[Nek5000-users] Load_fld() without restart
Mon Jan 20 02:51:35 CST 2014
Hi Josh,
Thank you for your answer. We had already considered using this approach
but we have a few queries. We would like to load a .fld file at each
time step, which means the process might become very costly. Do you have
any idea of the cost (in time) of such a method? Also, what becomes of
the variables calculated during the previous time steps?
Thanks again,
Holly
Le 17/01/2014 14:21, nek5000-users at lists.mcs.anl.gov a écrit :
> Hi Holly,
> If you wanted to load a .fld file without copying over your variables,
> you could do something like
> ! Create temporary storage
> real tmp1(lx1*ly1*lz1*lelv), tmp2(lx1*ly1*lz1*lelv), ...
> ! Copy simulation fields to temporary variables
> call copy(tmp1,vx,nx1*ny1*nz1*nelv)
> ! Load field file and do whatever work you want to do with it
> ! Copy simulation fields back to nek variables
> call copy(vx,tmp1,nx1*ny1*nz1*nelv)
> You should be able to use some of the Nek scratch arrays to store your
> temporary variables (instead of taking up more memory with the
> explicit declaration), but I'm not sure at the moment which scratch
> arrays load_fld() uses.
> - Josh
> On Fri, Jan 17, 2014 at 4:56 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Neks !
>     Is there a way to load a .fld file during a simulation (in the
>     same way load_fld() does) but without doing a complete restart of
>     all the variables ?
>     Thanks for any help !
>     Holly
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do
> nothing" -- Edmund Burke
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140120/e19d6a31/attachment.html>
