[Nek5000-users] Pipe with expansion
Tue Jan 21 10:33:36 CST 2014
Hi paul,
can I make this to be drag or shear quantities to be return to the a
separate file so that it will easy for me to plot.
By the way it gives the integral quantity. Think for example I need to
find the shear stress on the wall  from the inlet to outlet at a
particular time = 2 . How can I do that ?
Is there way to find the number of elements in x,y and z direction ?
On 21/01/2014 17:32, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> Your integrated drag quantities should be written to the logfile
> (stdout),
> assuming you've set the arguments in the call to be .true.
> Paul
> On Tue, 21 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> I checked the set_obj subroutine and implemented one in my .USR file.
>> The code seem to run without any errors but I don't find where these
>> variables are getting stored.
>> I use VisIT to visualize my output, even there was no change in it.
>> do I have to define my own output file and write the variables out ?
>> Thanks,
>> Kamal.
>> On 20/01/2014 21:52, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Kamal,
>>> You'll need to compute your own tke by manipulating the
>>> velocity fields.
>>> You can get running averages of the requisite quantities
>>> via calls to "avg_all" which is found in navier5.f
>>> You can compute shear stress on the wall simply by computing
>>> the drag on the wall, which can be done via a call to torque_calc(),
>>> also found in navier5.f
>>> If you cd to /examples and type:
>>>       grep torq */*.usr
>>> you'll find many examples of calls to torque_calc.  You simply
>>> need to prescribe the surfaces on which shear is to be integrated.
>>> I typically write a routine "set_obj" to identify such surfaces
>>> on the first call to usrchk.
>>>       grep set_obj */*.usr
>>> will show similar examples.
>>> I would recommend trying this for laminar Poiseiulle flow in
>>> a very simple channel just to check that your calls are properly
>>> set.
>>> Best,
>>> Paul
>>> On Mon, 20 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Paul,
>>>> Thanks and that helped.
>>>> Where can I find the variables like Turbulent KE , shear stress on
>>>> the wall. ?
>>>> Do i have to activate some parameters for calculating them ?
>>>> If I had to plot them.
>>>> Thanks,
>>>> Kamal
>>>> On Jan 20, 2014, at 5:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Kamal,
>>>>> Looks good.
>>>>> I'm guessing that one further refinement would be:
>>>>> if (z.gt.z0) scale = 1 + (smax-1)*(z-z0)/(z1-z0)
>>>>> if (z.gt.z1) scale = smax
>>>>> which would yield
>>>>>   scale = 1 when z=z0
>>>>>   scale = smax when z >= z1
>>>>> Paul
>>>>> On Sun, 19 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi paul,
>>>>>> The code works fine, but there should be a small change thats has
>>>>>> to be done
>>>>>> if (z.gt.z0) scale = 1 + (z /(z1-z0 )))
>>>>>> This creates a perfect diverging pipe.
>>>>>> Thanks for the help paul.
>>>>>> Kamal
>>>>>> On Jan 20, 2014, at 12:09 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi paul,
>>>>>>> If I am not wrong,
>>>>>>> I make a mesh with three straight pipes( inlet, divergent,
>>>>>>> outlet ) connected together via n2to3 so that I know the element
>>>>>>> connectivity places of the divergent section (z0,z1) and use the
>>>>>>> section what you gave
>>>>>>> Thank you for the code
>>>>>>> Kamal
>>>>>>> On Jan 19, 2014, at 8:45 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>> Kamal,
>>>>>>>> I would do the following in usrdat2():
>>>>>>>>    n=nx1*ny1*nz1*nelt
>>>>>>>>    do i=1,n
>>>>>>>>       x=xm1(i,1,1,1)
>>>>>>>>       y=ym1(i,1,1,1)
>>>>>>>>       z=ym1(i,1,1,1)
>>>>>>>>       scale = 1.
>>>>>>>>       if (z.gt.z0) scale = smax*(z-z0/(z1-z0)
>>>>>>>>       xm1(i,1,1,1) = scale*x
>>>>>>>>       ym1(i,1,1,1) = scale*y
>>>>>>>>    enddo
>>>>>>>> Paul
>>>>>>>> Make certain that z1 and z0 correspond to z values
>>>>>>>> that precisely coincide with element interfaces.
>>>>>>>>> Hi Paul,
>>>>>>>>> I looked into the Peris example but It is so what same like
>>>>>>>>> the stenosis example with a Cosine deformation.
>>>>>>>>> In my case it is a pipe with conical divergent. I tried to
>>>>>>>>> play around the variables Xm1, Ym1 and Zm1 but the mapping
>>>>>>>>> doesn't go well.
>>>>>>>>> Could you please help me with this.
>>>>>>>>> Thank you,
>>>>>>>>> Kamal
>>>>>>>>> On Jan 18, 2014, at 7:26 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>> wrote:
>>>>>>>>>> Hi Paul,
>>>>>>>>>> I looked at the Helix and stenosis example but they are using
>>>>>>>>>> cosine functions to deform
>>>>>>>>>> I tried to use a tangent function but it bends the whole pipe.
>>>>>>>>>> I dint look at peris example .
>>>>>>>>>> I will take a look at it and let you know.
>>>>>>>>>> Thank you
>>>>>>>>>> Kamal
>>>>>>>>>> On Jan 18, 2014, at 7:22 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>> wrote:
>>>>>>>>>>> Kamal,
>>>>>>>>>>> Have you looked at the peris example?  The usr file there
>>>>>>>>>>> shows how to deform
>>>>>>>>>>> a pipe geometry.
>>>>>>>>>>> Paul
>>>>>>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>>>>>>>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>>>>>>>>>> [nek5000-users at lists.mcs.anl.gov]
>>>>>>>>>>> Sent: Saturday, January 18, 2014 12:17 PM
>>>>>>>>>>> To: nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>> Subject: Re: [Nek5000-users] Pipe with expansion
>>>>>>>>>>> Dear Paul,
>>>>>>>>>>> I tried many ways to map my straight pipe geometry but it
>>>>>>>>>>> does not seem to work properly
>>>>>>>>>>> I used something like
>>>>>>>>>>> X = X + Z * tan ( alpha )
>>>>>>>>>>> Y = Y + Z* tan (alpha )
>>>>>>>>>>> even that dint work. could please help me with this
>>>>>>>>>>> Thank you
>>>>>>>>>>> Kamal.
>>>>>>>>>>> On Jan 17, 2014, at 2:24 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>> Thanks paul. I tried working with the diverging mesh
>>>>>>>>>>>> modification.
>>>>>>>>>>>> I tried to use this form of equation to modify the mesh
>>>>>>>>>>>> z = mx + b
>>>>>>>>>>>> z = ny  + c
>>>>>>>>>>>> x = ( z - b ) / m
>>>>>>>>>>>> y = (z - c)  / n
>>>>>>>>>>>> Do you think would work ? or is there any other way to
>>>>>>>>>>>> input that ?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Kamal
>>>>>>>>>>>> On 17/01/2014 14:14, nek5000-users at lists.mcs.anl.govwrote:
>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>> 1) To check for convergence, run your simulation for
>>>>>>>>>>>>> increasing polynomial orders ( lx1 in the SIZE file) and
>>>>>>>>>>>>> measure some consistent quantity (drag, TKE, etc).  You
>>>>>>>>>>>>> can plot this quantity against lx1 and this should give
>>>>>>>>>>>>> you a good picture of how you are converging (without
>>>>>>>>>>>>> needing to change the physical mesh).
>>>>>>>>>>>>> 2) If you weren't using temperature in your simulation,
>>>>>>>>>>>>> you could do put the following code snippet in your userchk
>>>>>>>>>>>>> c-------------------------------------------
>>>>>>>>>>>>> integer i, ntot
>>>>>>>>>>>>> ntot = nx1*ny1*nz1*nelv  ! total number of points in
>>>>>>>>>>>>> simulation (on THIS processor)
>>>>>>>>>>>>> do i = 1,ntot
>>>>>>>>>>>>> t(i,1,1,1,1) = 0.5*(vx(i,1,1,1)**2 + vy(i,1,1,1)**2 +
>>>>>>>>>>>>> vz(i,1,1,1)**2)
>>>>>>>>>>>>> enddo
>>>>>>>>>>>>> ifto = .true.
>>>>>>>>>>>>> I've assumed here that your density is unity. This
>>>>>>>>>>>>> computed kinetic energy point-wise and stores it in the
>>>>>>>>>>>>> temperature field. The part "ifto = .true." tells Nek to
>>>>>>>>>>>>> output the temperature field whenever it outputs a field
>>>>>>>>>>>>> file.  You could then view this in visit just like you
>>>>>>>>>>>>> would the velocity field.
>>>>>>>>>>>>> Hope this helps!
>>>>>>>>>>>>> Josh
>>>>>>>>>>>>> On Wed, Jan 15, 2014 at 9:52 AM,
>>>>>>>>>>>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>> I will try that mapping, I created a straight pipe to do
>>>>>>>>>>>>> some simulations.
>>>>>>>>>>>>> 1) Is there a way to check my spectral convergence, so
>>>>>>>>>>>>> that I can do some mesh convergence study?
>>>>>>>>>>>>> 2) Is there a way to plot the kinetic energy in the flow ?
>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>> On 15/01/2014 12:14, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>> Hi Kamal,
>>>>>>>>>>>>> For the geometry you describe, I would apply mesh morphing
>>>>>>>>>>>>> to a standard straight pipe.  You can create such a pipe
>>>>>>>>>>>>> using a subset of the mkmesh script provided in the expansion
>>>>>>>>>>>>> example.
>>>>>>>>>>>>> If your transition region is conical, then I woud make
>>>>>>>>>>>>> certain that the change in slope occurs at element
>>>>>>>>>>>>> boundaries,
>>>>>>>>>>>>> i.e., as in the half cross-section depicted below:
>>>>>>>>>>>>>                            _______________
>>>>>>>>>>>>>     ________________/  |   |      |      |
>>>>>>>>>>>>> +-----+-----+---+--+---+------+------+----> z
>>>>>>>>>>>>> Paul
>>>>>>>>>>>>> On Wed, 15 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>> I looked at the example and it looks very helpful, but for
>>>>>>>>>>>>> a sudden expansion we have only two parts (i.e) the inlet
>>>>>>>>>>>>> pipe and the outlet pipe. Whereas in a diverging pipe we
>>>>>>>>>>>>> have three section (i.e,) The inlet pipe, Diverging
>>>>>>>>>>>>> section and the outlet pipe.
>>>>>>>>>>>>> Is it possible for me to create a 2D diverging section
>>>>>>>>>>>>> using mesh modification and revolve it around the centre
>>>>>>>>>>>>> axis to get a 3d diverging pipe ?
>>>>>>>>>>>>> or should I apply the mesh modification directly to the 3d
>>>>>>>>>>>>> sudden expansion pipe using usrdat2() ?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>> On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>> Thanks a lot for the update. I will take a look at as soon
>>>>>>>>>>>>> as possible and keep you updated with it.
>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>> On Jan 14, 2014, at 9:04 PM,
>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>> I've added an example for a step-type expansion in a pipe.
>>>>>>>>>>>>> New example directory
>>>>>>>>>>>>> is nek5_svn/examples/expansion, with a README.
>>>>>>>>>>>>> If you want a standard diffuser, I would use
>>>>>>>>>>>>> mesh-morphing, as outlined in the
>>>>>>>>>>>>> nek primer, which can be found on this page:
>>>>>>>>>>>>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>>>>>>>>>>>>> I've also automated our turbulent outflow bc treatment --
>>>>>>>>>>>>> one simply provides an
>>>>>>>>>>>>> expansion factor (typically ~ 1.5) and two persistent
>>>>>>>>>>>>> arrays to turb_outflow(), which
>>>>>>>>>>>>> is now in navier5.f.    This can be useful when very
>>>>>>>>>>>>> strong vortices are leaving the
>>>>>>>>>>>>> domain, which is possible for certain diffuser flow
>>>>>>>>>>>>> conditions (and others).
>>>>>>>>>>>>> Paul
>>>>>>>>>>>>> ________________________________________
>>>>>>>>>>>>> ofnek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>>>>>>>>>>> Subject: [Nek5000-users] Creating a Mesh
>>>>>>>>>>>>> Hi
>>>>>>>>>>>>> Can some one please help me in this because I am new to nek
>>>>>>>>>>>>> 1) How can I create a .rea for a specific geometry say ' A
>>>>>>>>>>>>> sudden
>>>>>>>>>>>>> expansion pipe ' or a ' Diverging pipe '
>>>>>>>>>>>>> 2) What tool I should use to create that mesh.
>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>> kamal
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>>>>>>>> Josh Camp
>>>>>>>>>>>>> "All that is necessary for the triumph of evil is that
>>>>>>>>>>>>> good men do nothing" -- Edmund Burke
