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>> On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>> Thanks a lot for the update. I will take a look at as soon as
>>>>>>>>>>>>>> possible and keep you updated with it.
>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>> On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>> I've added an example for a step-type expansion in a pipe. New
>>>>>>>>>>>>>> example directory
>>>>>>>>>>>>>> is nek5_svn/examples/expansion, with a README.
>>>>>>>>>>>>>> If you want a standard diffuser, I would use mesh-morphing, as
>>>>>>>>>>>>>> outlined in the
>>>>>>>>>>>>>> nek primer, which can be found on this page:
>>>>>>>>>>>>>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>>>>>>>>>>>>>> I've also automated our turbulent outflow bc treatment -- one
>>>>>>>>>>>>>> simply provides an
>>>>>>>>>>>>>> expansion factor (typically ~ 1.5) and two persistent arrays to
>>>>>>>>>>>>>> turb_outflow(), which
>>>>>>>>>>>>>> is now in navier5.f.    This can be useful when very strong
>>>>>>>>>>>>>> vortices are leaving the
>>>>>>>>>>>>>> domain, which is possible for certain diffuser flow conditions
>>>>>>>>>>>>>> (and others).
>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>> ________________________________________
>>>>>>>>>>>>>> ofnek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>>>>>>>>>>>> Subject: [Nek5000-users] Creating a Mesh
>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>> Can some one please help me in this because I am new to nek
>>>>>>>>>>>>>> 1) How can I create a .rea for a specific geometry say ' A
>>>>>>>>>>>>>> sudden
>>>>>>>>>>>>>> expansion pipe ' or a ' Diverging pipe '
>>>>>>>>>>>>>> 2) What tool I should use to create that mesh.
>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>> kamal
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>>>>>>>>> Josh Camp
>>>>>>>>>>>>>> "All that is necessary for the triumph of evil is that good men
>>>>>>>>>>>>>> do nothing" -- Edmund Burke
